Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS C3.11M/C3.11: Specification for Torch Soldering
Likes: 8,312 in 1,373 posts
Given Likes: 94
08-27-2023, 09:02 AM
AWS C3.11M/C3.11-2011: Specification for Torch Soldering
| Size: 4.33 MB| Format: PDF| Quality: Scanner| Publisher: American Welding Society, Inc. (AWS) | Year: 1st Edition, 2011| pages: 30
[Image: 91632836474478972335.png]
AWS C3.11M/C3.11, 1st Edition, 2011 - Specification for Torch Soldering
This specification presents the minimum process and quality requirements for the torch soldering of ceramics, precious metals, and refractory metals, as well as the alloys of copper (Cu), iron (Fe), nickel (Ni), aluminum (Al), magnesium (Mg), tin (Sn), lead (Pb), and zinc (Zn).
The purpose of this specification is to standardize torch soldering process requirements that will ensure that soldered joints attain the quality level designated by the application. This document establishes the minimum requirements for processes using a minimum amount of explanatory information so as to limit any ambiguity. This document assigns responsibility for soldered joint quality to the Organization Having Quality Responsibility and permits that organization to modify requirements as necessary. However, this specification requires that proper documentation be developed and archived by that organization, which explains the basis and specific details of any such modifications.
  â€¢ babakfeyzi, kowheng, PinkPant
Given Likes: 94
05-29-2024, 11:05 AM
AWS C3.11M/C3.11-2024: Specification for Torch Soldering
| Format: PDF
[Image: 05582413898939251861.jpg]
This post has been made by CivilEA Post-Generator V2.4.3
  â€¢ babakfeyzi, PinkPant
  AWS C4.3/C4.3M: Recommended Practices for Oxyfuel Gas Heating Torch Operation poolmand 0 1,502 08-30-2023, 08:25 AM
  AWS C4.2/C4.2M: Recommended Practices for Oxyfuel Gas Cutting Torch Operation poolmand 0 1,528 08-30-2023, 08:22 AM
  [CivilEA Exclusive] AWS GHSP Guideline for Hand Soldering Practices poolmand 0 1,541 08-27-2023, 09:21 AM
  [CivilEA Exclusive] AWS SHB: Soldering Handbook poolmand 0 1,647 08-27-2023, 09:17 AM
  AWS C3.12M/C3.12: Specification for Furnace Soldering poolmand 0 1,584 08-27-2023, 09:05 AM
  AWS C3.4M/C3.4: Specification for Torch Brazing poolmand 0 1,800 08-27-2023, 08:42 AM
  [CivilEA Exclusive] AWS B2.3/B2.3M: SPECIFICATION FOR SOLDERING PROCEDURE AND PERFORMANCE QUALIFICAT poolmand 0 1,607 08-19-2023, 12:01 PM
