Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) ISO 22762-1: Elastomeric seismic-protection isolators Part 1: Test methods
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
11-16-2024, 01:18 PM
ISO 22762-1:2024 Elastomeric seismic-protection isolators Part 1: Test methods
| Size: 21.7 MB| Format: PDF| Quality: Scanner| Year: 2024-09| pages: 77
[Image: 29159175115698358063.jpg]
This document specifies the test methods for determination of
a) the properties of the rubber material used to manufacture the elastomeric isolators, and
b) the characteristics of elastomeric isolators.
It is applicable to elastomeric isolators used to provide buildings or bridges with protection from earthquake damage. The elastomeric isolators covered consist of alternate elastomeric layers and reinforcing steel plates which are placed between a superstructure and its substructure to provide both flexibility for decoupling structural systems from ground motion, and damping capability to reduce displacement at the isolation interface and the transmission of energy from the ground into the structure at the isolation frequency.
  â€¢ babakfeyzi, Dell_Brett, ziggywas1
  ISO/TR 22762-7: Elastomeric seismic-protection isolators Part 7: Relationship of the poolmand 0 2,935 11-17-2024, 06:52 AM
  ISO 22762-6: Elastomeric seismic-protection isolators Part 6: High-durability and hig poolmand 0 2,847 11-17-2024, 06:50 AM
  ISO 22762-5: Elastomeric seismic-protection isolators Part 5: Sliding seismic-protect poolmand 0 2,875 11-17-2024, 06:47 AM
  ISO/TS 22762-4: Elastomeric seismic-protection isolators Part 4: Guidance on the appl poolmand 0 2,907 11-17-2024, 06:44 AM
  ISO 22762-3: Elastomeric seismic-protection isolators Part 3: Applications for buildi poolmand 0 2,912 11-16-2024, 01:25 PM
  ISO 22762-2: Elastomeric seismic-protection isolators Part 2: Applications for bridge poolmand 0 3,015 11-16-2024, 01:21 PM
  BS EN 1340/AC:2006 Concrete kerb units - Requirements and test methods ir_71 2 3,134 07-22-2017, 07:41 AM
