Civil Engineering Association eBooks Codes, Manual & Handbook AWWA AWWA B114: Reverse Osmosis and Nanofiltration Systems for Water Treatment
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
01-15-2024, 12:28 PM
AWWA B114-22 Reverse Osmosis and Nanofiltration Systems for Water Treatment
| Size: 9.55 MB| Format: PDF| Quality: Scanner| Year: 2022 | ISBN: 9781647170912
[Image: 06762383245545591720.jpg]
This standard delineates minimum requirements for reverse osmosis (RO) and nanofiltration (NF) membrane systems for water and reclaimed water treatment systems.
The purpose of this standard is to recommend a minimum set of requirements for RO and NF membrane systems used for water and reclaimed water treatment systems. This standard is intended to assist with the design, procurement, installation, and commissioning of RO and NF membrane systems. This standard can be referenced for design, procurement, installation, commissioning, demonstration testing and performance testing of RO and NF membrane systems used for water purification and reclaimed water treatment systems.
  β€’ PinkPant, babakfeyzi
  AWWA B304: Liquid Oxygen for Ozone Generation for Water, Wastewater, and Reclaimed W poolmand 0 3,117 01-16-2024, 08:10 AM
  AWWA B130: Membrane Bioreactor Systems poolmand 0 1,417 01-15-2024, 12:33 PM
  AWWA B116: Electrodialysis and Ion-Exchange Membrane Systems poolmand 0 1,490 01-15-2024, 12:30 PM
  AWWA B112: Microfiltration and Ultrafiltration Membrane Systems poolmand 0 1,371 01-15-2024, 12:22 PM
  AWWA A100: Water Wells poolmand 0 1,656 01-15-2024, 11:44 AM
  AWWA C602: Cement-Mortar Lining of Water Pipelines in Placeβ€”4 In. (100 mm) and Larger poolmand 0 1,424 01-15-2024, 10:34 AM
  AWWA D103 Factory-Coated Bolted Steel Tanks for Water Stor ir_71 2 4,428 09-04-2019, 08:45 AM
Last Post: pedzaquino
