Civil Engineering Association eBooks Codes, Manual & Handbook ISO ISO 16834: Welding consumables Wire electrodes, wires, rods and deposits for gas shie
Threads: 750
Likes: 8,270 in 1,355 posts
Given Likes: 88
02-03-2024, 10:45 AM
ISO 16834:2012 Welding consumables Wire electrodes, wires, rods and deposits for gas shielded arc welding of high strength steels
| Size: 5.57 MB| Format: PDF| Quality: Scanner| Year: 2012| pages: 14
[Image: 90927523954944581636.jpg]
ISO 16834:2012 specifies requirements for classification of wire electrodes, wires, rods and all-weld metal deposits in the as-welded condition and in the post-weld heat-treated (PWHT) condition for gas shielded metal arc welding and tungsten inert-gas welding of high-strength steels with a minimum yield strength greater than 500 MPa, or a minimum tensile strength greater than 570 MPa. One wire electrode can be tested and classified with different shielding gases.
ISO 16834:2012 is a combined specification providing for classification utilizing a system based upon the yield strength and the average impact energy of 47 J of all-weld metal, or utilizing a system based upon the tensile strength and the average impact energy of 27 J of all-weld metal.
  • jcbv, babakfeyzi, PinkPant, kowheng
