Civil Engineering Association eBooks Structural Books Steel SHS Design to BS 5950 Part 1
Threads: 1,298
04-02-2011, 02:47 PM
Author: British Steel | Size: 14.3 MB | Format: PDF | Publisher: BSI | Year: 1999 | pages: 55
[Image: 18296802141937924535.jpg]
This brochure has been produced to assist Structural Engineers and Designers who use Hot finished Structural Hollow Sections whose section properties comply with BS 4848 : Part 2 (Ref 1) and whose Steel qualities comply with EN 102 10-l (Ref 2) to design using the Limit State basis as covered by BS 5950 : Part 1 (Ref 3).
It is important for designers to recognise that hollow sections, unlike their rolled open section counterparts, can be produced by a hot or cold forming process. The process of cold forming produces different mechanical properties in the section to that of hot forming and a reduction in the sectional properties used in design.
Designers wishing to use cold formed hollow sections should design in accordance with the appropriate cold formed standard and with the sectional properties as given in BS 6363 (Ref 4). Further guidance is given in British Steels Tubes & Pipes publication TD369 - ‘Cold Formed Hollow Sections’. In addition to the information contained in this publication, further assistance and design guidance is given in companion British Steel Tubes & Pipes publications (references 16 to 21) and the Steel Construction Institute (references 8 to 15) publications as given in Appendix A.
[-] The following 22 users Like ir_71's post:22 users Like ir_71's post
  • kowheng, melkat, hmwere, seriousboy, zrilek, knrsa, nowanda, nuttapolk, oanm2000, sheb101, chenamoy, Gabemzaman, parwez007, lirizen, monter, kmmh76, Nilupa, baikur, wahta, warbeast, vvvv, ykhackhack
Threads: 54
11-22-2012, 05:47 AM
all links dead; mirror
password
[-] The following 10 users Like andersen3's post:10 users Like andersen3's post
  • Andrew seah, blaze, subin91, vvvv, Dell_Brett, Jackass, Trishu999, malc, ykhackhack, slowet
 yanburak
User ID: 27551
Threads: 93
Likes: 821 in 94 posts
Given Likes: 421
03-31-2014, 08:52 PM
all links dead
can anyone upload it
  Plastic Design to BS 5950 robertsas 2 3,241 12-17-2014, 03:38 AM
  SCI P080: Fire resistant design of steel structures - A handbook to BS 5950: Part 8 ir_71 2 2,874 05-14-2014, 05:33 AM
  SCI P326: Steelwork Design Guide to BS 5950-1 2000 6Ed username123 3 4,772 02-18-2014, 10:00 AM
Last Post: vinnunsam
  Steelwork Design Guide to BS 5950-1: 2000 jmpkumara 2 3,715 02-18-2014, 09:43 AM
  SCI P304 Guide to the major amendments in BS 5950-1:2000 ir_71 2 2,571 12-18-2013, 11:41 AM
Last Post: bigone
  SCI P325: Introduction to Steelwork Design to BS 5950-1:2000 ir_71 1 2,211 11-15-2012, 03:34 PM
  Design of single-span steel portal frames to BS 5950 sheb101 2 3,503 01-28-2012, 09:19 PM
Last Post: joker™
