Civil Engineering Association eBooks Codes, Manual & Handbook MBMA: Metal Building Systems Manual
 rohailiyaz
User ID: 925
Threads: 104
Likes: 1,152 in 117 posts
Given Likes: 733
08-18-2009, 04:57 AM (This post was last modified: 07-21-2019, 03:05 PM by usman. Edit Reason: N/A )
MBMA 2006 Manual
[Image: 42786033756805381575.jpg]
The MBMA Metal Building Systems Manual incorporates the results of research undertaken by MBMA, its member companies and other industry groups. In many respects, it reflects refinement and advances in the knowledge of load application methods and design. This edition of the Metal Building Systems Manual replaces the 2002 edition, and its release coincides with the 50th anniversary of the Metal Building Manufacturers Association
[-] The following 46 users Like rohailiyaz's post:46 users Like rohailiyaz's post
  â€¢ kowheng, kowheng, zrilek, zrilek, haze, haze, yucapareja, yucapareja, nuttapolk, nuttapolk, struceng, struceng, Panjack39, Panjack39, Ultra Zone, Ultra Zone, oanm2000, oanm2000, goober, goober, tomtumx, tomtumx, chenamoy, chenamoy, Alexander, blackjack, napeera, pokycute, Dell_Brett, 2d.agen, RICARDI, mastermind, ssi3k, dinu69in, dovsky, malc, maad59, toa011, lasalleguy, blaze, gulilero, Mouh@ndiss, mowafi3m, Clouseau, jcbv, bigone
 muralihare
User ID: 28976
Threads: 12
Likes: 64 in 12 posts
Given Likes: 16
02-17-2011, 04:15 PM
Metal building design systems manual -2010
Author: MBMA | Size: 862 KB | Format: PDF | Publisher: MBMA | Year: 2010 | pages: 73
Latest manual for metal building design by Metal building manufacturers Association.Actually it is a supplement t0 2006 manual.
[-] The following 23 users Like muralihare's post:23 users Like muralihare's post
  â€¢ jayborre, vardan, zrilek, usman, blaze, dinu69in, pedzaquino, oanm2000, malc, jjmtz, faros3000, haze, orambo, yutt, kowheng, toa011, taifur, slowet, bigone, oram, engrirfan, ting tsai huang, Mohammad6299
 muqiang
User ID: 11680
Threads: 2
Likes: 19 in 4 posts
Given Likes: 2
03-18-2011, 12:33 PM (This post was last modified: 03-18-2011, 01:04 PM by kowheng.)
the above link given wrong files,not MBMA2006,It is a story
Moderator Notes:
You were warned for posting transparent link. Before making further posts and to avoid new warning points, please read those:
and especially this:
[-] The following 4 users Like muqiang's post:4 users Like muqiang's post
  â€¢ shaqee, oanm2000, slowet, bigone
 mowafi3m
Egypt
User ID: 1236
Threads: 385
Likes: 9,324 in 678 posts
Given Likes: 1667
03-18-2011, 08:32 PM
Mirror
[-] The following 10 users Like mowafi3m's post:10 users Like mowafi3m's post
  â€¢ handresy, hcardenas, Clouseau, usman, haze, kowheng, oanm2000, monter, bigone, fbx_rdnk
 kamba911
User ID: 1967
Threads: 10
Likes: 94 in 15 posts
Given Likes: 17
03-19-2011, 06:32 AM
the official download link (for free)
[-] The following 12 users Like kamba911's post:12 users Like kamba911's post
  â€¢ kowheng, zrilek, ascetic19, seriousboy, oanm2000, monter, slowet, nowanda, bigone, oram, jcbv, Mohammad6299
 febo927
User ID: 23688
Threads: 105
Likes: 4,179 in 339 posts
Given Likes: 1279
11-27-2018, 05:05 PM
Metal Building Systems Manual - 2012 Edition
Author(s)/Editor(s): Metal Building Manufacturers Association, Inc. | Size: 13 MB | Format: PDF | Quality: Original preprint | Publisher: Metal Building Manufacturers Association, Inc. | Year: 2012 | pages: 724 | ISBN: -
[Image: 04517093777294960513.jpg]
The 2012 Metal Building Systems Manual includes:
Step-by-step examples for calculating wind, snow and seismic design loads per the 2012 International Building Code (IBC) and referenced ASCE 7-2010 standard, along with designing roof drainage systems for metal buildings, per the 2012 International Plumbing Code (IPC).
A guide for the determination of loads for metal buildings with bridge, monorail, jib and single-leg gantry for underhung and top-running cranes.
Recommended drift and deflection criteria for the design of metal buildings that use masonry, metal and other wall systems, including manufacturing and erection tolerances.
Common Industry Practices that spell out all current practices relating to design, manufacture, sale and erection for metal building systems, including contract, order documents and engineer of record.
Seventeen code-compliant, fire-rated construction (column, wall, roof and joint details) details specifically tailored for metal building systems.
Wind, snow, seismic and rainfall design data tabulated for every U.S. county based on the 2012 IBC, ASCE 7-10, USGS and NOAA data - you won't find this anywhere else!
[-] The following 51 users Like febo927's post:51 users Like febo927's post
  â€¢ blaze, jcbv, frank1972, pontiac, Nita1391, carolinandra, amindoxiti, mgdario, gulilero, rami1976, malee, tomtumx, milova, munycamsec, ali akbar, pedzaquino, hatkam, zrilek, PinkPant, tuanpecc1, cace-01, avge, vvvv, simanta, Aviator, dinu69in, oanm2000, promo8, subin91, temp1366, Veggeta, malc, emmi, Andrew seah, melekeen, psppsp, Wijono, Dell_Brett, levanduy, ralarcon, karthikeyans3d, rendel_©, cristi, kowheng, monter, lasalleguy, yutt, usman, shaker, zego2000, bigone
 malee
User ID: 554
Threads: 20
Likes: 1,358 in 98 posts
Given Likes: 267
07-20-2019, 02:52 AM (This post was last modified: 07-20-2019, 02:53 AM by malee. Edit Reason: N/A )
MBMA 2012
[-] The following 23 users Like malee's post:23 users Like malee's post
  â€¢ 88FeNIX, jcbv, Dell_Brett, PinkPant, Andrew seah, CAMSECT, chenamoy, promo8, cace-01, chandra1234567, oanm2000, moh_towhid, bigone, Umer.Aleem, limberjmc, simanta, blaze, pedzaquino, jonygut, Wijono, caifan, kowheng, inge911
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
08-04-2021, 08:47 AM
MBMA 2012
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 7 users Like poolmand's post:7 users Like poolmand's post
  â€¢ cace-01, Dell_Brett, rami1976, jonygut, PinkPant, Administrator , oanm2000
Threads: 758
Given Likes: 91
11-03-2024, 10:01 AM
Metal Building Systems Manual - 2018 Edition
| Size: 15.58 MB| Format: PDF| Quality: Original preprint| Publisher: MBMA| Year: 2018
[Image: 98529707888997428713.png]
  â€¢ babakfeyzi, tomtumx, amindoxiti, spiderthan, thulasiramsm
  MBMA: Metal Roofing Systems Design Manual - 2000 struceng 3 4,978 07-21-2019, 01:02 PM
Last Post: Nita1391
  NAAMM 531-00: Metal Bar Grating Manual aflv 1 2,954 10-20-2009, 03:03 PM
Last Post: concreteok
