Civil Engineering Association eBooks Structural Books Steel SCI: Wind Moment Design of Low Rise Frames
 gboyega
User ID: 2845
Threads: 33
Likes: 711 in 38 posts
Given Likes: 27
11-21-2009, 08:53 AM (This post was last modified: 04-04-2012, 12:06 PM by oanm2000.)
[Image: 75275724084932426532_thumb.jpg]
This publication presents procedures for the design of wind-moment frames in accordance with BS 5950-1. In this method of design, the frame is made statically determinate by treating the connections as pinned under vertical loads and fixed under horizontal loads (with certain assumed points of zero moment). The publication gives design procedures for frames that are braced in the minor axis direction and for frames that do not have bracing in either principal direction.
The limitations of the method, which differ slightly for these two cases, are explained. In particular, it should be noted that the method is only recommended for low-rise frames up to four storeys high.
In addition to design procedures for the ultimate and serviceability limit states, fully worked design examples are presented for two cases. The publication also reproduces the resistance tables for standard wind-moment connections taken from SCI/BCSA publication P207 Joints in steel construction: Moment connections.
These connections use flush or extended end plates and grade 8.8 M20 or M24 bolts, and achieve sufficient rotation capacity by ensuring that the moment resistance is not governed by bolt or weld failure.
[-] The following 18 users Like gboyega's post:18 users Like gboyega's post
  • kowheng, Dell_Brett, robertsas, chenamoy, vvvv, baikur, levanduy, zrilek, cristi, joannaking, subin91, boycv, dovsky, simanta, eng donny, oanm2000, SCREAM7890, sheb101
 eng donny
Indonesia
User ID: 765
Threads: 14
Likes: 1,976 in 236 posts
Given Likes: 905
04-04-2012, 08:37 AM
[-] The following 3 users Like eng donny's post:3 users Like eng donny's post
  • Dell_Brett, oanm2000, SCREAM7890
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
04-04-2012, 09:48 AM
Mirrors:
[-] The following 9 users Like ssobhan's post:9 users Like ssobhan's post
  • oanm2000, slowet, SCREAM7890, Jackass, gulilero, malc, Dell_Brett, cristi, andersen3
  Plastic design of low-rise frames malc 0 1,696 10-06-2020, 03:46 AM
Last Post: malc
  Moment Resistant Connections of Steel Frames in Seismic Areas: Design and Reliability Grunf 4 5,433 09-07-2014, 09:44 PM
Last Post: apocalipse
  SCI P264: Wind-moment Design of Unbraced Composite Frames ir_71 2 2,700 11-18-2013, 06:24 AM
  Low Rise Office Building Design - by E Chien, P.Eng usman 1 3,530 03-09-2012, 01:23 PM
  Steel Building Design: Medium Rise Braced Frames ir_71 2 3,302 01-28-2012, 08:52 PM
Last Post: joker™
  SCI: Wind-moment design for unbraced steel frames ebcivilea 1 2,762 06-12-2011, 01:18 PM
Last Post: Dell_Brett
