Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM D2850 – 03a Standard Test Method for Unconsolidated-Undrained Triaxial Compre...
 portal61
Indonesia
User ID: 12856
Threads: 66
Likes: 855 in 90 posts
Given Likes: 223
02-14-2012, 12:10 PM
ASTM D2850 – 03a Standard Test Method for Unconsolidated-Undrained Triaxial Compression Test on Cohesive Soils
Size: 132 KB | Format: PDF | Quality: Original preprint | Year: 2007 | pages: 6
[Image: unconsolidated.jpg]
This test method covers determination of the strength and stress-strain relationships of a cylindrical specimen of either undisturbed or remolded cohesive soil. Specimens are subjected to a confining fluid pressure in a triaxial chamber. No drainage of the specimen is permitted during the test. The specimen is sheared in compression without drainage at a constant rate of axial deformation (strain controlled).
[-] The following 6 users Like portal61's post:6 users Like portal61's post
  • kowheng, Jackass, mybest, Dell_Brett, utan, nhim4mat2006
 khanhutc
User ID: 33375
Likes: 0 in 0 posts
Given Likes: 1
12-31-2012, 07:46 AM
Dead link, please re upload
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 3,101 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,431 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 3,214 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 3,272 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,490 11-12-2023, 08:07 AM
  STM D6927: Standard Test Method for Marshall Stability and Flow of Asphalt Mixtures poolmand 0 3,074 11-04-2023, 10:57 AM
