Civil Engineering Association eBooks Structural Books Steel Builders’ Guide to Residential Steel Floors
Threads: 1,298
06-14-2011, 05:00 AM
Size: 1.5 MB | Format: PDF | Publisher: US H.U.D. | Year: 2001 | pages: 104
[Image: 49860879273255558656.jpg]
The Builders Guide to Residential Steel Floors is provided as a guideline to facilitate the appropriate use of cold-formed steel floor framing in the construction of conventional one- and two-family residential dwellings, townhouses, and multifamily dwellings. The provisions in this document were developed by applying accepted engineering practices, test results of steel floor assemblies, and other published reports, technical bulletins, and manufacturer data. However, users of this document should verify its compliance with local code requirements and seek any necessary regulatory approvals prior to use. The user is advised to refer to applicable building code requirements for technical issues beyond the scope of this document and when engineered design is called out. The first three chapters of this document provide an overview of cold-formed steel framing, including its advantages, technical resources, tools and fasteners, and material properties. The overview has many helpful tips and guidance, particularly for first timers. Builders and contractors must understand the strengths and weaknesses of the material they are using. They must also know how to cut, trim, measure, mark, and install steel framing members. Steel framers must know how to order steel members, how to select the proper tools, and how to fasten framing members together. While many of these considerations are best learned by practice, the transition between wood and steel floor framing can be rather easy with the proper guidance and planning.
Chapters 4 and 5 of this document describe how to construct cold-formed steel floors and related sub-trade installations. Chapter 6 provides general recommendations and construction guidelines that are gathered from experienced steel framers. The intent of that chapter is to provide steel framers with good practices that could save them time, material, and frustration.
[-] The following 37 users Like ir_71's post:37 users Like ir_71's post
  • araza023, pedzaquino, jcbv, Jackass, kowheng, Dell_Brett, vvvv, theanhpe, malc, toa011, seriousboy, oanm2000, jjmtz, isurya, Trishu999, jferrer, subin91, cristi, yutt, Clouseau, monter, dbsimon29, kmmh76, kvtasp, blaze, lednar_ved, mastermind, knrsa, slowet, ting tsai huang, chenamoy, nuttapolk, Pinkto, Nilupa, kerenski_t, julioreptil, baikur
 kvtasp
User ID: 7690
Threads: 69
Likes: 2,028 in 379 posts
Given Likes: 791
12-14-2011, 03:13 PM
[-] The following 1 user Likes kvtasp's post:1 user Likes kvtasp's post
  • Dell_Brett
  SCI P076: Design guide on the vibration of floors choonguan 4 4,927 08-04-2021, 08:33 AM
  SCI P332: Steel in Multi-Storey Residential Buildings ir_71 5 4,648 06-17-2015, 04:42 AM
Last Post: f_slikken
  SCI - Durability of Light Steel Framing in Residential Building joradu 3 3,297 08-24-2014, 08:33 AM
Last Post: pram
  Prescriptive Method For Residential Cold-Formed Steel Framing Year 2000 Edition ir_71 1 2,368 09-02-2012, 05:55 AM
  Cold Formed Steel in Residential Construction.ppt Kurucz 0 2,321 12-18-2010, 07:09 PM
Last Post: Kurucz
