Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 508:2008 Roofing products from metal sheet - Specification for selfsupporting prod
10-16-2011, 10:02 AM
EN 508:2008 Roofing products from metal sheet - Specification for selfsupporting products of steel, aluminium or stainless steel sheet
Author: CEN/TC 128 | Size: 0.5 MB | Format: PDF | Publisher: CEN | Year: 2008 | pages: 46
[Image: 01787371095142608675.jpg]
This Part of EN 508 specifies requirements for self-supporting roofing products for discontinuous laying made from metallic coated steel sheet with or without additional organic coatings. The standard establishes general characteristics, definitions, classifications and labelling for the products, together with requirements for the materials from which the products can be manufactured. It is intended to be used either by manufacturers to ensure that their products comply with the requirements or by purchasers to verify that the products comply when purchased before they are despatched from the factory. It specifies the requirements for products which enable them to meet all normal service conditions. The standard applies to all discontinuously laid self-supporting external profiled sheets for roofing with the exception of tiles with a surface area less than 1 m2 and produced by stamping. These profiled roof sheets are designed to keep wind, rain and snow out of the building and to transfer any resultant loads and infrequent maintenance loads to the structure. No requirements for supporting construction, design of roof system and execution of connections and flashings are included.
  â€¢ toa011, Jackass, blaze, zrilek, malc, kowheng, ting tsai huang, peixoto, dizz
10-16-2011, 02:17 PM (This post was last modified: 06-11-2013, 01:33 PM by mybest.)
EN 508-2:2008 Roofing products from metal sheet - Specification for selfsupporting products of steel, aluminium or stainless steel sheet - Part 2: Aluminium
[Image: 88571933905620742506.jpg]
This part of EN 508 specifies requirements for self-supporting roofing products for discontinuous laying made from aluminium sheet with or without additional organic coatings. The standard establishes general characteristics, definitions, classifications and labelling for the products, together with requirements for the materials from which the products can be manufactured. It is intended to be used either by manufacturers to ensure that their products comply with the requirements or by purchasers to verify that the products comply before they are despatched from the factory. It specifies the requirements for products which enable them to meet all normal service conditions. The standard applies to all discontinuously laid self-supporting external profiled sheets for roofing. These profiled roof sheets are designed to keep wind, rain and snow out of the building, and to transfer any resultant loads and infrequent maintenance loads to the structure. No requirements for supporting construction, design of roof system and execution of connections and flashings are included.
EN 208-3:2008 Roofing products from metal sheet - Specification for selfsupporting products of steel, aluminium or stainless steel sheet - Part 3: Stainless steel
Author: CEN/TC 128 | Size: 0.5 MB | Format: PDF | Publisher: CEN | Year: 2008 | pages: 38
[Image: 14895050317403770505.jpg]
This Part of EN 508 specifies requirements for self-supporting roofing products for discontinuous laying made from stainless steel sheet with or without additional metallic and/or organic coatings. The standard establishes general characteristics, definitions, classifications and labelling for the products, together with requirements for the materials from which the products can be manufactured. It is intended to be used either by manufacturers to ensure that their products comply with the requirements or by purchasers to verify that the products comply before they are despatched from the factory. It specifies the requirements for products which enable them to meet all normal service conditions. The standard applies to all discontinuously laid self-supporting external profiled sheets for roofing with the exception of tiles with a surface area less than 1 m2 and produced by stamping. These profiled roof sheets are designed to keep wind, rain and snow out of the building and to transfer any resultant loads and infrequent maintenance loads to the structure. No requirements for supporting construction, design of roof system and execution of connections and flashings are included.
  â€¢ 3fan, Vladimir, zrilek, Dell_Brett, malc, kowheng, Jackass, avge
 Jackass
Bolivia
User ID: 29460
Threads: 24
Likes: 1,138 in 115 posts
Given Likes: 7399
06-11-2013, 10:48 AM
Hi
New link above EN 508 Part 1,2,3
Pass:www.civilea.com
[-] The following 4 users Like Jackass's post:4 users Like Jackass's post
  â€¢ st77bel, isurya, andersen3, peixoto
  EN 15629:2008 Steel static storage systems - Specification of storage equipment ir_71 0 2,115 01-01-2011, 08:37 PM
