CSA S347:14 (R2023) Method of test for evaluation of truss plates used in lumber joints
| Size: 6.62 MB| Format: PDF| Quality: Scanner| Publisher: CSA Group| Year: 2014 (R2023)| pages: 31
![[Image: 86011313649517873928.jpg]](https://pic.civilea.com/images/86011313649517873928.jpg)
This is the fourth edition of CSA S347, Method of test for evaluation of truss plates used in lumber joints. It supersedes previous editions published in 1980, 1976, and 1999.
The major changes in this addition include the following:
a) change from basic relative density to oven-dry relative density;
b) introduction of test requirements for machine stress rated lumber, machine evaluated lumber and structural composite lumber;
c) introduction of additional tests for roller press embedment of truss plates; and
d) updating of calculations and reporting to suit changes in truss plate analysis requirements in CSA O86.
The plate and teeth resistance and the teeth lateral slip resistance, determined in accordance with this Standard, provide the basis for the truss plate connection design and design values set forth in CSA O86, Engineering design in wood.
This Standard was prepared by the Technical Committee on Engineering Design in Wood under the jurisdiction of the Strategic Steering Committee on Buildings and Civil Infrastructure and was formally approved by the Technical Committee.
This Standard has been developed in compliance with Standards Council of Canada requirements for National Standards of Canada. It has been published as a National Standard of Canada by CSA Group.
