Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM Construction & Building Standards
 nibbi
User ID: 21150
Threads: 6
Likes: 464 in 21 posts
Given Likes: 182
02-02-2015, 02:27 PM
ASTM Construction & Building Standards - Part 1
Author: ASTM | Size: 34.4 MB | Format: PDF | Quality: Original preprint | Year: 2014
The following latest ASTM Standards are included, exclusively for the Forum Members
ASTM A6 Standard Specification for General Requirements for Rolled Structural Steel Bars, Plates, Shapes, and Sheet Piling
ASTM A29 Standard Specification for Steel Bars, Carbon and Alloy, Hot-Wrought, General Requirements for
ASTM A36 Standard Specification for Carbon Structural Steel
ASTM A53 Standard Specification for Pipe, Steel, Black and Hot-Dipped, Zinc-Coated, Welded and Seamless
ASTM A90 Standard Specification for Weight [Mass] of Coating on Iron and Steel Articles with Zinc of Zinc-Alloy Coatings
ASTM A105 Standard Specification for Forgings, Carbon Steel for Piping Components
ASTM A106 Standard Specification for Seamless Carbon Steel Pipe for High-Temperature Service
ASTM A123 Standard Specification for Zinc (Hot-Dip Galvanized) Coatings on Iron and Steel Products
ASTM A148 Standard Specification for Steel Castings, High Strength, for Structural Purposes
ASTM A153 Standard Specification for Zinc Coating (Hot-Dip) on Iron and Steel Hardware
ASTM A193/A193M Standard Specification for Alloy-Steel and Stainless Steel Bolting Materials for High-Temperature Service
ASTM A194/A194M Specification for Carbon and Alloy Steel Nuts for Bolts for High-Pressure or High-Temperature Service, or Both
ASTM A255 Standard Test Methods for Determining Hardenability of Steel (Includes JOMINY test)
ASTM A297 Standard Specification for Steel Castings, Iron-Chromium and Iron-Chromium-Nickel, Heat Resistant, for General Application
ASTM A307 Standard Specification for carbon steel bolts and studs ranging from 1/4" through 4" diameter.
ASTM A312 Specification for Seamless, Welded, and Heavily Cold Worked Austenitic Stainless Steel Pipes
TM A320/A320M Specification for Alloy/Steel Bolting Materials for Low-Temperature Service
ASTM A325M Standard Specification for Structural Bolts, Steel, Heat Treated 830 MPa Minimum Tensile Strength
ASTM A354 Standard Specification for Quenched and Tempered Alloy Steel Bolts, Studs, and Other Externally Threaded Fasteners
ASTM A370 Standard Testing Methods and Definitions for Mechanical Testing of Steel Products
ASTM A385 Standard Practice for Providing High-Quality Zinc Coatings (Hot Dip)
ASTM A490 Standard Specification for Structural Bolts, Alloy Steel, Heat Treated, 150 ksi Minimum Tensile Strength
ASTM A500 Standard Specification for Cold-Formed Welded and Seamless Carbon Steel Structural Tubing in Rounds and Shapes
ASTM A514 Standard Specification for High-Yield-Strength, Quenched and Tempered Alloy Steel Plate, Suitable for Welding
ASTM A529 Standard Specification for High-Strength Carbon-Maganese Steel of Structural Quality
ASTM A563 Standard Specification for Carbon and Alloy Steel Nuts
ASTM A564 Standard Specification for Hot-Rolled and Cold-Finished Age-Hardening Stainless Steel Bars and Shapes
ASTM A568 Standard Specification for Steel, Sheet, Carbon, Structural, and High-Strength, Low-Alloy, Hot-Rolled and Cold-Rolled, General Requirements for
ASTM A588 Standard Specification for High-Strength Low-Alloy Structural Steel, up to 50 ksi [345 MPa] Minimum Yield Point, with Atmospheric Corrosion Resistance
ASTM A615/615M Standard Specification for Deformed and Plain Carbon- Steel Bars for Concrete
ASTM A653 Standard Specification for Steel Sheet, Zinc-Coated (Galvanized) or Zinc-Iron Alloy-Coated (Galvannealed) by the Hot-Dip Process
ASTM A706 Standard Specification for Low-Alloy Steel Deformed and Plain Bars for Concrete Reinforcement
ASTM A759 Standard Specification for Carbon Steel Crane Rails
ASTM A780 Standard Specification for Repair of Damaged and Uncated Areas of Hot-Dip Galvanized Coatings
ASTM A786 Standard Specification for Hot-Rolled Carbon, Low-Alloy, High-Strength Low-Alloy, and Alloy Steel Floor Plates
ASTM A820 Standard Specification for Steel Fibers for Fiber-Reinforced Concrete
ASTM A962/A962M Specification for Common Requirements for Steel Fasteners or Fastener Materials, or Both, Intended for Use at Any Temperature from Cryogenic to the Creep Range
ASTM A992 Standard Specification for Structural Steel Shapes
ASTM A994 Standard Specification for General Requirements for Steel Sheet, Metallic-Coated by the Hot-Dip Process
ASTM A1008 Standard Specification for Structural Steel, Sheet, Cold-Rolled, Carbon, Structural, High-Strength Low-Alloy, High-Strength Low-Alloy with Improved Formability, Solution Hardened, and Bake Hardenable
ASTM A1011 Standard Specification for Structural Steel, Sheet and Strip, Hot-Rolled, Carbon, Structural, High-Strength Low-Alloy, High-Strength Low-Alloy with Improved Formability, and Ultra-High Strength
ASTM A1018 Standard Specification for Structural Steel, Sheet and Strip, Heavy-Thickness Coils, Hot-Rolled, Carbon, Commercial, Drawing, Structural, High-Strength Low-Alloy, High-Strength Low-Alloy with Improved Formability, and Ultra-High Strength
ASTM C 91 Cement Standards and Concrete Standards
ASTM C 150 Standard Specification for Portland Cement
ASTM C 876 Standard Test Method for Half-Cell Potential of uncoated reinforcing steel in concrete
ASTM C 813-90 Standard Test Method for Hydrophobic Contamination on Glass by Contact Angle Measurement
ASTM C 857-14 Standard Practice for Minimum Structural Design Loading for Underground Precast Concrete Utility Structures
ASTM C 1321 - 04 Standard Practice for Installation and Use of Interior Radiation Control Coating Systems (IRCCS) in Building Construction
ASTM C 1349 Standard Specification for Architectural Flat Glass Clad Polycarbonate
ASTM F432 Standard Specification for Roof and Rock Bolts and Accessories
ASTM F436 Standard Specification for Hardened Steel Washers
ASTM F 606 Test Methods for Determining the Mechanical Properties of Externally and Internally Threaded Fasteners, Washers, and Rivets
ASTM F 626 Standard Specification for Fence Fittings
ASTM E72 - 14a Standard Test Methods of Conducting Strength Tests of Panels for Building Construction
ASTM E73 - 13 Standard Practice for Static Load Testing of Truss Assemblies
ASTM E196 - 06(2012) Standard Practice for Gravity Load Testing of Floors and Low Slope Roofs
ASTM E455 - 11 Standard Method for Static Load Testing of Framed Floor or Roof Diaphragm Constructions for Buildings
ASTM E529 - 04(2011) Standard Guide for Conducting Flexural Tests on Beams and Girders for Building Construction
ASTM E564 - 06(2012) Standard Practice for Static Load Test for Shear Resistance of Framed Walls for Buildings
ASTM E575 - 05(2011) Standard Practice for Reporting Data from Structural Tests of Building Constructions, Elements, Connections, and Assemblies
ASTM E661 - 03(2009) Standard Test Method for Performance of Wood and Wood-Based Floor and Roof Sheathing Under Concentrated Static and Impact Loads
ASTM E695 - 03(2009) Standard Method for Measuring Relative Resistance of Wall, Floor, and Roof Construction to Impact Loading
ASTM E1803 - 14 Standard Test Methods for Determining Strength Capacities of Structural Insulated Panels
