Civil Engineering Association eBooks Structural Books Steel SCI RT1187 Guidance on the Fire Protection of Beams with Web Openings
Threads: 1,298
04-28-2011, 11:12 AM
Author: Dr W I Simms | Size: 0.58 MB | Format: PDF | Publisher: SCI | Year: 2008 | pages: 59
[Image: 96592157974230241808.jpg]
This report provides details of the assessment methodology and calculation procedure adopted by SCI to produce tables of limiting temperature for individual intumescent coatings based on thermal performance demonstrated by testing and assessment in accordance with the ASFP protocol for beams with web openings. A description of the structural calculation model is provided, including the method of automatically generating beam geometries and the thermal model used to determine the temperature variation on the cross section of beams with web openings. The report also includes a worked example to illustrate the calculation procedure required for a single value of limiting temperature given in the design tables supplied to intumescent manufacturers.
  • kowheng, seriousboy, 3fan, tluc, Jackass, zrilek, jferrer, oanm2000, malc, toa011, Dell_Brett, vvvv, sodapas, jcbv, kmmh76, ting tsai huang, lisine, blaze, chenamoy, avge, Nilupa, portal61, warbeast, asim99
 kvtasp
User ID: 7690
Threads: 69
Likes: 2,028 in 379 posts
Given Likes: 791
12-12-2011, 02:45 AM (This post was last modified: 02-21-2013, 09:19 AM by 3fan.)
[-] The following 2 users Like kvtasp's post:2 users Like kvtasp's post
  • Dell_Brett, asim99
Threads: 54
02-21-2013, 09:05 AM
links dead; reposted here:
password
  • Jackass, slowet, Dell_Brett, arshiakh, warbeast, asim99
  SCI P068 Design for openings in the webs of composite beams andersen3 2 2,898 04-10-2014, 12:10 PM
  SCI P355 Design of composite beams with large web openings andersen3 0 1,784 01-09-2013, 06:39 AM
  SCI P186: Design of Steel Framed Buildings without Applied fire Protection mowafi3m 1 3,031 01-17-2011, 07:09 AM
