Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 10204:2004 Metallic products - Types of inspection documents
Threads: 1,298
01-23-2011, 07:43 AM
Author: ECISS/TC 100 | Size: 0.18 MB | Format: PDF | Publisher: CEN | Year: 2004 | pages: 10
[Image: 19056818634988924044.jpg]
1.1 This document specifies the different types of inspection documents supplied to the purchaser, in
accordance with the requirements of the order, for the delivery of all metallic products e.g. plates, sheets, bars,
forgings, castings, whatever their method of production.
1.2 This document may also apply to non-metallic products.
1.3 This document is used in conjunction with the product specifications which specify the technical delivery
conditions of the products.
NOTE 1 The list of information that may be included in the inspection documents can be found in appropriate documents, e.g.
EN 10168 for steel.
NOTE 2 Annex A gives a summary of the different inspection documents.
  • kowheng, Grunf, jcbv, cordoba123, toa011, Dell_Brett, shaqee, oanm2000, usman, roaming79, zrilek, vvvv, oyabun
Threads: 1,298
04-11-2014, 04:33 AM
  • Mohammad6299, englandboy, PinkPant, jcbv, vvvv, Dell_Brett
  EN 13369:2004 (Common rules for precast concrete products) raffah 2 3,522 03-07-2018, 01:53 PM
  EN 12843:2004 Precast concrete products - Masts and poles ir_71 3 3,794 01-24-2015, 01:19 AM
Last Post: concreteok
  EN 10244 Standard Series Steel wire and wire products - Non-ferrous metallic coatings ir_71 1 2,663 06-07-2013, 07:04 AM
  EN 10168:2004 Steel products - Inspection documents - List of information and descrip ir_71 0 2,256 01-23-2011, 07:37 AM
  EN 13636:2004 Cathodic protection of buried metallic tanks and related piping ir_71 0 1,990 12-04-2010, 07:37 AM