ASTM E2126 - 11 Standard Test Methods for Cyclic (Reversed) Load Test for Shear Resistance of Vertical Elements of the Lateral Force Resisting Systems for Buildings
ASTM E2127 - 01a(2007) Standard Methods of Static Load Test for Combined Tensile and Transverse Load Resistance of Paneled Wall Systems in Building Construction
ASTM E2322 - 03(2009) Standard Test Method for Conducting Traverse and Concentrated Load Tests on Panels used in Floor and Roof Construction
ASTM E1925 - 10 Specifiction for Engineering and Design Criteria for Rigid Wall Relocatable Structures
ASTM E1574 - 98(2014) Standard Test Method for Measurement of Sound in Residential Spaces
ASTM E2202 - 02(2009) Standard Practice for Measurement of Equipment-Generated Continuous Noise for Assessment of Health Hazards
ASTM E1825 - 06(2012) Standard Guide for Evaluation of Exterior Building Wall Materials, Products, and Systems
ASTM E2128 - 12 Standard Guide for Evaluating Water Leakage of Building Walls
ASTM E2266 - 11 Standard Guide for Design and Construction of Low-Rise Frame Building Wall Systems to Resist Water Intrusion
ASTM E2270 - 14 Standard Practice for Periodic Inspection of Building Facades for Unsafe Conditions
ASTM E2813 - 12 Standard Practice for Building Enclosure Commissioning
ASTM E2841 - 11 Standard Guide for Conducting Inspections of Building Facades for Unsafe Conditions
ASTM E2947 - 14 Standard Guide for Building Enclosure Commissioning
ASTM E894 - 88(2010) Standard Test Method for Anchorage of Permanent Metal Railing Systems and Rails for Buildings
ASTM E935 - 13e1 Standard Test Methods for Performance of Permanent Metal Railing Systems and Rails for Buildings
ASTM E1481 - 00a(2014)e1 Standard Terminology of Railing Systems and Rails for Buildings
ASTM E2751 / E2751M - 13 Standard Practice for Design and Performance of Supported Laminated Glass Walkways
ASTM E1233 / E1233M - 14 Standard Test Method for Structural Performance of Exterior Windows, Doors, Skylights, and Curtain Walls by Cyclic Air Pressure Differential
ASTM E1300 - 12ae1 Standard Practice for Determining Load Resistance of Glass in Buildings
ASTM E2112 - 07 Standard Practice for Installation of Exterior Windows, Doors and Skylights
ASTM E2461 - 12 Standard Practice for Determining the Thickness of Glass in Airport Traffic Control Tower Cabs
ASTM E154 / E154M - 08a(2013)e1 Standard Test Methods for Water Vapor Retarders Used in Contact with Earth Under Concrete Slabs, on Walls, or as Ground Cover
ASTM E605 - 93(2011) Standard Test Methods for Thickness and Density of Sprayed Fire-Resistive Material (SFRM) Applied to Structural Members
ASTM E736 - 00(2011) Standard Test Method for Cohesion/Adhesion of Sprayed Fire-Resistive Materials Applied to Structural Members
ASTM E1513 - 93(2011) Standard Practice for Application of Sprayed Fire-Resistive Materials (SFRMs)
ASTM E1643 - 11 Standard Practice for Selection, Design, Installation, and Inspection of Water Vapor Retarders Used in Contact with Earth or Granular Fill Under Concrete Slabs
ASTM E1745 - 11 Standard Specification for Plastic Water Vapor Retarders Used in Contact with Soil or Granular Fill under Concrete Slabs
ASTM E1993 / E1993M - 98(2013)e1 Standard Specification for Bituminous Water Vapor Retarders Used in Contact with Soil or Granular Fill Under Concrete Slabs
ASTM E756 - 05(2010) Standard Test Method for Measuring Vibration-Damping Properties of Materials
ASTM C834 - 14 Standard Specification for Latex Sealants
ASTM C920 - 14a Standard Specification for Elastomeric Joint Sealants
ASTM C1021 - 08(2014) Standard Practice for Laboratories Engaged in Testing of Building Sealants
ASTM C1184 - 14 Standard Specification for Structural Silicone Sealants
ASTM C1193 - 13 Standard Guide for Use of Joint Sealants
ASTM C1311 - 14 Standard Specification for Solvent Release Sealants
ASTM C1401 - 14 Standard Guide for Structural Sealant Glazing
ASTM E488 / E488M - 10 Standard Test Methods for Strength of Anchors in Concrete Elements
ASTM E754 - 80(2014)e1 Standard Test Method for Pullout Resistance of Ties and Anchors Embedded in Masonry Mortar Joints
ASTM E1190 - 11 Standard Test Methods for Strength of Power-Actuated Fasteners Installed in Structural Members
ASTM E1512 - 01(2007) Standard Test Methods for Testing Bond Performance of Bonded Anchors
ASTM E2265 - 09 Standard Terminology for Anchors and Fasteners in Concrete and Masonry
ASTM E631 - 06 Standard Terminology of Building Constructions
ASTM C717 - 14a Standard Terminology of Building Seals and Sealants
ASTM C1589 / C1589M - 14 Standard Practice for Outdoor Weathering of Construction Seals and Sealants
ASTM E2026 - 07 Standard Guide for Seismic Risk Assessment of Buildings
ASTM C226 - 12 Standard Specification for Air-Entraining Additions for Use in the Manufacture of Air-Entraining Hydraulic Cement
ASTM C185 - 08 Standard Test Method for Air Content of Hydraulic Cement Mortar
ASTM C233 / C233M - 14 Standard Test Method for Air-Entraining Admixtures for Concrete
ASTM C260 / C260M - 10a Standard Specification for Air-Entraining Admixtures for Concrete
ASTM C403 / C403M - 08 Standard Test Method for Time of Setting of Concrete Mixtures by Penetration Resistance
ASTM C494 / C494M - 13 Standard Specification for Chemical Admixtures for Concrete
ASTM C796 / C796M - 12 Standard Test Method for Foaming Agents for Use in Producing Cellular Concrete Using Preformed Foam
ASTM C869 / C869M - 11 Standard Specification for Foaming Agents Used in Making Preformed Foam for Cellular Concrete
ASTM C1017 / C1017M - 13 Standard Specification for Chemical Admixtures for Use in Producing Flowing Concrete
ASTM C1582 / C1582M - 11 Standard Specification for Admixtures to Inhibit Chloride-Induced Corrosion of Reinforcing Steel in Concrete
ASTM C1622 / C1622M - 10 Standard Specification for Cold-Weather Admixture Systems
ASTM C642 - 13 Standard Test Method for Density, Absorption, and Voids in Hardened Concrete
ASTM C1585 - 13 Standard Test Method for Measurement of Rate of Absorption of Water by Hydraulic-Cement Concretes
ASTM C183 - 13 Standard Practice for Sampling and the Amount of Testing of Hydraulic Cement
ASTM C778 - 13 Standard Specification for Standard Sand
ASTM C51 - 11 Standard Terminology Relating to Lime and Limestone (as used by the Industry)
ASTM C1077 - 14 Standard Practice for Agencies Testing Concrete and Concrete Aggregates for Use in Construction and Criteria for Testing Agency Evaluation
ASTM C1116 / C1116M - 10a Standard Specification for Fiber-Reinforced Concrete
ASTM C1399 / C1399M - 10 Standard Test Method for Obtaining Average Residual-Strength of Fiber-Reinforced Concrete
ASTM C1550 - 12a Standard Test Method for Flexural Toughness of Fiber Reinforced Concrete (Using Centrally Loaded Round Panel)
ASTM C1609 / C1609M - 12 Standard Test Method for Flexural Performance of Fiber-Reinforced Concrete (Using Beam With Third-Point Loading)
ASTM C115 / C115M - 10e1 Standard Test Method for Fineness of Portland Cement by the Turbidimeter
ASTM C188 - 14 Standard Test Method for Density of Hydraulic Cement
ASTM C204 - 11e1 Standard Test Methods for Fineness of Hydraulic Cement by Air-Permeability Apparatus
ASTM C430 - 08 Standard Test Method for Fineness of Hydraulic Cement by the 45-μm (No. 325) Sieve
ASTM C786 / C786M - 10 Standard Test Method for Fineness of Hydraulic Cement and Raw Materials by the 300-μm (No. 50), 150-μm (No. 100), and 75-μm (No. 200) Sieves by Wet Methods
