Civil Engineering Association CivilEA Shop Own-Copyrighted Material [CivilEA SHOP] AISC Standards, Design Guides, Examples, Manuals, FAQs & ...
Thread Closed
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
02-21-2019, 08:22 PM (This post was last modified: 09-07-2026, 06:41 AM by Administrator.)
Interactive AISC Standards, Design Guides, Examples, Manuals, FAQs & ...
This file includes all AISC Standards, Design Guides, Examples, Manuals, FAQs, Books, Manual Tables & Seismic Design Manuals.
A complete series of AISC standards, Design guides are also the latest and the complete ones and also for other files
Finally, if you find any specific AISC standard or file that you may need to be added to this program, please mention that below to add it to this program.
Hope it can be useful for structural designers and students.
Last Update: 2022/01/23
AISC Manuals
  • AISC-LOAD AND RESISTANCE FACTOR DESIGN SPECIFICATION 1999‬
  • AISC-Manual Of Steel Construction - ASD - 1989
  • AISC-Manual Of Steel Construction-LRFD - 1994
  • AISC-Steel Construction Manual - 13th edition - LRFD&ASD - 2005
  • AISC-Steel Construction Manual - 14th edition
  • AISC-Steel Construction Manual - 15th edition
  • Manual of Steel Construction, 3rd Edition, Correction
AISC-Seismic Design Manual
  • AISC - Seismic Design Manual - 2005
  • AISC - Seismic Design Manual - 2012
  • AISC - Seismic Design Manual - 2018
Design Examples
  • AISC-Design Examples-Ver13.1
  • AISC-Design Examples-Ver14.0
  • AISC-Design Examples-Ver15.0
  • AISC-Design Examples-Ver15.1
Design Guides
  • Design Guide 1: Column Base Plates, 2nd Edition
  • Design Guide 2: Design of Steel, Composite Beams with Web Openings
  • Design Guide 3: Serviceability Design for Low-Rise Buildings, 2nd Edition
  • Design Guide 4: Extended End-Plate Moment Connections, 2nd Edition
  • Design Guide 5: Design of Low- and Medium-Rise Steel Buildings
  • Design Guide 6: LRFD of W-Shapes Encased in Concrete
  • Design Guide 7: Industrial Buildings: Roofs to Column Anchorage, 3rd Edition
  • Design Guide 8: Partially Restrained Composite Connections
  • Design Guide 9: Torsional Analysis of Structural Steel Members
  • Design Guide 10: Erection Bracing of Low-Rise Structural Steel Frames, 2nd Edition
  • Design Guide 11: Floor Vibrations Due To Human Activity, 2nd Edition
  • Design Guide 12: Modification of Existing Steel Welded Moment Frame
  • Design Guide 13: Wide-Flange Column Stiffening at Moment Connections
  • Design Guide 14: Staggered Truss Framing Systems
  • Design Guide 15: AISC Rehabilitation and Retrofit Guide, 2nd Edition
  • Design Guide 16: Flush, Extended Multiple-Row Moment Connections
  • Design Guide 17: High Strength Bolts--A Primer for Structural Engineers
  • Design Guide 18: Steel-Framed Open-Deck Parking Structures
  • Design Guide 19: Fire Resistance of Structural Steel Framing
  • Design Guide 21: Welded Connections - A Primer for Engineers, 2nd Edition
  • Design Guide 22: Facade Attachments To Steel Framed Buildings
  • Design Guide 23: Constructability of Structural Steel Buildings
  • Design Guide 24 - Hollow Structural Section Connections
  • Design Guide 25: Frame Design Using Web-Tapered Members - 2nd Edition
  • Design Guide 26: Design of Blast Resistant Structures
  • Design Guide 27: Structural Stainless Steel
  • Design Guide 28: Stability Design of Steel Buildings
  • Design Guide 29: Vertical Bracing Connections--Analysis  and Design
  • Design Guide 30: Sound Isolation and Noise Control in Steel Buildings
  • Design Guide 31: Castellated and Cellular Beam Design
  • Design Guide 32: Design of Modular Steel-Plate Composite Walls for Safety-Related Nuclear Facilities
  • Design Guide 33: Curved Member Design
  • Design Guide 34: Steel-Framed Stairway Design
  • Design Guide 35: Steel-Framed Storm Shelters
  • Design Guide 36: Design Considerations for Camber
FAQs
Manual Tables
  • AISC-13th Manual Tables
Miscellaneous Books by AISC
  • ‪AISC Load and Resistance Factor Design Specification for Single-Angle Members‬
  • AISC Seismic Design Module1 -Introduction
  • AISC Seismic Design Module2 -Moment Resisting Frames
