Civil Engineering Association eBooks Structural Books Steel Flexural-Torsional Buckling of Structures - by N. S. Trahair
 cordoba123
User ID: 1196
Threads: 221
Likes: 5,490 in 485 posts
Given Likes: 1618
10-30-2011, 10:08 PM (This post was last modified: 02-24-2013, 05:38 PM by usman.)
New Directions in Civil Engineering
Author: N. S. Trahair | Size: 27.88 MB | Format: PDF | Publisher: E & FN Spon | Year: July 20, 1993 | pages: 382 | ISBN: ISBN-10: 0849377633 ; ISBN-13: 978-0849377631
[Image: 37590121582121184919.jpg]
Flexural-Torsional Buckling of Structures provides an up-to-date, comprehensive treatment of flexural-torsional buckling and demonstrates how to design against this mode of failure. The author first explains the fundamentals of this type of buckling behavior and then summarizes results that will be of use to designers and researchers in either equation or graphical form. This approach makes the book an ideal text/reference for students in structural engineering as well as for practicing civil engineers, structural engineers, and constructional steel researchers and designers.
The book begins by introducing the modern development of the theory of flexural-torsional buckling through discussions on the general concepts of equilibrium, total potential, virtual work, and buckling. It then continues with in-depth coverage of hand methods for solving buckling problems, the analysis of flexural-torsional buckling using the finite element method, and the buckling of different types of structural elements and frames composed of various elastic materials. Other topics addressed include the design and inelastic buckling of steel members. The book's final chapter considers a collection of special topics.
following review helpful:
A great reference, January 15, 2000
This is a must-have reference for researchers and engineers in the field of structural stability. Particular emphasis is made on Flexural Torsional Buckling of planar frames and arches under in-plane loads.
The book is well organized and extremely well written by one of the renowned experts in the field. Extensive summary of benchmarking solutions including recent ones is given in each chapter. I would rate this book at the same level as the distinguished titles: "Theory of Beam-Column (1977)" by Chen and Atsuta, and "Guide to Stability Design Criteria for Metal Structures (5th edition, 1998)" by Galambos.
Mirror:
[-] The following 40 users Like cordoba123's post:40 users Like cordoba123's post
  • 3fan, Dell_Brett, carolinandra, shanta, sodapas, kowheng, ting tsai huang, miquan, dinu69in, malc, kvtasp, subin91, Jackass, foxxx2010, zrilek, knrsa, LiviuM, orambo, monter, iluso81, Nilupa, baikur, kasiphonk, amrizal, parhyang, jcbv, saiwal, WangJiangchaocn, Nim., ranui30, mahyarov, apocalipse, Hengki, eng donny, lisine, peixoto, asim99, levanduy, xyxtof, AYODINA
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
02-24-2013, 03:54 PM
Direct link;
[-] The following 22 users Like ssobhan's post:22 users Like ssobhan's post
  • slowet, devilmaycry, jcbv, hernansgz, jackpotjoe, ibg0203, gulilero, eng donny, lisine, peixoto, Dell_Brett, asim99, stigtg, cristi, adams, xyxtof, rfireman, zrilek, ruaumoko, blaze, Mohammad6299, PinkPant
 amindoxiti
User ID: 86739
Threads: 203
Likes: 8,341 in 584 posts
Given Likes: 2618
12-19-2014, 05:16 PM
Do not worry about your difficulties in Mathematics, I can assure you mine are still greater.  -Albert Einstein
[-] The following 10 users Like amindoxiti's post:10 users Like amindoxiti's post
  • bridgeengineer, blaze, Mohammad6299, levanduy, malc, zrilek, PinkPant, Dell_Brett, chairatpk, xpressmusic
  The Behaviour and Design of Steel-Structures to BS5950 trahair bradford nethercot 3rd sabooryan 0 1,763 05-16-2018, 09:49 AM
Last Post: sabooryan
  Experimental Methods in Buckling of Thin-Walled Structures - Vol. 2 arsace82 2 2,565 10-23-2014, 03:24 PM
Last Post: r3be1
  Lateral torsional buckling of channel sections baikur 2 3,582 10-07-2011, 10:44 PM
Last Post: amareen2000