ASTM C989 / C989M - 14 Standard Specification for Slag Cement for Use in Concrete and Mortars
ASTM C186 - 13 Standard Test Method for Heat of Hydration of Hydraulic Cement
ASTM C1702 - 14 Standard Test Method for Measurement of Heat of Hydration of Hydraulic Cementitious Materials Using Isothermal Conduction Calorimetry
ASTM C940 - 10a Standard Test Method for Expansion and Bleeding of Freshly Mixed Grouts for Preplaced-Aggregate Concrete in the Laboratory
ASTM C942 - 10 Standard Test Method for Compressive Strength of Grouts for Preplaced-Aggregate Concrete in the Laboratory
ASTM C943 - 10 Standard Practice for Making Test Cylinders and Prisms for Determining Strength and Density of Preplaced-Aggregate Concrete in the Laboratory
ASTM C10 / C10M - 14 Standard Specification for Natural Cement
ASTM C150 / C150M - 12 Standard Specification for Portland Cement
ASTM C595 / C595M - 14 Standard Specification for Blended Hydraulic Cements
ASTM C1157 / C1157M - 11 Standard Performance Specification for Hydraulic Cement
ASTM C330 / C330M - 14 Standard Specification for Lightweight Aggregates for Structural Concrete
ASTM C331 / C331M - 14 Standard Specification for Lightweight Aggregates for Concrete Masonry Units
ASTM C332 - 09 Standard Specification for Lightweight Aggregates for Insulating Concrete
ASTM C495 / C495M - 12 Standard Test Method for Compressive Strength of Lightweight Insulating Concrete
ASTM C567 / C567M - 14 Standard Test Method for Determining Density of Structural Lightweight Concrete
ASTM C91 / C91M - 12 Standard Specification for Masonry Cement
ASTM C1328 / C1328M - 12 Standard Specification for Plastic (Stucco) Cement
ASTM C1329 / C1329M - 12 Standard Specification for Mortar Cement
ASTM C171 - 07 Standard Specification for Sheet Materials for Curing Concrete
ASTM C309 - 11 Standard Specification for Liquid Membrane-Forming Compounds for Curing Concrete
ASTM C1315 - 11 Standard Specification for Liquid Membrane-Forming Compounds Having Special Properties for Curing and Sealing Concrete
ASTM C1084 - 10 Standard Test Method for Portland-Cement Content of Hardened Hydraulic-Cement Concrete
ASTM C803 / C803M - 03(2010) Standard Test Method for Penetration Resistance of Hardened Concrete
ASTM C805 / C805M - 13a Standard Test Method for Rebound Number of Hardened Concrete
ASTM C900 - 14 Standard Test Method for Pullout Strength of Hardened Concrete
ASTM C1074 - 11 Standard Practice for Estimating Concrete Strength by the Maturity Method
ASTM C29 / C29M - 09 Standard Test Method for Bulk Density ("Unit Weight") and Voids in Aggregate
ASTM C33 / C33M - 13 Standard Specification for Concrete Aggregates
ASTM C40 / C40M - 11 Standard Test Method for Organic Impurities in Fine Aggregates for Concrete
ASTM C70 - 13 Standard Test Method for Surface Moisture in Fine Aggregate
ASTM C87 / C87M - 10 Standard Test Method for Effect of Organic Impurities in Fine Aggregate on Strength of Mortar
ASTM C117 - 13 Standard Test Method for Materials Finer than 75-μm (No. 200) Sieve in Mineral Aggregates by Washing
ASTM C123 / C123M - 14 Standard Test Method for Lightweight Particles in Aggregate
ASTM C127 - 12 Standard Test Method for Density, Relative Density (Specific Gravity), and Absorption of Coarse Aggregate
ASTM C128 - 12 Standard Test Method for Density, Relative Density (Specific Gravity), and Absorption of Fine Aggregate
ASTM C131 / C131M - 14 Standard Test Method for Resistance to Degradation of Small-Size Coarse Aggregate by Abrasion and Impact in the Los Angeles Machine
ASTM C136 - 06 Standard Test Method for Sieve Analysis of Fine and Coarse Aggregates
ASTM C142 / C142M - 10 Standard Test Method for Clay Lumps and Friable Particles in Aggregates
ASTM C535 - 12 Standard Test Method for Resistance to Degradation of Large-Size Coarse Aggregate by Abrasion and Impact in the Los Angeles Machine
ASTM C566 - 13 Standard Test Method for Total Evaporable Moisture Content of Aggregate by Drying
ASTM C702 / C702M - 11 Standard Practice for Reducing Samples of Aggregate to Testing Size
ASTM C881 / C881M - 14 Standard Specification for Epoxy-Resin-Base Bonding Systems for Concrete
ASTM C882 / C882M - 13a Standard Test Method for Bond Strength of Epoxy-Resin Systems Used With Concrete By Slant Shear
ASTM C1059 / C1059M - 13 Standard Specification for Latex Agents for Bonding Fresh To Hardened Concrete
ASTM C1583 / C1583M - 13 Standard Test Method for Tensile Strength of Concrete Surfaces and the Bond Strength or Tensile Strength of Concrete Repair and Overlay Materials by Direct Tension (Pull-off Method)
ASTM C387 / C387M - 11b Standard Specification for Packaged, Dry, Combined Materials for Concrete and High Strength Mortar
ASTM C928 / C928M - 13 Standard Specification for Packaged, Dry, Rapid-Hardening Cementitious Materials for Concrete Repairs
ASTM C1107 / C1107M - 14 Standard Specification for Packaged Dry, Hydraulic-Cement Grout (Nonshrink)
ASTM C1708 / C1708M - 13 Standard Test Methods for Self-leveling Mortars Containing Hydraulic Cements
ASTM C1688 / C1688M - 14a Standard Test Method for Density and Void Content of Freshly Mixed Pervious Concrete
ASTM C1701 / C1701M - 09 Standard Test Method for Infiltration Rate of In Place Pervious Concrete
ASTM C1747 / C1747M - 13 Standard Test Method for Determining Potential Resistance to Degradation of Pervious Concrete by Impact and Abrasion
ASTM C1754 / C1754M - 12 Standard Test Method for Density and Void Content of Hardened Pervious Concrete
ASTM C294 - 12 Standard Descriptive Nomenclature for Constituents of Concrete Aggregates
ASTM C823 / C823M - 12 Standard Practice for Examination and Sampling of Hardened Concrete in Constructions
ASTM C110 - 14 Standard Test Methods for Physical Testing of Quicklime, Hydrated Lime, and Limestone
[-] The following 56 users Like nibbi's post:56 users Like nibbi's post
  • RyanRS, PinkPant, dgw7245, subin91, blaze, dinu69in, aslam, isurya, bridgeengineer, junaid, inge911, usman, Dell_Brett, ALMF, malc, Jackass, tomtumx, shaker, ykhackhack, cace-01, ting tsai huang, carolinandra, emmaoyen, ronnie_150, Hengki, peixoto, araza023, jcbv, agarciam2, concreteok, viet2010, tumangik, zrilek, pezhmankhan, pingfan2, ascetic19, vvvv, daywalker, bigone, eliseo.as, ir_71, yalham2000, f_slikken, abualamal, ashcivilea, hodzicemir, pram, hamex, amrzaki200, simanta, sodapas, amareen2000, scorpion07, Wijono, Yasir, tuanpecc1
 nibbi
User ID: 21150
Threads: 6
Given Likes: 182
02-03-2015, 04:06 PM
ASTM Building & Construction Standards - Part 2
Size: 13.66 MB | Format: PDF | Quality: Original preprint | Publisher: ASTM | Year: 2014-15
ASTM C1438 – 13 Standard Specification for Latex and Powder Polymer Modifiers for use in Hydraulic Cement Concrete and Mortar
ASTM C1439 – 13 Standard Test Methods for Evaluating Latex and Powder Polymer Modifiers for use in Hydraulic Cement Concrete and Mortar
ASTM C94 / C94M - 14b Standard Specification for Ready-Mixed Concrete
ASTM C685 / C685M – 11 Standard Specification for Concrete Made by Volumetric Batching and Continuous Mixing
ASTM C1602 / C1602M – 12 Standard Specification for Mixing Water Used in the Production of Hydraulic Cement Concrete
ASTM C1603 – 10 Standard Test Method for Measurement of Solids in Water
ASTM C666 / C666M - 03(2008) Standard Test Method for Resistance of Concrete to Rapid Freezing and Thawing