  • AISC Seismic Design Module3 -Concentrically Braced Frames
  • AISC Seismic Design Module4 -Eccentrically Braced Frames
  • AISC Seismic Design Module5 -Buckling Restrained Braced Frames
  • AISC Seismic Design Module6- Special Plate Shear Walls
  • Connections Teaching Toolkit
  • Construction Management of Steel Construction
  • Detailing for Steel Construction, 3rd Ed. (Digital)
  • Efficient Analysis For Steel Design Using The 2005 AISC Specification
  • Facts For Steel Buildings 3- Earthquake and Seismic Design
  • Facts For Steel Buildings 2- blast and progressive collapse
  • Geometric Formulas for Gusset Plate Design Chambers Bartley AISC
  • RCSC 2021
  • Seismic Braced Frames - Design Concept and Connections
Standards
  • AISC 205-11 - standard for steel bridges
  • AISC 207-20 - Standard for Certification Programs
  • AISC 303-10 - Code of Standard Practice for Steel Buildings and Bridges
  • AISC 303-16 - Code of Standard Practice for Steel Buildings and Bridges
  • AISC 341-05 - Seismic Provisions for Structural Steel Buildings
  • AISC 341-10 - Seismic Provisions for Structural Steel Buildings
  • AISC 341-16 - Seismic Provisions for Structural Steel Buildings
  • AISC 341-22 (Draft) - Seismic Provisions for Structural Steel Buildings
  • AISC 342-22 (Draft) - Seismic Provisions for Evaluation and Retrofit of Existing Structural Steel Buildings
  • AISC 358-05 - Prequalified Connections for Special and Intermediate Steel Moment Frames for Seismic Applications
  • AISC 358-10 - Prequalified Connections for Special and Intermediate Steel Moment Frames for Seismic Applications
  • AISC 358-16 - Prequalified Connections for Special and Intermediate Steel Moment Frames for Seismic Applications
  • AISC 358-16-358S-18 - Prequalified Connections for Special and Intermediate Steel Moment Frames for Seismic Applications
  • AISC 358-22 (Draft) - Prequalified Connections for Special and Intermediate Steel Moment Frames for Seismic Applications
  • AISC 360-05 - Specification for Structural Steel Buildings
  • AISC 360-10 - Specification for Structural Steel Buildings
  • AISC 360-16 - Specification for Structural Steel Buildings
  • AISC 360-22 (Draft) - Specification for Structural Steel Buildings
  • AISC 420-10 SSPC-QP 3-standard-for-shop-application-of-complex-protective
  • AISC A370-21 SPECIFICATION FOR STRUCTURAL STAINLESS STEEL BUILDINGS
  • ANSI-AISC N690-18 - Specification for Safety-Related Steel Structures for Nuclear Facilities
**** SPECIAL OFFER / LIMITED TIME (ORIGINAL PRICE IS 60 USD) ****
Cost: 18 USD
#10
Guests Can Not Buy Paid Contents. Please Login or Register to Buy Paid Contents.
[-] The following 18 users Like poolmand's post:18 users Like poolmand's post
  • Rainbow, amareen2000, Umer.Aleem, davegabj, jaks, drewpt, engart, KMABD, caifan, GeorgeS, abhijit, NAUTILUS87, nhim4mat2006, nibbi, aalbujae, alcalan57, kowheng, jonygut
Threads: 758
Given Likes: 91
01-23-2022, 08:50 AM
Post #1 was updated and all books and standards were updated to latest edition up to now (2022/01/23), also many books and standards were added to package.
  • Dell_Brett, carolinandra, kowheng, CAMSECT, jonygut
Threads: 758
Given Likes: 91
12-15-2024, 12:04 PM (This post was last modified: 12-15-2024, 12:08 PM by poolmand.)
AISC Update 2024-12-15
  • AISC 205-11
  • AISC 207-23
  • AISC 303-22
  • AISC 313-21
  • AISC 327-2018_Seismic Design Manual
  • AISC 341-22
  • AISC 342-22
  • AISC 358-22
  • AISC 360-22
  • AISC 420-10_SSPC-QP 3
  • AISC A370-21
  • AISC Design Guide 1_Base_Connection_Design_for_Steel_Structures
  • AISC Design Guide 36_Design Considerations for Camber 2020
  • AISC Design Guide 37_Hybrid_Steel_Frames_with_Wood_Floors_Barber
  • AISC Design Guide 38_SpeedCore_Systems_for_Steel_Structures_2023
  • AISC Design Guide 39_END-PLATE MOMENT CONNECTIONS 2023
  • AISC Design Guide 40 Rain Loads and Ponding 2024
  • AISC Model Review and Approval for Structural Steel 2022
  • AISC_Steel_Construction_Manual_Volume_1_Design
  • AISC_Steel_Construction_Manual_Volume_2_Design
  • BIM & VDC for Structural Steel AISC 2019
  • Seismic Design Manual, 2nd Edition
