04-24-2011, 10:29 PM
Floor loading in warehouses: a review
Author: Armitage, J. S. and Judge, C. J. | Size: 2.74 MB | Format: PDF | Year: 1987 | pages: 24 | ISBN: 9780851252476
Abstract
Identifies the different types of storage and materials-handling systems currently in use and gives examples of actual loads and pressures that may be imposed on the floor. It includes data on loads and pressures from different storage systems and from a range of trucks and handling equipment. It concludes that there is such a large variability in possible loads in warehouses that the use of a single minimum imposed load in design could result in a significant proportion of warehouses being either excessively expensive or structurally inadequate. It recommends that the current values in codes should be reviewed and that consideration should be given to defining responsibilities for the safe operation and loading of warehouses