ASTM C672 / C672M – 12 Standard Test Method for Scaling Resistance of Concrete Surfaces Exposed to Deicing Chemicals
ASTM C1646 / C1646M - 08a Standard Practice for Making and Curing Test Specimens for Evaluating Resistance of Coarse Aggregate to Freezing and Thawing in Air-Entrained Concrete
ASTM C1778 – 14 Standard Guide for Reducing the Risk of Deleterious Alkali-Aggregate Reaction in Concrete
ASTM C1040 / C1040M - 08(2013) Standard Test Methods for In-Place Density of Unhardened and Hardened Concrete, Including Roller Compacted Concrete, By Nuclear Methods
ASTM C1170 / C1170M - 14e1 Standard Test Method for Determining Consistency and Density of Roller-Compacted Concrete Using a Vibrating Table
ASTM C1176 / C1176M – 13 Standard Practice for Making Roller-Compacted Concrete in Cylinder Molds Using a Vibrating Table
ASTM C1245 / C1245M – 12 Standard Test Method for Determining Relative Bond Strength Between Hardened Roller Compacted Concrete Lifts (Point Load Test)
ASTM C1435 / C1435M – 14 Standard Practice for Molding Roller-Compacted Concrete in Cylinder Molds Using a Vibrating Hammer
ASTM C1610 / C1610M – 14 Standard Test Method for Static Segregation of Self-Consolidating Concrete Using Column Technique
ASTM C1611 / C1611M – 14 Standard Test Method for Slump Flow of Self-Consolidating Concrete
ASTM C1621 / C1621M – 14 Standard Test Method for Passing Ability of Self-Consolidating Concrete by J-Ring
ASTM C1712 – 14 Standard Test Method for Rapid Assessment of Static Segregation Resistance of Self-Consolidating Concrete Using Penetration Test
ASTM C1758 / C1758M – 13 Standard Practice for Fabricating Test Specimens with Self-Consolidating Concrete
ASTM C1140 / C1140M – 11 Standard Practice for Preparing and Testing Specimens from Shotcrete Test Panels
ASTM C1141 / C1141M – 08 Standard Specification for Admixtures for Shotcrete
ASTM C1385 / C1385M – 10 Standard Practice for Sampling Materials for Shotcrete
ASTM C1436 – 13 Standard Specification for Materials for Shotcrete
ASTM C1480 / C1480M - 07(2012) Standard Specification for Packaged, Pre-Blended, Dry, Combined Materials for Use in Wet or Dry Shotcrete Application
ASTM C1604 / C1604M - 05(2012) Standard Test Method for Obtaining and Testing Drilled Cores of Shotcrete
ASTM C806 – 12 Standard Test Method for Restrained Expansion of Expansive Cement Mortar
ASTM C845 / C845M – 12 Standard Specification for Expansive Hydraulic Cement
ASTM C1600 / C1600M – 11 Standard Specification for Rapid Hardening Hydraulic Cement
ASTM C5 – 10 Standard Specification for Quicklime for Structural Purposes
ASTM C141 / C141M – 14 Standard Specification for Hydrated Hydraulic Lime for Structural Purposes
ASTM C821 – 14 Standard Specification for Lime for Use with Pozzolans
ASTM C1097 – 13 Standard Specification for Hydrated Lime for Use in Asphalt Cement or Bituminous Paving Mixtures
ASTM C1707 – 11 Standard Specification for Pozzolanic Hydraulic Lime for Structural Purposes
ASTM C645 – 14 Standard Specification for Nonstructural Steel Framing Members
ASTM C22 / C22M - 00(2010) Standard Specification for Gypsum
ASTM C28 / C28M – 10 Standard Specification for Gypsum Plasters
ASTM C1396 / C1396M - 14a Standard Specification for Gypsum Board
ASTM C840 – 13 Standard Specification for Application and Finishing of Gypsum Board
ASTM C109 / C109M – 13 Standard Test Method for Compressive Strength of Hydraulic Cement Mortars (Using 2-in. or [50-mm] Cube Specimens)
ASTM C348 - 14Standard Test Method for Flexural Strength of Hydraulic-Cement Mortars
ASTM C265 – 08 Standard Test Method for Water-Extractable Sulfate in Hydrated Hydraulic Cement Mortar
ASTM C563 – 13 Standard Test Method for Approximation of Optimum SO3 in Hydraulic Cement Using Compressive Strength
ASTM C452 / C452M – 10 Standard Test Method for Potential Expansion of Portland-Cement Mortars Exposed to Sulfate
ASTM C311 / C311M – 13 Standard Test Methods for Sampling and Testing Fly Ash or Natural Pozzolans for Use in Portland-Cement Concrete
ASTM C618 - 12a Standard Specification for Coal Fly Ash and Raw or Calcined Natural Pozzolan for Use in Concrete
ASTM C1240 – 14 Standard Specification for Silica Fume Used in Cementitious Mixtures
ASTM C1697 – 10 Standard Specification for Blended Supplementary Cementitious Materials
ASTM C219 - 14a Standard Terminology Relating to Hydraulic Cement
ASTM C125 – 14 Standard Terminology Relating to Concrete and Concrete Aggregates
ASTM C11 – 13 Standard Terminology Relating to Gypsum and Related Building Materials and Systems
ASTM C31 / C31M – 12 Standard Practice for Making and Curing Concrete Test Specimens in the Field
ASTM C39 / C39M - 14a Standard Test Method for Compressive Strength of Cylindrical Concrete Specimens
ASTM C42 / C42M – 13 Standard Test Method for Obtaining and Testing Drilled Cores and Sawed Beams of Concrete
ASTM C78 / C78M - 10e1 Standard Test Method for Flexural Strength of Concrete (Using Simple Beam with Third-Point Loading)
ASTM C192 / C192M – 14 Standard Practice for Making and Curing Concrete Test Specimens in the Laboratory
ASTM C293 / C293M – 10 Standard Test Method for Flexural Strength of Concrete (Using Simple Beam With Center-Point Loading)
ASTM C469 / C469M – 14 Standard Test Method for Static Modulus of Elasticity and Poisson’s Ratio of Concrete in Compression
ASTM C470 / C470M – 09 Standard Specification for Molds for Forming Concrete Test Cylinders Vertically
ASTM C496 / C496M – 11 Standard Test Method for Splitting Tensile Strength of Cylindrical Concrete Specimens
ASTM C512 / C512M – 10 Standard Test Method for Creep of Concrete in Compression
ASTM C617 / C617M – 12 Standard Practice for Capping Cylindrical Concrete Specimens
ASTM C873 / C873M - 10a Standard Test Method for Compressive Strength of Concrete Cylinders Cast in Place in Cylindrical Molds
ASTM C918 / C918M – 13 Standard Test Method for Measuring Early-Age Compressive Strength and Projecting Later-Age Strength
ASTM C1231 / C1231M – 14 Standard Practice for Use of Unbonded Caps in Determination of Compressive Strength of Hardened Concrete Cylinders
ASTM C1768 / C1768M – 12 Standard Practice for Accelerated Curing of Concrete Cylinders
ASTM C138 / C138M – 14 Standard Test Method for Density (Unit Weight), Yield, and Air Content (Gravimetric) of Concrete
ASTM C143 / C143M – 12 Standard Test Method for Slump of Hydraulic-Cement Concrete
ASTM C172 / C172M - 14a Standard Practice for Sampling Freshly Mixed Concrete
ASTM C173 / C173M – 14 Standard Test Method for Air Content of Freshly Mixed Concrete by the Volumetric Method
ASTM C231 / C231M – 14 Standard Test Method for Air Content of Freshly Mixed Concrete by the Pressure Method
ASTM C232 / C232M – 14 Standard Test Method for Bleeding of Concrete
ASTM C1064 / C1064M – 12 Standard Test Method for Temperature of Freshly Mixed Hydraulic-Cement Concrete
ASTM C191 – 13 Standard Test Methods for Time of Setting of Hydraulic Cement by Vicat Needle
ASTM C266 – 13 Standard Test Method for Time of Setting of Hydraulic-Cement Paste by Gillmore Needles
ASTM C359 – 13 Standard Test Method for Early Stiffening of Hydraulic Cement (Mortar Method)
ASTM C451 – 13 Standard Test Method for Early Stiffening of Hydraulic Cement (Paste Method)
ASTM C807 – 13 Standard Test Method for Time of Setting of Hydraulic Cement Mortar by Modified Vicat Needle
ASTM C596 – 09 Standard Test Method for Drying Shrinkage of Mortar Containing Hydraulic Cement
