Civil Engineering Association eBooks Structural Books Concrete Time-Dependent Behaviour of Concrete Structures
01-21-2011, 06:59 PM (This post was last modified: 10-29-2011, 11:02 PM by Dell_Brett.)
Author: Raymond Ian Gilbert, Gianluca Ranzi | Size: 2.74 MB | Format: PDF | Publisher: Spon Press | Year: 2010 | pages: 447 | ISBN: 0415493846
[Image: 97298811034833640616.jpg]
Description
Serviceability failures of concrete structures involving excessive cracking or deflection are relatively common, even in structures that comply with code requirements. This is often as a result of a failure to adequately account for the time-dependent deformations of concrete in the design of the structure. The serviceability provisions embodied in codes of practice are relatively crude and, in some situations, unreliable and do not adequately model the in-service behaviour of structures. In particular, they fail to adequately account for the effects of creep and shrinkage of the concrete. Design for serviceability is complicated by the non-linear and inelastic behaviour of concrete at service loads.
Providing detailed information, this book helps engineers to rationally predict the time-varying deformation of concrete structures under typical in-service conditions. It gives analytical methods to help anticipate time-dependent cracking, the gradual change in tension stiffening with time, creep induced deformations and the load independent strains caused by shrinkage and temperature changes. The calculation procedures are illustrated with many worked examples.
A vital guide for practising engineers and advanced students of structural engineering on the design of concrete structures for serviceability and provides a penetrating insight into the time-dependent behaviour of reinforced and prestressed concrete structures.
Content:
1. Time-Dependent Deformation 2. Material Properies 3. Design for Serviceability – Deflection and Crack Control 4. Uncracked Sections – Axial Loading 5. Uncracked Sections – Axial Force and Uniaxial Bending 6. Uncracked Sections – Axial Force and Biaxial Bending 7. Cracked Sections 8. Members and Structures 9. Stiffness Method and Finite Element Modelling. Appendix: Analytical Formulations – Euler-Bernoulli Beam Model
[-] The following 50 users Like ir_71's post:50 users Like ir_71's post
  • giga, melkat, majkyy, oanm2000, diseñador, usman, vardan, Dell_Brett, kowheng, faros3000, chenamoy, sujups, orambo, mgdario, salahcivil, ladjin, iceman84, Djulaiman, HASH007, sodapas, jf28, Clouseau, diotviet, zrilek, cristi, Nilupa, toa011, spiderthan, jcbv, malc, civilphongvan, yutt, vvvv, bhawk0, foxxx2010, subin91, peixoto, bigone, Umer.Aleem, rkce, cx_oem, blaze, gulilero, jfjdm, dersaar, batata666, jgarciafic, jafi, rezart, tuanpecc1
 sodapas
Indonesia
User ID: 1004
Threads: 58
Likes: 856 in 83 posts
Given Likes: 4073
05-27-2011, 05:51 PM (This post was last modified: 05-27-2011, 06:19 PM by Dell_Brett.)
[-] The following 16 users Like sodapas's post:16 users Like sodapas's post
  • zrilek, seriousboy, toa011, kg85arun, theanhpe, civilphongvan, blaze, bhawk0, Hengki, foxxx2010, user108, Nilupa, Dell_Brett, batata666, ibg0203, rezart
 junaid
User ID: 402
Threads: 197
Likes: 8,170 in 732 posts
Given Likes: 983
10-29-2011, 06:50 PM
Other Links:
[-] The following 7 users Like junaid's post:7 users Like junaid's post
  • Dell_Brett, ssobhan, Jackass, zrilek, lisine, blaze, rezart
 foxxx2010
Lithuania
User ID: 31627
Threads: 13
Likes: 2,013 in 182 posts
Given Likes: 753
05-14-2012, 06:10 PM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 20 users Like foxxx2010's post:20 users Like foxxx2010's post
  • rezart, versiondemo, rusty, NBZ1400, 3fan, ruaumoko, terrorruban, cace-01, zrilek, ibg0203, Dell_Brett, DamirDz, draluka, stash, JoseCivil, shadabg, blaze, bridgeengineer, chrono146, harsono
Threads: 154
07-30-2012, 06:34 AM
Mirror:
[-] The following 1 user Likes shadabg's post:1 user Likes shadabg's post
  • hignacio43
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,035 in 2,188 posts
Given Likes: 42494
04-22-2013, 03:07 PM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
 ibg0203
China
User ID: 1557
Threads: 288
Likes: 6,208 in 686 posts
Given Likes: 1411
11-26-2015, 06:21 PM
[-] The following 6 users Like ibg0203's post:6 users Like ibg0203's post
  • oanm2000, draluka, Dell_Brett, PinkPant, TAFATNEB, bridgeengineer
Threads: 57
01-19-2021, 07:12 AM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 10 users Like kowheng's post:10 users Like kowheng's post
  • durden, milova, 88FeNIX, Aviator, babakfeyzi, zrilek, PinkPant, Dell_Brett, emmi, CAMSECT
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 38
Likes: 4,964 in 638 posts
Given Likes: 3501
01-25-2021, 02:13 AM
concrete solution advocate
[-] The following 11 users Like concreteok's post:11 users Like concreteok's post
  • milova, simanta, jcbv, blaze, Dell_Brett, CAMSECT, tuanpecc1, jorgeramos, psk62, PinkPant, TAFATNEB
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 38
Given Likes: 3501
#10
01-13-2025, 08:17 AM (This post was last modified: 01-14-2025, 08:51 AM by lisine.)
pass
[-] The following 2 users Like concreteok's post:2 users Like concreteok's post
  • Dell_Brett, babakfeyzi
  Behaviour Of Reinforced Concrete Flat Slabs mowafi3m 3 4,297 07-19-2018, 12:38 PM
Last Post: febo927
  Creep Behaviour in Cracked Sections of Fibre Reinforced Concrete: TAFATNEB 1 1,902 02-06-2017, 06:22 AM
  FIB 46: Fire design of concrete structures - structural behaviour and assessment oscargon 1 2,259 04-03-2014, 07:50 AM
Last Post: Mohammad6299
  Concrete Delivery Time Study mahyarov 0 1,554 10-29-2012, 06:55 AM
Last Post: mahyarov
  Concrete Behaviour in Multiaxial Compression lisine 0 1,869 05-24-2012, 09:42 AM
  Time Effects in Concrete Structures lamkin 0 2,584 04-23-2010, 01:53 PM
Last Post: lamkin
