Civil Engineering Association eBooks Codes, Manual & Handbook AASHTO AASHTO LRFD Bridge Construction Specifications
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
02-28-2013, 07:22 PM (This post was last modified: 02-12-2022, 06:04 AM by Administrator.)
AASHTO LRFD Bridge Construction Specifications (3rd Edition) with 2010 and 2011 Interim
Author: AASHTO | Size: 4.1 MB | Format: PDF | Quality: Unspecified | Publisher: AASHTO | Year: 2012 | pages: 583 | ISBN: 9781613449929
[Image: 53899409588691716634.jpg]
This broadly recognized national standard to design and construct bridges has been revised to be consistent with its companion, the recently updated AASHTO LRFD Bridge Design Specifications. Among the revisions are improved testing and acceptance criteria, updated material references, and recommended guidelines for construction loads. Included in this electronic edition are the 2010 and 2011 Interim Revisions. Following each chapter the revisions are identified as well as linked throughout the entire book where available. See the "Interim Revisions 2010 and 2011" sections for a complete list of changes to each section.
[-] The following 9 users Like asim99's post:9 users Like asim99's post
  β€’ usman, kowheng, Administrator , Dell_Brett, peixoto, Ultra Zone, cordoba123, gulilero, pezhmankhan
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
06-20-2017, 05:34 PM
[-] The following 2 users Like mahyarov's post:2 users Like mahyarov's post
  β€’ jokerβ„’, oanm2000
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1388
06-20-2017, 05:45 PM
AASHTO LRFD Bridge Construction Specifications (3rd Edition) with 2010, 2011, 2012, 2014, 2015 and 2016 Interim Revisions
  β€’ jokerβ„’, amindoxiti, oanm2000, Dell_Brett, spat, kowheng
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
01-25-2022, 10:29 AM
Knowel AASHTO LRFD Bridge Construction Specifications (3rd Edition) with 2010, 2011, 2012, 2014, 2015 and 2016 Interim Revisions
| Size: 13.8 MB| Format: PDF| Quality: Original preprint| Publisher: AASHTO| Year: 2016| pages: 696
This broadly recognized national standard to design and construct bridges has been revised to be consistent with its companion, the recently updated AASHTO LRFD Bridge Design Specifications. Among the revisions are improved testing and acceptance criteria, updated material references, and recommended guidelines for construction loads. Included in this electronic edition are the 2010, 2011, 2012, 2014, 2015 and 2016 Interim Revisions. Following each chapter the revisions are identified as well as linked throughout the entire book where available. See the "Interim Revisions 2010, 2011, 2012, 2014 2015 and 2016" sections for a complete list of changes to each section.
  β€’ Aviator, babakfeyzi, Dell_Brett, oanm2000
 i_kabir
Bangladesh
User ID: 741
Threads: 122
Likes: 3,231 in 259 posts
Given Likes: 446
02-09-2022, 09:14 AM
AASHTO LRFD Bridge Construction Specifications (4th Edition)
Author(s)/Editor(s): AASHTO | Size: 11.4 MB| Format: PDF| Quality: Scanner (OCR)| Publisher: AASHTO| Year: 2017| pages: 607 | ISBN: 9781560516668
[Image: 47993635125795524127.png]
The AASHTO LRFD Bridge Construction Specifications are intended for use in the construction of bridges. The specifications employ the Load and Resistance Factor Design (LRFD) methodology, and are designed to be used in conjunction with the AASHTO LRFD Bridge Design Specifications. Revisions from the 3rd edition of this title include a complete revision of Section 3, Temporary Works, and changes to Section 10, Prestressing; Section 11, Steel Structures; Section 19, Bridge Deck Joint Seals; and Section 27, Concrete Culverts.
[-] The following 12 users Like i_kabir's post:12 users Like i_kabir's post
  β€’ Dell_Brett, carolinandra, cheosmith, Aviator, babakfeyzi, oanm2000, tomtumx, jcbv, subin91, cace-01, Administrator , kowheng
  AASHTO LRFD Bridge Design Specifications 10th edition pezhmankhan 3 9,397 02-01-2025, 08:35 AM
  AASHTO M351: Standard Specification for Cotton Duck Fabric Bridge Bearings, poolmand 0 3,193 01-15-2024, 08:42 AM
  AASHTO LRFD Bridge Design Guide Specifications for GFRP-Reinforced Concrete poolmand 0 3,213 08-30-2023, 08:45 AM
  AASHTO Manual for Bridge Element Inspection carolinandra 1 3,956 01-25-2022, 11:46 AM
  AASHTO - Standard Specifications for Structural Supports for Highway Signs, Luminaire jamildear4u 6 7,738 01-25-2022, 10:57 AM
  AASHTO/AWS D1.5M/D1.5: Bridge Welding Code anfaga 4 3,768 01-25-2022, 10:47 AM
  AASHTO - Standard Specifications for Transportation Materials and Methods of Sampling ir_71 5 6,781 01-25-2022, 10:20 AM