ASTM C1608 – 12 Standard Test Method for Chemical Shrinkage of Hydraulic Cement Paste
ASTM C157 / C157M - 08(2014)e1 Standard Test Method for Length Change of Hardened Hydraulic-Cement Mortar and Concrete
ASTM C1698 - 09(2014) Standard Test Method for Autogenous Strain of Cement Paste and Mortar
ASTM C187 - 11e1 Standard Test Method for Amount of Water Required for Normal Consistency of Hydraulic Cement Paste
ASTM C230 / C230M – 14 Standard Specification for Flow Table for Use in Tests of Hydraulic Cement
ASTM C305 – 14 Standard Practice for Mechanical Mixing of Hydraulic Cement Pastes and Mortars of Plastic Consistency
ASTM C1437 – 13 Standard Test Method for Flow of Hydraulic Cement Mortar
ASTM C1506 – 09 Standard Test Method for Water Retention of Hydraulic Cement-Based Mortars and Plasters
ASTM C1738 / C1738M – 14 Standard Practice for High-Shear Mixing of Hydraulic Cement Pastes
ASTM C1749 – 12 Standard Guide for Measurement of the Rheological Properties of Hydraulic Cementious Paste Using a Rotational Rheometer
[-] The following 52 users Like nibbi's post:52 users Like nibbi's post
  • usman, Jackass, ronnie_150, Hengki, bridgeengineer, peixoto, junaid, Dell_Brett, araza023, jcbv, haze, agarciam2, oanm2000, uncblue, concreteok, viet2010, subin91, shaker, gulilero, malc, tumangik, PinkPant, zrilek, tomtumx, pezhmankhan, isurya, Photon, inge911, pingfan2, RyanRS, ascetic19, vvvv, bigone, eliseo.as, ir_71, yalham2000, f_slikken, chenamoy, ykhackhack, abualamal, ashcivilea, heogay43, hodzicemir, pram, amrzaki200, simanta, sodapas, amareen2000, scorpion07, Wijono, Yasir, tuanpecc1
 Veggeta
Guatemala
User ID: 114
Threads: 98
Likes: 4,273 in 520 posts
Given Likes: 403
02-04-2015, 04:23 PM
Use official password
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 16 users Like Veggeta's post:16 users Like Veggeta's post
  • oanm2000, Photon, Dell_Brett, PinkPant, vvvv, bigone, eliseo.as, yalham2000, f_slikken, ykhackhack, abualamal, heogay43, hodzicemir, amrzaki200, simanta, amareen2000
 nibbi
User ID: 21150
Threads: 6
Given Likes: 182
02-06-2015, 06:06 AM (This post was last modified: 02-06-2015, 06:41 AM by nibbi.)
ASTM Steel Standards
Author: ASTM | Size: 11.4 MB | Format: PDF | Quality: Original preprint | Year: 2015
F2453 / F2453M – 14 Standard Specification for Welded Wire Mesh Fence Fabric (Metallic-Coated or Polymer Coated) for Meshes of 6 in.2  [3871 mm2] or Less, in Panels or Rolls, with Uniform Meshes
F2919 / F2919M – 12 Standard Specification for Welded Wire Mesh Fence Fabric (Metallic-Coated or Polymer Coated) with Variable Mesh Patterns or Meshes Greater than 6 in.2 [3871 mm2] in Panels
A29 / A29M - 12e1 Standard Specification for General Requirements for Steel Bars, Carbon and Alloy, Hot-Wrought
A255 - 10(2014) Standard Test Methods for Determining Hardenability of Steel
A322 – 13 Standard Specification for Steel Bars, Alloy, Standard Grades
A499 - 89(2008) Standard Specification for Steel Bars and Shapes, Carbon Rolled from “T” Rails
A663 / A663M – 12 Standard Specification for Steel Bars, Carbon, Merchant Quality, Mechanical Properties
A702 – 13 Standard Specification for Steel Fence Posts, Hot Wrought
A295 / A295M – 14 Standard Specification for High-Carbon Anti-Friction Bearing Steel
A866 – 14 Standard Specification for Medium Carbon Anti-Friction Bearing Steel
A53 / A53M – 12 Standard Specification for Pipe, Steel, Black and Hot-Dipped, Zinc-Coated, Welded and Seamless
A106 / A106M – 14 Standard Specification for Seamless Carbon Steel Pipe for High-Temperature Service
A135 / A135M - 09(2014) Standard Specification for Electric-Resistance-Welded Steel Pipe
A139 / A139M - 04(2010) Standard Specification for Electric-Fusion (Arc)-Welded Steel Pipe (NPS 4 and Over)
A252 – 10 Standard Specification for Welded and Seamless Steel Pipe Piles
A450 / A450M – 10 Standard Specification for General Requirements for Carbon and Low Alloy Steel Tubes
A27 / A27M – 13 Standard Specification for Steel Castings, Carbon, for General Application
A148 / A148M – 14 Standard Specification for Steel Castings, High Strength, for Structural Purposes
A392 - 11a Standard Specification for Zinc-Coated Steel Chain-Link Fence Fabric
F626 – 14 Standard Specification for Fence Fittings
F900 – 11 Standard Specification for Industrial and Commercial Swing Gates
F1083 – 13 Standard Specification for Pipe, Steel, Hot-Dipped Zinc-Coated (Galvanized) Welded, for Fence Structures
F1184 - 05(2010) Standard Specification for Industrial and Commercial Horizontal Slide Gates
F1553 – 11 Standard Guide for Specifying Chain Link Fence
A742 / A742M – 13 Standard Specification for Steel Sheet, Metallic Coated and Polymer Precoated for Corrugated Steel Pipe
A761 / A761M - 13b Standard Specification for Corrugated Steel Structural Plate, Zinc-Coated, for Field-Bolted Pipe, Pipe-Arches, and Arches
A964 / A964M - 03(2011) Standard Specification for Corrugated Steel Box Culverts
A902 – 14 Standard Terminology Relating to Metallic Coated Steel Products
F1835 - 97(2012)e1 Standard Guide for Cable Splicing Installations
F1837M - 97(2012)e1 Standard Specification for Heat-Shrink Cable Entry Seals (Metric)
F1883 - 03(2013) Standard Practice for Selection of Wire and Cable Size in AWG or Metric Units
A276 / A276M – 15 Standard Specification for Stainless Steel Bars and Shapes
A314 - 13a Standard Specification for Stainless Steel Billets and Bars for Forging
A368 - 95a(2013) Standard Specification for Stainless Steel Wire Strand
A484 / A484M - 14a Standard Specification for General Requirements for Stainless Steel Bars, Billets, and Forgings
A555 / A555M - 05(2014) Standard Specification for General Requirements for Stainless Steel Wire and Wire Rods
A580 / A580M – 14 Standard Specification for Stainless Steel Wire
A947M – 13 Standard Specification for Textured Stainless Steel Sheet [Metric]
F1712 – 11 Standard Specification for Steel Chain-Link Fencing Materials Used for High Security Applications
F2611 – 11 Standard Guide for Design and Construction of Chain Link Security Fencing
A370 – 14 Standard Test Methods and Definitions for Mechanical Testing of Steel Products
A751 - 14a Standard Test Methods, Practices, and Terminology for Chemical Analysis of Steel Products
A1058 – 14 Standard Test Methods for Mechanical Testing of Steel Products—Metric
A380 / A380M – 13 Standard Practice for Cleaning, Descaling, and Passivation of Stainless Steel Parts, Equipment, and Systems
A90 / A90M – 13 Standard Test Method for Weight [Mass] of Coating on Iron and Steel Articles with Zinc or Zinc-Alloy Coatings
A428 / A428M - 10(2014) Standard Test Method for Weight [Mass] of Coating on Aluminum-Coated Iron or Steel Articles
A754 / A754M – 11 Standard Test Method for Coating Weight (Mass) of Metallic Coatings on Steel by X-Ray Fluorescence
F537 - 01(2014) Standard Specification for Design, Fabrication, and Installation of Fences Constructed of Wood and Related Materials
A463 / A463M – 10 Standard Specification for Steel Sheet, Aluminum-Coated, by the Hot-Dip Process
A653 / A653M – 13 Standard Specification for Steel Sheet, Zinc-Coated (Galvanized) or Zinc-Iron Alloy-Coated (Galvannealed) by the Hot-Dip Process
A924 / A924M – 14 Standard Specification for General Requirements for Steel Sheet, Metallic-Coated by the Hot-Dip Process
