Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) [CivilEA Exclusive] BS EN 1993-1-8 Eurocode 3. Design of steel structures - Joints
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
02-04-2025, 12:42 PM
BS EN 1993-1-8:2024 Eurocode 3. Design of steel structures - Joints
| Size: 18.43 MB| Format: PDF| Quality: Scanner| Year: 2024 | ISBN: 9780539317121
[Image: 40704811184199286036.jpg]
(1) EN 1993‑1‑8 provides rules for structural design of joints subject to predominantly static loading using all steel grades from S235 up to and including S700, unless otherwise stated in individual clauses.
NOTE As an alternative to the design rules provided in Clause 9, the design rules given in CEN/TS 1993‑1‑8011 “Eurocode 3: Design of steel structures — Part 1-801: Hollow section joints design according to the component method” can be used.
(2) The provisions in this document apply to steels complying with the requirements given in EN 1993‑1‑1 and to material thickness greater than or equal to 3 mm, unless otherwise stated in individual clauses.
  • zrilek, babakfeyzi, lisine, Dell_Brett, heogay43
  BS EN 1992-1-2: Eurocode 2. Design of concrete structures-Structural fire design poolmand 0 3,445 01-14-2024, 10:04 AM
  BS EN 1992-1-1: Eurocode 2. Design of concrete structures. General rules and rules f poolmand 0 3,113 01-14-2024, 10:00 AM
  EN 26891 - Timber structures. Joints made with mechanical fasteners ir_71 1 1,938 07-01-2021, 08:41 AM
Last Post: zrilek
  BS 6093 - Design of Joints dinu69in 3 3,837 11-28-2019, 10:54 AM
  BS 7608:1993 Code of practice for fatigue design and assessment of steel structures ir_71 5 5,063 12-15-2015, 09:46 AM
Last Post: Dobblo
  BS EN ISO 5817:2007 Welding. Fusion-welded joints in steel, nickel, titanium and thei mybest 1 3,386 02-21-2013, 01:54 PM
Last Post: arshiakh
  BS EN 10034:1993 Structural steel I and H sections - Tolerances on shape and dimensio ir_71 1 3,418 02-14-2013, 11:02 AM
