Civil Engineering Association eBooks Codes, Manual & Handbook AWWA AWWA B306: Aqua Ammonia (Liquid Ammonium Hydroxide)
Threads: 750
Likes: 8,270 in 1,355 posts
Given Likes: 88
01-16-2024, 08:15 AM
AWWA B306-22 Aqua Ammonia (Liquid Ammonium Hydroxide)
| Format: PDF| Quality: Scanner| Year: 2022 | ISBN: 9781647171308
[Image: 68257845799920991671.jpg]
The purpose of this standard is to provide the minimum requirements for aqua ammonia, including physical, chemical, sampling, packaging, shipping, and testing requirements.
This standard describes aqua ammonia (liquid ammonium hydroxide) for use in the treatment of potable water, wastewater, or reclaimed water. It can be referenced in documents for purchasing and receiving aqua ammonia and can be used as a guide for testing the physical and chemical properties of aqua ammonia samples. The stipulations of this standard apply when this document has been referenced and then only to aqua ammonia used in the treatment of potable water, wastewater, or reclaimed water.
  • babakfeyzi, PinkPant, rami1976
  AWWA B408 LIQUID POLYALUMINUM CHLORIDE poolmand 0 2,989 01-20-2024, 11:56 AM
  AWWA B407 LIQUID FERRIC CHLORIDE poolmand 0 2,894 01-20-2024, 11:54 AM
  AWWA B404 LIQUID SODIUM SILICATE poolmand 0 2,812 01-20-2024, 11:46 AM
  AWWA B403 ALUMINUM SULFATE — LIQUID, GROUND, OR LUMP poolmand 0 2,875 01-20-2024, 11:44 AM
  AWWA B305: Anhydrous Ammonia poolmand 0 2,814 01-16-2024, 08:12 AM
  AWWA B304: Liquid Oxygen for Ozone Generation for Water, Wastewater, and Reclaimed W poolmand 0 2,969 01-16-2024, 08:10 AM
  AWWA B302: Ammonium Sulfate poolmand 0 2,871 01-16-2024, 08:04 AM
