CSI Perform 3D
Perform 3D v2.1
(Students Version)
Documents
PERFORM 3D is a highly focused nonlinear software tool for earthquake resistant design. Complex structures, including those with intricate shear wall layouts, can be analyzed nonlinearly using a wide variety of deformation-based and strength-based limit states.Model data can be imported directly from ETABS and SAP2000. A wide variety of element types are supported, including beams (with panel zones), columns, braces, shear walls (with openings), floor slabs, dampers, and isolators.
Nonlinear analyses can be static and/or dynamic, and can be run on the same model. Loads can be applied in any sequence, such as a dynamic earthquake load followed by a static pushover.
PERFORM 3D provides powerful performance based design capabilities, and can calculate demand/capacity (usage) ratios for all components and all limit states. Performance assessment based on ATC-40, FEMA-356 or ATC-440 is fully automated.
PERFORM 3D output includes usage ratio plots, pushover diagrams, energy balance displays, as well as mode shapes, deflected shapes, and time history records of displacements and forces.
PERFORMANCE ASSESSMENT
PERFORM has built in tools for widely accepted methods of performance assessment
• Deformation and/or strength capacities (acceptance criteria) for components of all types.
• Limit states based on deformation, strength and/or drift.
• Demand-capacity ratios are calculated for all components, and usage ratios for all limit states.
• Performance assessment using static pushover methods, including Capacity Spectrum Method, FEMA 356 and ATC 440 Coefficient (Displacement Modification) Methods, and FEMA 440 Linearization Method. Graphic implementation of all methods, clearly showing target displacement (performance point) and limit states.
• Simple graphic display of limit state usage ratios for dynamic earthquake analyses.
• Results combination for multiple dynamic earthquake analyses, with mean demand/capacity ratios calculated at component level, and simple graphic display of limit sate usage ratios. Simplifies decision making by reducing the results of complex analyses to a few simple graphs.
• Draw structure with members and/or individual plastic hinges colored based on demand/capacity ratio, for both single load cases and load case combinations, to help identify "hot spots".
NONLINEAR MODELING
An unparalleled variety of nonlinear and linear components. Simple properties if you want to keep it simple. More complex properties, as options, if you want sophistication.
• Bars of several types, including buckling bars.
• Beams, columns, braces, shear links.
• Fiber cross sections for beams, columns and walls. Steel, concrete, tension-only and buckling fibers.
• Plastic hinges with PMM Interaction.
• Shear hinges with V-V interaction.
• Fracturing connections.
• Panel zones in beam-to-column connections.
• Shear walls, including coupling beams.
• Squat walls with irregular openings.
• Buckling restrained braces.
• Nonlinear fluid dampers.
• Rubber type and friction pendulum isolators.
• Floor slabs.
• All nonlinear components have similar force-deformation relationships. Elastic-perfectly-plastic or trilinear behavior, with brittle strength loss as an option. FEMA 356 relationship as a special case.
• Optional stiffness and energy degradation under cyclic load. This can be important for earthquake time history analysis.
• P-delta effects in all components, including seismic isolators.
• Account for uncertainty in member properties by specifying upper and lower bounds on strength and stiffness, then vary member strength and/or stiffness at analysis time, without changing the model
• Import model geometry and loads from ETABS and SAP2000
• Full graphic interface
NONLINEAR ANALYSIS
Automated and reliable strategies for static and dynamic analysis, even for complex behavior with brittle strength loss and/or P-delta effects. Handles very large models.
• Nonlinear static pushover, in any direction.
• Nonlinear time history analysis for earthquake ground motions.
• Nonlinear time history analysis for dynamic external forces.
• Modal and/or Rayleigh damping.
• Arbitrary load sequences, such as cyclic push-over or earthquake time-history followed by pushover.
CHECK BEHAVIOR AND DISPLAY RESULTS
Includes a variety of tools to display results, for checking the analysis model and to help you understand the behavior of the structure.
• Time history plots of results, including displacements, velocities, relative and absolute accelerations, member forces, member deformations, drifts and forces on cross sections through any part of the structure.
• Built-in calculation of "floor" response spectra.
• Hysteresis loop plots for inelastic components.
• Graphical energy balance, showing how much energy is dissipated by members of each type.
• Animated deflected shapes, with optional coloring based on member demand/capacity ratio.
• Bending moment and shear force diagrams for beams and columns, including animation.
• Bending moment and shear force diagrams for complex shear walls and shear cores.
• Animated mode shapes.
• Save results to text files for off-line processing (rarely needed).
FOR PERFORM-COLLAPSE
The modeling and performance assessment capabilities of PERFORM 3D, with analysis methods specifically for progressive collapse using the alternate path method.
• Static and dynamic analysis options.
• Catenary effects in floors (true large displacements analysis).
• Automatic calculation and application of forces in removed columns or walls.
• Automatic calculation of vertical masses for progressive collapse analysis.
Download Links:
1.Follows the rules
2.Use "Search" before posting
4.Do not spam
5.Respect the other members
4.Do not spam