A1057 / A1057M - 08(2014) Standard Specification for Steel, Structural Tubing, Cold Formed, Welded, Carbon, Zinc-Coated (Galvanized) by the Hot-Dip Process
A20 / A20M – 14 Standard Specification for General Requirements for Steel Plates for Pressure Vessels
A1 - 00(2010) Standard Specification for Carbon Steel Tee Rails
A2 - 02(2014) Standard Specification for Carbon Steel Girder Rails of Plain, Grooved, and Guard Types
A759 – 10 Standard Specification for Carbon Steel Crane Rails
A183 – 14 Standard Specification for Carbon Steel Track Bolts and Nuts
A184 / A184M - 06(2011) Standard Specification for Welded Deformed Steel Bar Mats for Concrete Reinforcement
A416 / A416M - 12a Standard Specification for Steel Strand, Uncoated Seven-Wire for Prestressed Concrete
A421 / A421M – 10 Standard Specification for Uncoated Stress-Relieved Steel Wire for Prestressed Concrete
A648 – 12 Standard Specification for Steel Wire, Hard-Drawn for Prestressed Concrete Pipe
A704 / A704M - 06(2011) Standard Specification for Welded Steel Plain Bar or Rod Mats for Concrete Reinforcement
A722 / A722M – 12 Standard Specification for Uncoated High-Strength Steel Bars for Prestressing Concrete
A775 / A775M - 07b(2014) Standard Specification for Epoxy-Coated Steel Reinforcing Bars
A779 / A779M – 12 Standard Specification for Steel Strand, Seven-Wire, Uncoated, Compacted for Prestressed Concrete
A820 / A820M – 11 Standard Specification for Steel Fibers for Fiber-Reinforced Concrete
A821 / A821M – 10 Standard Specification for Steel Wire, Hard-Drawn for Prestressed Concrete Tanks
A884 / A884M – 14 Standard Specification for Epoxy-Coated Steel Wire and Welded Wire Reinforcement
A934 / A934M – 13 Standard Specification for Epoxy-Coated Prefabricated Steel Reinforcing Bars
A951 / A951M – 14 Standard Specification for Steel Wire for Masonry Joint Reinforcement
A955 / A955M – 14 Standard Specification for Deformed and Plain Stainless-Steel Bars for Concrete Reinforcement
A970 / A970M - 13a Standard Specification for Headed Steel Bars for Concrete Reinforcement
A981 / A981M – 11 Standard Test Method for Evaluating Bond Strength for 0.600-in. [15.24-mm] Diameter Steel Prestressing Strand, Grade 270 [1860], Uncoated, Used in Prestressed Ground Anchors
A1022 / A1022M - 14a Standard Specification for Deformed and Plain Stainless Steel Wire and Welded Wire for Concrete Reinforcement
A1034 / A1034M - 10a Standard Test Methods for Testing Mechanical Splices for Steel Reinforcing Bars
A1044 / A1044M - 05(2010) Standard Specification for Steel Stud Assemblies for Shear Reinforcement of Concrete
A1055 / A1055M - 10e1 Standard Specification for Zinc and Epoxy Dual-Coated Steel Reinforcing Bars
A1060 / A1060M – 14 Standard Specification for Zinc-Coated (Galvanized) Steel Welded Wire Reinforcement, Plain and Deformed, for Concrete
A1061 / A1061M – 09 Standard Test Methods for Testing Multi-Wire Steel Strand
A1064 / A1064M – 14 Standard Specification for Carbon-Steel Wire and Welded Wire Reinforcement, Plain and Deformed, for Concrete
A1081 / A1081M – 12 Standard Test Method for Evaluating Bond of Seven-Wire Steel Prestressing Strand
A123 / A123M – 13 Standard Specification for Zinc (Hot-Dip Galvanized) Coatings on Iron and Steel Products
A153 / A153M – 09 Standard Specification for Zinc Coating (Hot-Dip) on Iron and Steel Hardware
A385 / A385M - 11e1 Standard Practice for Providing High-Quality Zinc Coatings (Hot-Dip)
A780 / A780M – 09 Standard Practice for Repair of Damaged and Uncoated Areas of Hot-Dip Galvanized Coatings
A6 / A6M – 14 Standard Specification for General Requirements for Rolled Structural Steel Bars, Plates, Shapes, and Sheet Piling
A36 / A36M – 14 Standard Specification for Carbon Structural Steel
A242 / A242M – 13 Standard Specification for High-Strength Low-Alloy Structural Steel
A328 / A328M - 13a Standard Specification for Steel Sheet Piling
A572 / A572M - 13a Standard Specification for High-Strength Low-Alloy Columbium-Vanadium Structural Steel
A529 / A529M – 14 Standard Specification for High-Strength Carbon-Manganese Steel of Structural Quality
A573 / A573M – 13 Standard Specification for Structural Carbon Steel Plates of Improved Toughness
A588 / A588M – 10 Standard Specification for High-Strength Low-Alloy Structural Steel, up to 50 ksi [345 MPa] Minimum Yield Point, with Atmospheric Corrosion Resistance
A633 / A633M – 13 Standard Specification for Normalized High-Strength Low-Alloy Structural Steel Plates
A690 / A690M - 13a Standard Specification for High-Strength Low-Alloy Nickel, Copper, Phosphorus Steel H-Piles and Sheet Piling with Atmospheric Corrosion Resistance for Use in Marine Environments
A709 / A709M - 13a Standard Specification for Structural Steel for Bridges
A829 / A829M – 14 Standard Specification for Alloy Structural Steel Plates
A871 / A871M – 14 Standard Specification for High-Strength Low-Alloy Structural Steel Plate With Atmospheric Corrosion Resistance
A898 / A898M - 07(2012) Standard Specification for Straight Beam Ultrasonic Examination of Rolled Steel Structural Shapes
A992 / A992M – 11 Standard Specification for Structural Steel Shapes
A1077 / A1077M – 14 Standard Specification for Structural Steel with Improved Yield Strength at High Temperature for Use in Buildings
A941 - 13b Standard Terminology Relating to Steel, Stainless Steel, Related Alloys, and Ferroalloys
A700 – 14 Standard Guide for Packaging, Marking, and Loading Methods for Steel Products for Shipment
A121 – 13 Standard Specification for Metallic-Coated Carbon Steel Barbed Wire
A363 - 03(2014) Standard Specification for Zinc-Coated (Galvanized) Steel Overhead Ground Wire Strand
A460 – 11 Standard Specification for Copper-Clad Steel Wire Strand
A474 - 03(2013) Standard Specification for Aluminum-Coated Steel Wire Strand
A475 - 03(2014) Standard Specification for Zinc-Coated Steel Wire Strand
A641 / A641M - 09a(2014) Standard Specification for Zinc–Coated (Galvanized) Carbon Steel Wire
A741 - 11e1 Standard Specification for Metallic-Coated Steel Wire Rope and Fittings for Highway Guardrail
ASTM Fastener Standards
Author: ASTM | Size: 3.2 MB | Format: PDF | Quality: Original preprint | Year: 2015
F1136 / F1136M – 11 Standard Specification for Zinc/Aluminum Corrosion Protective Coatings for Fasteners
F2329 – 13 Standard Specification for Zinc Coating, Hot-Dip, Requirements for Application to Carbon and Alloy Steel Bolts, Screws, Washers, Nuts, and Special Threaded Fasteners
F593 - 13a Standard Specification for Stainless Steel Bolts, Hex Cap Screws, and Studs
F594 - 09e1 Standard Specification for Stainless Steel Nuts
F837M - 02a(2010) Standard Specification for Stainless Steel Socket Head Cap Screws [Metric]
F901 - 01(2012) Standard Specification for Aluminum Transmission Tower Bolts and Nuts
F1470 – 12 Standard Practice for Fastener Sampling for Specified Mechanical Properties and Performance Inspection
A31 – 14 Standard Specification for Steel Rivets and Bars for Rivets, Pressure Vessels
A307 – 14 Standard Specification for Carbon Steel Bolts, Studs, and Threaded Rod 60000 PSI Tensile Strength
A325 – 14 Standard Specification for Structural Bolts, Steel, Heat Treated, 120/105 ksi Minimum Tensile Strength
A354 – 11 Standard Specification for Quenched and Tempered Alloy Steel Bolts, Studs, and Other Externally Threaded Fasteners
A394 - 08e1 Standard Specification for Steel Transmission Tower Bolts, Zinc-Coated and Bare
