Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 1092 Flanges and their joints — Circular flanges for pipes, valves, fittings and a
03-01-2011, 11:05 AM (This post was last modified: 03-01-2011, 11:12 AM by ir_71.)
EN 1092 Flanges and their joints — Circular flanges for pipes, valves, fittings and accessories, PN designated
Author: CEN/TC 74 | Size: 1.92 MB | Format: PDF | Publisher: CEN | Year: 2007 | pages: 126
[Image: 72894883831202562652.jpg]
This European Standard for a single series of flanges specifies requirements for circular steel flanges in PN designations PN 2,5 to PN 400 and nominal sizes from DN 10 to DN 4000. This European Standard specifies the flange types and their facings, dimensions, tolerances, threading, bolt sizes, flange jointing face surface finish, marking, materials, pressure/ temperature ratings and approximate flange masses. For the purpose of this European Standard, "flanges" include also lapped ends and collars. This European Standard applies to flanges manufactured in accordance with the methods described in Table 1. Non-gasketed pipe joints are outside the scope of this European Standard.
EN 1092 - 2
EN 1092 - 3
EN 1092 - 4
  • kowheng, Grunf, toa011, zrilek, jcbv, oanm2000, Clouseau
 PinkPant
Turkey
User ID: 25448
Threads: 67
Likes: 4,007 in 374 posts
Given Likes: 10354
05-14-2015, 01:50 PM
BS EN 1092-1:2007+A1:2013 Flanges and their joints. Circular flanges for pipes, valves, fittings and accessories, PN designated. Steel flanges
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
BS EN 1092-2:1997 Flanges and their joints. Circular flanges for pipes, valves, fittings and accessories, PN designated. Cast iron flanges
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
BS EN 1092-3:2003 Flanges and their joints. Circular flanges for pipes, valves, fittings and accessories, PN designated. Copper alloy flanges
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
BS EN 1092-4:2002 Flanges and their joints. Circular flanges for pipes, valves, fittings and accessories, PN designated. Aluminium alloy flanges
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
PinkPant
[-] The following 13 users Like PinkPant's post:13 users Like PinkPant's post
  • zrilek, PanosP, dinu69in, amindoxiti, oanm2000, Dell_Brett, Munykong, titko, vvvv, peixoto, Jackass, malc, Trishu999
  EN 1916 Concrete pipes and fittings, unreinforced, steel fibre and reinforced datagap 4 5,622 02-13-2022, 11:44 AM
  EN 545:2010 Ductile iron pipes, fittings, accessories and their joints for water pipe ir_71 2 3,392 07-17-2014, 08:36 AM
