Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Foundation: Telecom, Transmission, Guyed Tower, Pole Footing - TIA 222F & ACI
 mahfuzbangla
User ID: 11568
Threads: 13
Likes: 306 in 16 posts
Given Likes: 407
03-14-2010, 04:23 PM (This post was last modified: 06-05-2021, 09:55 PM by oanm2000.)
Single Footing Design - Telecom, Transmission & Guyed Tower & Pole - TIA 222F & ACI
[Image: 29003842113651014670.jpg]
Its a Excel SheetΒ  for Single Footing Design for Telecomm, Transmission & Guyed Tower & Pole according TIA 222F & ACI. Prepared by Engr Jemi Astimo (Tower design Engineer in Indonesia, Good designer). Slight modification has been made afterwards.
Here Geotechnical Design of Footing has been considered mainly. Not structural Design, as Single footing of Telecomm tower/Pole is designed considering upward force and sliding force, rather than traditional downward force.
Excel sheet or computer program is not always available for single footing design is placed considering uplift and shliding force.
If you have time then review and post comment. Everyone will be helped.
Anyway, Structural Design of footing is normal. Though attaching another excel sheet for footing structural design by daniel T Li. U can se that Excel sheet made by Daniel T Li is not all time fit for all types of footing, specially footing with uplift force and sliding.
Daniel T Li didn't made any check for uplift force and sliding.. Another excel file has been added to remove excel cell password. One Prokon Single footing file has been added... which will show same result as well with the excel sheet.
[-] The following 45 users Like mahfuzbangla's post:45 users Like mahfuzbangla's post
  β€’ rohailiyaz, Dell_Brett, cristi, cgedmundo, robertsas, asumi, isurya, arceon, simanta, Nilupa, duazo2009, civilteam, inra, Pajipitar, josh2725, fwrjel311, dbsimon29, salahcivil, kkteo03, engrezi, HellboyRBJ, parwez007, tecktik, nassara, narendra, cesar3226, super_engineer, roaming79, ruaumoko, guiu15, lucky_b2me, durden, Diquan, DamaD, levanduy, rendel_Β©, zamil.ec, Vufor, ssi3k, kkgcivil, hapimaster, ramla2002, oanm2000, jaks, bigone
 junhe898
User ID: 4760
Threads: 1
Likes: 1 in 1 posts
Given Likes: 1
08-06-2010, 11:48 AM
mahfuzbangla :
Would you please let me know what the conventional way is to strengthen the tower foundation in Asia to resist the uplift?
We deal with telecommunication tower always with the additional antennas adding onto the existing tower structure.
[-] The following 1 user Likes junhe898's post:1 user Likes junhe898's post
  β€’ telecivil
 parhyang
User ID: 25165
Threads: 28
Likes: 1,261 in 219 posts
Given Likes: 447
08-06-2010, 01:23 PM
provide counter weight for uplift / tilt problems.
[-] The following 2 users Like parhyang's post:2 users Like parhyang's post
  β€’ GROUT, bigone
 durden
User ID: 7009
Threads: 11
Likes: 86 in 13 posts
Given Likes: 306
09-09-2010, 04:10 AM (This post was last modified: 08-01-2011, 07:28 AM by Grunf.)
I believe generally to resist uplift the simplest manner in which to accomplish this is simply to provide additional weight on top of existing footings and provide more resistance.
Alternatively deepening i would assume.
[-] The following 3 users Like durden's post:3 users Like durden's post
  β€’ Diquan, bigone, nickycruz
 vsa2010
User ID: 22156
Threads: 9
Likes: 422 in 53 posts
Given Likes: 64
08-01-2011, 09:06 AM
Mirror link of post#1:
ps:including 4 files
1)Password_To_Unprotect_Excel_Sheet.xla
2)Single Footing Design - Telecomm, Transmission & Guyed Tower & Pole - TIA 222F & ACI.xls
3)Single Footing Prokon - 03-03-10.C15.txt
4)Single Footing Structural Design - Daniel T Li - Unlocked.xls
Regards.
[-] The following 21 users Like vsa2010's post:21 users Like vsa2010's post
  β€’ Dell_Brett, TAFATNEB, Grunf, quatermain, concreteok, jacs127, ting tsai huang, malc, Jackass, tluc, duazo2009, DamaD, mahfuzbangla, dinu69in, nigema, kalayil78, realbabilu, portal61, SCREAM7890, oanm2000, bigone
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,035 in 2,188 posts
Given Likes: 42494
12-12-2012, 09:25 AM
Compilation of Footing Design Spreadsheets:
[Image: 58164686366531360960.jpg]
581 KB
[-] The following 34 users Like Dell_Brett's post:34 users Like Dell_Brett's post
  β€’ Andrew seah, mahyarov, shadabg, pezhmankhan, bigone, isurya, ting tsai huang, ska51, gulilero, odiclas, Diquan, oanm2000, kowheng, malc, we_mbm, gundis, cardinal85, nickycruz, TAFATNEB, Ambition, jaks, nibbi, blaze, PinkPant, chenamoy, hignacio43, geomahesh, Rodmo376, legarleon, pram, zrilek, Wijono, cristi, sodapas
Threads: 274
Likes: 12,075 in 1,233 posts
03-28-2013, 07:29 AM
[-] The following 9 users Like pezhmankhan's post:9 users Like pezhmankhan's post
  β€’ oram, slowet, Dell_Brett, ykhackhack, lednar_ved, nickycruz, subin91, legarleon, pram
 structural
Singapore
User ID: 7169
Threads: 2
Likes: 28 in 9 posts
Given Likes: 45
06-01-2021, 11:39 AM (This post was last modified: 06-02-2021, 03:39 AM by Dell_Brett. Edit Reason: N/A )
Hi, anyone available to re-upload the files and share links? Thank you
MODERATOR NOTE:
MEDIAFIRE link in post #6 still working!
[-] The following 2 users Like structural's post:2 users Like structural's post
  β€’ juangpulidoc, sodapas
  Foundation: Combined Trapezoidal Footing Design by JEC robertsas 2 9,125 03-26-2014, 10:39 AM
  Foundation: Combined Rectangular Footing Design by JEC robertsas 2 9,288 03-26-2014, 10:37 AM
  Pole Foundation Analysis usman 1 9,954 03-15-2012, 03:44 PM
Last Post: Diquan
