Civil Engineering Association Forum Discussion Suggestion & Complains Archive [IN PROGRESS] Suggestion: New section in ebook post generator for editors, translators and quality
[In Progress] Suggestion: New section in ebook post generator for editors, translators and quality
 Mohammad6299
Guest
Guests
Likes: 0 in 0 posts
Given Likes:
06-19-2014, 07:21 AM
I think that eBook post generator should have sections to specify "Editor(s)" and "Translator(s)". In "Source type (Quality)" section, "Scanner" should be devided to "Scanner (OCR)" and "Scanner (Non-OCR)".
[-] The following 5 users Like 's post:5 users Like 's post
  • amindoxiti, PinkPant, Administrator , oanm2000, ska51
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 258
Likes: 21,198 in 2,356 posts
Given Likes: 4260
10-31-2014, 12:52 PM
This suggestion is in progress and will be done in next revision.
  • Mohammad6299
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,039 in 2,189 posts
Given Likes: 42508
10-31-2014, 01:43 PM
Nice suggestion, but I think that too much information tends to be more of a hindrance than an increase in quality.
What's the real importance of the "translator(s)" as a field to be filled?
I think that we need to find the equilibrium point, between quality and simplicity.
[-] The following 9 users Like Dell_Brett's post:9 users Like Dell_Brett's post
  • BennyP, hapsea, usman, Mohammad6299, mowafi3m, oanm2000, malc, concreteok, faros3000
 Mohammad6299
User ID: 42302
Threads: 251
Likes: 7,913 in 854 posts
Given Likes: 4212
10-31-2014, 07:23 PM (This post was last modified: 10-31-2014, 07:24 PM by Mohammad6299.)
Dear Dell_Brett
Thank you for the reply.
You are right about the "Translator(s)", but I think Editor(s) and OCR are necessary.
Only the name of the Editors is specified for some publications:
In these cases "Editor(s)" should be used instead of the default "Author(s)".
I think OCR is necessary too. Some users want the OCR Scanned books because their content can be searched. Mentioning OCR in the post makes it easier to find such PDFs.
 mowafi3m
Egypt
User ID: 1236
Threads: 385
Likes: 9,324 in 678 posts
Given Likes: 1668
10-31-2014, 09:20 PM
@Mohammad6299
I'm agree with Dell_Brett
because these new options is not important for the Downloader !!!
and needs to more time to fill the fields
moreover we take materials from other forums and often these new data is not available
many thanks
[-] The following 3 users Like mowafi3m's post:3 users Like mowafi3m's post
  • oanm2000, Dell_Brett, Mohammad6299
 Mohammad6299
User ID: 42302
Threads: 251
Given Likes: 4212
11-01-2014, 03:21 AM (This post was last modified: 11-01-2014, 03:45 AM by Mohammad6299.)
Dear @mowafi3m,
These data (and even more) are usually specified at some websites for example libgen.org and openlibrary.org.
For some publications as I made an example at post #4, only the editors are specified and the authors are not specified (sometimes because every chapter of the book has many authors). I think that in these cases it is not correct to use Editors(s) option in the postgen instead of Author(s).
The person who posts a material at the forum can simply obtain the data and the information that he/she needs by downloading the eBook. eBooks usually have small sizes and it is not difficult to download them and look up the missing information.
Some scanned files have a large size and the server which the file is uploaded to is very slow. In these cases the person who is looking for the OCR material has to download files from different posts to check if the files are OCR.
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 258
Given Likes: 4260
07-10-2015, 09:11 AM
Your suggestion was implemented in new PostGenerator (V2.3.0).
[-] The following 3 users Like Administrator 's post:3 users Like Administrator 's post
  • ska51, oanm2000, ykhackhack
  Suggestion hodzicemir 1 8,791 09-17-2015, 02:15 PM
Last Post: Dell_Brett
  [IN PROGRESS] Suggestion: New section in PostGen for Civil Engineering Videos Mohammad6299 1 21,681 07-10-2015, 09:13 AM
Last Post: Administrator
  [IN PROGRESS] Suggestion: New section in PostGen for article download links Mohammad6299 2 11,079 07-10-2015, 09:12 AM
  Suggestion for Journal Reviews Section frankgron 2 8,332 10-31-2014, 07:52 PM
Last Post: Mohammad6299
  Use Post Generator to REQUEST mybest 8 28,181 03-15-2013, 05:24 PM
  Ebook Post Generator mybest 7 23,374 01-10-2012, 07:36 PM
  Some Suggestion mybest 1 6,638 12-26-2011, 05:52 PM
