09-21-2009, 04:25 AM
Symplectic Elasticity
![[Image: 4ekhxzm42u8sc04ilyea.jpeg]](https://pic.civilea.com/images/4ekhxzm42u8sc04ilyea.jpeg)
Weian Yao, Wanxie Zhong, Chee Wah Lim "Symplectic Elasticity"
World Scientific Publishing Company | English | 2009-02-26 | ISBN: 9812778705 | 316 pages | PDF | 3 MB
Solid mechanics problems have long been regarded as bottlenecks in the development of elasticity. In contrast to traditional solution methodologies, such as Timoshenko s theory of elasticity for which the main technique is the semi-inverse method, this book presents a new approach based on the Hamiltonian principle and the symplectic duality system where solutions are derived in a rational manner in the symplectic space. Departing from the conventional Euclidean space with one kind of variable, the symplectic space with dual variables thus provides a fundamental breakthrough.
This book explains the new solution methodology by discussing plane isotropic elasticity, multiple layered plate, anisotropic elasticity, sectorial plate and thin plate bending problems in some detail. A number of existing problems without analytical solutions within the framework of classical approaches are solved analytically using this symplectic approach. Symplectic methodologies can be applied not only to problems in elasticity, but also to other solid mechanics problems. In addition, it can also be extended to various engineering mechanics and mathematical physics fields, such as vibration, wave propagation, control theory, electromagnetism and quantum mechanics.
Contents: Mathematical Preliminaries; Fundamental Equations of Elasticity and Variational Principle; The Timoshenko Beam Theory and Its Extension; Plane Elasticity in Rectangular Coordinates; Plane Anisotropic Elasticity Problems; Saint Venant Problems for Laminated Composite Plates; Solutions for Plane Elasticity in Polar Coordinates; Hamiltonian System for Bending of Thin Plates.
Download Links:
π CLICK HERE π