A449 – 14 Standard Specification for Hex Cap Screws, Bolts and Studs, Steel, Heat Treated, 120/105/90 ksi Minimum Tensile Strength, General Use
A489 – 12 Standard Specification for Carbon Steel Lifting Eyes
A490 - 14a Standard Specification for Structural Bolts, Alloy Steel, Heat Treated, 150 ksi Minimum Tensile Strength
A502 - 03(2009) Standard Specification for Rivets, Steel, Structural
A563M - 07(2013) Standard Specification for Carbon and Alloy Steel Nuts (Metric)
A574M – 12 Standard Specification for Alloy Steel Socket-Head Cap Screws (Metric)
F432 – 13 Standard Specification for Roof and Rock Bolts and Accessories
F436M – 11 Standard Specification for Hardened Steel Washers [Metric]
F844 - 07a(2013) Standard Specification for Washers, Steel, Plain (Flat), Unhardened for General Use
F1554 - 07ae1 Standard Specification for Anchor Bolts, Steel, 36, 55, and 105-ksi Yield Strength
F1852 – 14 Standard Specification for “Twist Off” Type Tension Control Structural Bolt/Nut/Washer Assemblies, Steel, Heat Treated, 120/105 ksi Minimum Tensile Strength
F2280 – 14 Standard Specification for “Twist Off” Type Tension Control Structural Bolt/Nut/Washer Assemblies, Steel, Heat Treated, 150 ksi Minimum Tensile Strength
F2882M – 12 Standard Specification for Screws, Alloy Steel, Heat Treated, 1170 MPa Minimum Tensile Strength [Metric]
F3125 – 15 Standard Specification for High Strength Structural Bolts, Steel and Alloy Steel, Heat Treated, 120 ksi (830 MPa) and 150 ksi (1040 MPa) Minimum Tensile Strength, Inch and Metric Dimensions
F606M – 14 Standard Test Methods for Determining the Mechanical Properties of Externally and Internally Threaded Fasteners, Washers, and Rivets (Metric)
F2660 – 13 Standard Test Method for Qualifying Coatings for Use on A490 Structural Bolts Relative to Environmental Hydrogen Embrittlement
F2832 – 11 Standard Guide for Accelerated Corrosion Testing for Mechanical Fasteners
ASTM Geotechnical Engineering Standards
Author: ASTM | Size: 32.5 MB | Format: PDF | Quality: Original preprint | Year: 2015
D3999 / D3999M - 11e1 Standard Test Methods for the Determination of the Modulus and Damping Properties of Soils Using the Cyclic Triaxial Apparatus
D4015 – 07 Standard Test Methods for Modulus and Damping of Soils by Resonant-Column Method
D4428 / D4428M – 14 Standard Test Methods for Crosshole Seismic Testing
D5311 / D5311M – 13 Standard Test Method for Load Controlled Cyclic Triaxial Strength of Soil
D7400 – 14 Standard Test Methods for Downhole Seismic Testing
D1143 / D1143M - 07(2013) Standard Test Methods for Deep Foundations Under Static Axial Compressive Load
D3689 / D3689M - 07(2013)e1 Standard Test Methods for Deep Foundations Under Static Axial Tensile Load
D3966 / D3966M - 07(2013)e1 Standard Test Methods for Deep Foundations Under Lateral Load
D4945 – 12 Standard Test Method for High-Strain Dynamic Testing of Deep Foundations
D6760 – 14 Standard Test Method for Integrity Testing of Concrete Deep Foundations by Ultrasonic Crosshole Testing
D7383 – 10 Standard Test Methods for Axial Compressive Force Pulse (Rapid) Testing of Deep Foundations
D4439 – 14 Standard Terminology for Geosynthetics
D4083 - 89(2007) Standard Practice for Description of Frozen Soils (Visual-Manual Procedure)
D5918 – 13 Standard Test Methods for Frost Heave and Thaw Weakening Susceptibility of Soils
D7762 – 11 Standard Practice for Design of Stabilization of Soil and Soil-Like Materials with Self-Cementing Fly Ash
D7765 – 12 Standard Practice for Use of Foundry Sand in Structural Fill and Embankments
D5092 - 04(2010)e1 Standard Practice for Design and Installation of Groundwater Monitoring Wells
D7929 – 14 Standard Guide for Selection of Passive Techniques for Sampling Groundwater Monitoring Wells
D2487 – 11 Standard Practice for Classification of Soils for Engineering Purposes (Unified Soil Classification System)
D2488 - 09a Standard Practice for Description and Identification of Soils (Visual-Manual Procedure)
D3282 – 09 Standard Practice for Classification of Soils and Soil-Aggregate Mixtures for Highway Construction Purposes
D4427 – 13 Standard Classification of Peat Samples by Laboratory Testing
D4452 – 14 Standard Practice for X-Ray Radiography of Soil Samples
D4373 – 14 Standard Test Method for Rapid Determination of Carbonate Content of Soils
D4647 / D4647M – 13 Standard Test Methods for Identification and Classification of Dispersive Clay Soils by the Pinhole Test
D3740 - 12a Standard Practice for Minimum Requirements for Agencies Engaged in Testing and/or Inspection of Soil and Rock as Used in Engineering Design and Construction
D5255 – 14 Standard Practice for Certification of Personnel Engaged in the Testing of Soil and Rock
D4992 – 14 Standard Practice for Evaluation of Rock to be Used for Erosion Control
D6092 – 14 Standard Practice for Specifying Standard Sizes of Stone for Erosion Control
D6825 – 14 Standard Guide for Placement of Riprap Revetments
D2845 – 08 Standard Test Method for Laboratory Determination of Pulse Velocities and Ultrasonic Elastic Constants of Rock
D2936 – 08 Standard Test Method for Direct Tensile Strength of Intact Rock Core Specimens
D3967 – 08 Standard Test Method for Splitting Tensile Strength of Intact Rock Core Specimens
D4394 – 08 Standard Test Method for Determining In Situ Modulus of Deformation of Rock Mass Using Rigid Plate Loading Method
D4395 – 08 Standard Test Method for Determining In Situ Modulus of Deformation of Rock Mass Using Flexible Plate Loading Method
D4435 - 13e1 Standard Test Method for Rock Bolt Anchor Pull Test
D4553 – 08 Standard Test Method for Determining In Situ Creep Characteristics of Rock
D4554 – 12 Standard Test Method for In Situ Determination of Direct Shear Strength of Rock Discontinuities
D4555 – 10 Standard Test Method for Determining Deformability and Strength of Weak Rock by an In Situ Uniaxial Compressive Test
D4611 – 08 Standard Test Method for Specific Heat of Rock and Soil
D5731 – 08 Standard Test Method for Determination of the Point Load Strength Index of Rock and Application to Rock Strength Classifications
D5873 – 14 Standard Test Method for Determination of Rock Hardness by Rebound Hammer Method
D5878 – 08 Standard Guides for Using Rock-Mass Classification Systems for Engineering Purposes
D6032 – 08 Standard Test Method for Determining Rock Quality Designation (RQD) of Rock Core
D7012 – 14 Standard Test Methods for Compressive Strength and Elastic Moduli of Intact Rock Core Specimens under Varying States of Stress and Temperatures
D7401 – 08 Standard Test Methods for Laboratory Determination of Rock Anchor Capacities by Pull and Drop Tests
D1452 – 09 Standard Practice for Soil Exploration and Sampling by Auger Borings
D1586 – 11 Standard Test Method for Standard Penetration Test (SPT) and Split-Barrel Sampling of Soils
D1587 - 08(2012)e1 Standard Practice for Thin-Walled Tube Sampling of Soils for Geotechnical Purposes
D2113 – 14 Standard Practice for Rock Core Drilling and Sampling of Rock for Site Exploration
D2573 – 08 Standard Test Method for Field Vane Shear Test in Cohesive Soil
D4220 / D4220M – 14 Standard Practices for Preserving and Transporting Soil Samples
D4633 – 10 Standard Test Method for Energy Measurement for Dynamic Penetrometers
D5434 – 12 Standard Guide for Field Logging of Subsurface Explorations of Soil and Rock
