Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] Evaluation of bolted CHS flange-plate connections under axial tension
[Request] Evaluation of bolted CHS flange-plate connections under axial tension
 civilfafa
Iraq
User ID: 174183
Threads: 50
Likes: 305 in 51 posts
Given Likes: 459
06-29-2024, 03:35 AM
Hi There,
It is appreciated if someone could share the following paper:
Thanks.
Title of paper: Evaluation of bolted CHS flange-plate connections under axial tension
Journal: Journal of Constructional Steel Research
Authors: Augusto FidalgoJeffrey A. PackerORCID ID
Source Information Volume 196, September 2022, 107399
DOI URI :
  â€¢
 lisine
Vanuatu
User ID: 17927
Threads: 265
Likes: 11,713 in 1,307 posts
Given Likes: 4631
07-08-2024, 10:58 AM
[-] The following 4 users Like lisine's post:4 users Like lisine's post
  â€¢ civilfafa, babakfeyzi, tomtumx, zrilek
  [REQUEST] ASCE Paper (Ultimate Capacity of Single Bolted Angel Connections) civilfafa 0 711 07-27-2026, 06:34 AM
Last Post: civilfafa
  [REQUEST] Bolted end-plate tube connections subject to tension and bending civilfafa 1 3,407 07-08-2024, 11:03 AM
  [REQUEST] Column Axial Load Effects on Performance of Panel Zone in Welded-Flange-Plate Connect ssobhan 1 2,011 10-17-2015, 08:49 PM
Last Post: Mohammad6299
