Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM C876-09 Standard Test Method for Corrosion Potentials of Uncoated Reinforcing St
 miquan
Vietnam
User ID: 631
Threads: 171
Likes: 3,748 in 387 posts
Given Likes: 1331
08-09-2012, 12:11 AM
ASTM C876-09 Standard Test Method for Corrosion Potentials of Uncoated Reinforcing Steel in Concrete
Author: ASTM | Size: 1 MB | Format: PDF | Quality: Original preprint | Publisher: ASTM | Year: 2009 | pages: 7
This test method covers the estimation of the electrical
corrosion potential of uncoated reinforcing steel in field and
laboratory concrete, for the purpose of determining the corrosion
activity of the reinforcing steel.
[-] The following 12 users Like miquan's post:12 users Like miquan's post
  â€¢ kowheng, st77bel, malc, Jackass, ir_71, utan, lisine, peixoto, toa011, Tulanh, pram, sacem
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 3,102 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,433 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 3,216 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 3,273 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,490 11-12-2023, 08:07 AM
  STM D6927: Standard Test Method for Marshall Stability and Flow of Asphalt Mixtures poolmand 0 3,077 11-04-2023, 10:57 AM