D6066 – 11 Standard Practice for Determining the Normalized Penetration Resistance of Sands for Evaluation of Liquefaction Potential
D6151 – 08 Standard Practice for Using Hollow-Stem Augers for Geotechnical Exploration and Soil Sampling
D6635 - 01(2007)Standard Test Method for Performing the Flat Plate Dilatometer
D7015 – 13 Standard Practices for Obtaining Intact Block (Cubical and Cylindrical) Samples of Soils
D4972 – 13 Standard Test Method for pH of Soils
D6629 - 01(2012)e1 Standard Guide for Selection of Methods for Estimating Soil Loss by Erosion
D1241 – 07 Standard Specification for Materials for Soil-Aggregate Subbase, Base, and Surface Courses
D1556 – 07 Standard Test Method for Density and Unit Weight of Soil in Place by the Sand-Cone Method
D1558 – 10 Standard Test Method for Moisture Content Penetration Resistance Relationships of Fine-Grained Soils
D2167 – 08 Standard Test Method for Density and Unit Weight of Soil in Place by the Rubber Balloon Method
D2844 / D2844M – 13 Standard Test Method for Resistance R-Value and Expansion Pressure of Compacted Soils
D2937 – 10 Standard Test Method for Density of Soil in Place by the Drive-Cylinder Method
D4429 - 09a Standard Test Method for CBR (California Bearing Ratio) of Soils in Place
D4643 – 08 Standard Test Method for Determination of Water (Moisture) Content of Soil by Microwave Oven Heating
D4914 – 08 Standard Test Methods for Density and Unit Weight of Soil and Rock in Place by the Sand Replacement Method in a Test Pit
D4959 – 07 Standard Test Method for Determination of Water (Moisture) Content of Soil By Direct Heating
D5030 / D5030M - 13a Standard Test Methods for Density of Soil and Rock in Place by the Water Replacement Method in a Test Pit
D5080 – 08 Standard Test Method for Rapid Determination of Percent Compaction
D5195 – 14 Standard Test Method for Density of Soil and Rock In-Place at Depths Below Surface by Nuclear Methods
D6938 – 10 Standard Test Method for In-Place Density and Water Content of Soil and Soil-Aggregate by Nuclear Methods (Shallow Depth)
D7380 – 08 Standard Test Method for Soil Compaction Determination at Shallow Depths Using 5-lb (2.3 kg) Dynamic Cone Penetrometer
D7698 - 11a Standard Test Method for In-Place Estimation of Density and Water Content of Soil and Aggregate by Correlation with Complex Impedance Method
D7759 / D7759M – 14 Standard Guide for Nuclear Surface Moisture and Density Gauge Calibration
D7830 / D7830M – 14 Standard Test Method for In-Place Density (Unit Weight) and Water Content of Soil Using an Electromagnetic Soil Density Gauge
D1883 – 14 Standard Test Method for California Bearing Ratio (CBR) of Laboratory-Compacted Soils
D2166 / D2166M – 13 Standard Test Method for Unconfined Compressive Strength of Cohesive Soil
D2435 / D2435M – 11 Standard Test Methods for One-Dimensional Consolidation Properties of Soils Using Incremental Loading
D2850 - 03a(2007) Standard Test Method for Unconsolidated-Undrained Triaxial Compression Test on Cohesive Soils
D3080 / D3080M – 11 Standard Test Method for Direct Shear Test of Soils Under Consolidated Drained Conditions
D4186 / D4186M - 12e1 Standard Test Method for One-Dimensional Consolidation Properties of Saturated Cohesive Soils Using Controlled-Strain Loading
D4546 – 14 Standard Test Methods for One-Dimensional Swell or Collapse of Soils
D4648 / D4648M – 13 Standard Test Method for Laboratory Miniature Vane Shear Test for SaturatedFine-Grained Clayey Soil
D4767 – 11 Standard Test Method for Consolidated Undrained Triaxial Compression Test for Cohesive Soils
D4829 – 11 Standard Test Method for Expansion Index of Soils
D6467 – 13 Standard Test Method for Torsional Ring Shear Test to Determine Drained Residual Shear Strength of Cohesive Soils
D6528 – 07 Standard Test Method for Consolidated Undrained Direct Simple Shear Testing of Cohesive Soils
D7181 – 11 Method for Consolidated Drained Triaxial Compression Test for Soils
D7608 – 10 Standard Test Method for Torsional Ring Shear Test to Determine Drained Fully Softened Shear Strength and Nonlinear Strength Envelope of Cohesive Soils (Using Normally Consolidated Specimen) for Slopes with No Preexisting Shear Surfaces
D5753 - 05(2010) Standard Guide for Planning and Conducting Borehole Geophysical Logging
D5995 - 98(2010) Standard Guide for Environmental Site Characterization in Cold Regions
D7128 - 05(2010) Standard Guide for Using the Seismic-Reflection Method for Shallow Subsurface Investigation
D653 – 14 Standard Terminology Relating to Soil, Rock, and Contained Fluids
D422 - 63(2007)e2 Standard Test Method for Particle-Size Analysis of Soils
D698 - 12e1 Standard Test Methods for Laboratory Compaction Characteristics of Soil Using Standard Effort (12 400 ft-lbf/ft3 (600 kN-m/m3))
D1140 – 14 Standard Test Methods for Determining the Amount of Material Finer than 75-μm (No. 200) Sieve in Soils by Washing
D1557 – 12 Standard Test Methods for Laboratory Compaction Characteristics of Soil Using Modified Effort (56,000 ft-lbf/ft3 (2,700 kN-m/m3))
D2168 – 10 Standard Test Methods for Calibration of Laboratory Mechanical-Rammer Soil Compactors
D2216 – 10 Standard Test Methods for Laboratory Determination of Water (Moisture) Content of Soil and Rock by Mass
D4253 – 14 Standard Test Methods for Maximum Index Density and Unit Weight of Soils Using a Vibratory Table
D4254 – 14 Standard Test Methods for Minimum Index Density and Unit Weight of Soils and Calculation of Relative Density
D4318 - 10e1 Standard Test Methods for Liquid Limit, Plastic Limit, and Plasticity Index of Soils
D4718 - 87(2007) Standard Practice for Correction of Unit Weight and Water Content for Soils Containing Oversize Particles
D5550 – 14 Standard Test Method for Specific Gravity of Soil Solids by Gas Pycnometer
D6913 - 04(2009)e1 Standard Test Methods for Particle-Size Distribution (Gradation) of Soils Using Sieve Analysis
D7263 – 09 Standard Test Methods for Laboratory Determination of Density (Unit Weight) of Soil Specimens
D7382 – 08 Standard Test Methods for Determination of Maximum Dry Unit Weight and Water Content Range for Effective Compaction of Granular Soils Using a Vibrating Hammer
[-] The following 47 users Like nibbi's post:47 users Like nibbi's post
  • ascetic19, malc, vvvv, jcbv, docgeotech, PinkPant, Dell_Brett, daywalker, inge911, uncblue, tomtumx, zrilek, shaker, bigone, bridgeengineer, oanm2000, eliseo.as, RyanRS, usman, Jackass, ir_71, yalham2000, f_slikken, chenamoy, ykhackhack, utan, Photon, abualamal, duazo2009, peixoto, ashcivilea, heogay43, hodzicemir, nghuuthanh, hamex, amrzaki200, simanta, sodapas, amareen2000, LeonardoPark, pram, Hengki, Aviator, scorpion07, rizal13, levanduy, Wijono
  ASTM 2005 - ASTM Dictionary of ENGINEERING SCIENCE & TECHNOLOGY, 10th ed abudabeeja 2 4,756 01-23-2022, 10:22 AM
  ASTM 2015 Standards (Complete Set) junaid 2 4,216 12-12-2020, 11:01 PM
Last Post: shaker
  ASTM - Mega Collection of ASTM Standards (UPDATED REGULARLY) junaid 1 3,272 11-09-2017, 11:49 PM
Last Post: usman
  ASTM DS67B - Handbook of Comparative World Steel Standards struceng 7 5,790 04-27-2017, 04:54 PM
Last Post: AtoZmail
  ASTM 2014 Standards (Complete Set) junaid 7 6,115 01-30-2017, 04:36 PM
Last Post: junaid
  ASTM 2004 Standards (Complete Set) junaid 6 4,618 01-29-2017, 06:11 PM
Last Post: junaid
  ASTM Standards (Miscellaneous Collection) ans575 5 6,437 04-13-2016, 12:59 PM
