Civil Engineering Association eBooks Structural Books Concrete Guide Specifications for the Design of Concrete Bridge Beams Prestressed with Carbon
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
08-30-2023, 06:18 AM (This post was last modified: 08-30-2023, 08:58 AM by Administrator. Edit Reason: N/A )
Guide Specifications for the Design of Concrete Bridge Beams Prestressed with Carbon Fiber-Reinforced Polymer (CFRP) Systems, 1st Edition
| Size: 7.57 MB| Format: PDF| Quality: Scanner| Publisher: AASHTO| Year: 2018| pages: 70 | ISBN: 9781560517160
[Image: 60607659340400341702.jpg]
These guide specifications apply to the design of prestressed concrete beams constructed of normal weight concrete and prestressed by carbon fiber-reinforced polymer (CFRP) prestressing systems. Unless otherwise specifically noted, these guide specifications are applicable to: concrete components made of concrete with compressive strengths used for design from 5.0 to15.0 ksi, inclusive; pretensioned concrete beams; bonded and unbonded internally post-tensioned concrete beams; andΒ  shear design of prestressed concrete bridge beams with only transverse steel reinforcement.
  β€’ milova, PinkPant, blaze, babakfeyzi, subin91, kowheng, zrilek, civilfafa, Kerry3
 whysx
User ID: 2025
Threads: 22
Likes: 22 in 11 posts
Given Likes: 0
08-30-2023, 08:47 AM
The key you provided for file access was invalid. This is usually caused because the file is no longer stored on MediaFire. This occurs when the file is removed by the originating user or MediaFire.
  β€’
Threads: 758
Given Likes: 91
08-30-2023, 08:59 AM
try it now
  β€’
  An Introduction to Prestressed Concrete usman 4 6,194 08-10-2024, 06:08 AM
  Reinforced and prestressed Concrete Design to EC2 - The complete Process gianniorlati 3 3,542 12-20-2022, 08:37 AM
Last Post: Dell_Brett
  Analysis and Design of Prestressed Concrete carolinandra 0 1,881 09-24-2022, 03:53 PM
Last Post: carolinandra
  PRESTRESSED CONCRETE. 5ED carolinandra 0 1,829 06-28-2022, 12:38 PM
  CPCI: Canadian Precast & Prestressed Concrete Institue - Design Manual 4 rohailiyaz 6 5,435 06-23-2022, 04:40 AM
Last Post: sandeepb
  Reinforcement Detailing Handbook for Reinforced and Prestressed Concrete carolinandra 0 1,851 01-29-2022, 08:01 PM
  Design of prestressed Concrete flat slabs tuanpecc1 5 5,360 12-09-2021, 07:59 AM
Last Post: Gabemzaman
