Civil Engineering Association eBooks Structural Books Steel STRUCTURAL STEEL ENGINEERING AND DESIGN
 mowafi3m
Egypt
User ID: 1236
Threads: 385
Likes: 9,317 in 676 posts
Given Likes: 1667
01-15-2011, 12:03 PM (This post was last modified: 01-15-2011, 12:08 PM by mowafi3m.)
Author: MAX KURTZ, P.E. | Size: 8.05 MB | Format: PDF | Publisher: unknown | Year: unknown | pages: 202 | ISBN: unknown
[Image: 25340241327943202730.jpg]
Part 1: Statics, Stress and Strain, and Flexural Analysis
Graphical Analysis of a Force System
ANALYSIS OF STRESS AND STRAIN
STRESSES IN FLEXURAL MEMBERS
DEFLECTION OF BEAMS
STATICALLY INDETERMINATE STRUCTURES
MOVING LOADS AND INFLUENCE LINES
RIVETED AND WELDED CONNECTIONS
Part 2: Structural Steel Design
STEEL BEAMS AND PLATE GIRDERS
STEEL COLUMNS AND TENSION MEMBERS
PLASTIC DESIGN OF STEEL STRUCTURES
LOAD AND RESISTANCE FACTOR METHOD
Part 3: Hangers and Connections, Wind-Shear Analysis
Design of an Eyebar
Analysis of a Steel Hanger
Analysis of a Gusset Plate
Design of a Semirigid Connection
Riveted Moment Connection
Design of a Welded Flexible Beam Connection
Design of a Welded Seated Beam Connection
Design of a Welded Moment Connection
Rectangular Knee of Rigid Bent
Curved Knee of Rigid Bent
Base Plate for Steel Column Carrying Axial Load
Base for Steel Column with End Moment
Grillage Support for Column
Wind-Stress Analysis by Portal Method
Wind-Stress Analysis by Cantilever Method
Wind-Stress Analysis by Slope-Deflection Method
Wind Drift of a Building
Reduction in Wind Drift by Using Diagonal Bracing
Light-Gage Steel Beam with Unstiffened Flange
Light-Gage Steel Beam with Stiffened Compression Flange
[-] The following 53 users Like mowafi3m's post:53 users Like mowafi3m's post
  • kowheng, lamkin, jcbv, almadar12, vardan, oanm2000, Dell_Brett, robertsas, zego2000, jjmtz, usman, Quantumm, surajdas, mastermind, pm81, Adam Smith, gatob, sodapas, orambo, Ivan_1980, Administrator , zainseiya, zrilek, Hengki, goober, durden, Nilupa, tamboon, thebeatles, slowet, kmmh76, kvtasp, hcardenas, dovsky, ting tsai huang, blaze, JUAN101, foxxx2010, mgdario, Pinkto, rohailiyaz, chairatpk, carolinandra, NBZ1400, wahta, bigone, learner20, shanta, ruaumoko, jaks, TAFATNEB, simanta, dquan373
 kvtasp
User ID: 7690
Threads: 69
Likes: 2,028 in 379 posts
Given Likes: 791
12-15-2011, 12:20 PM
[-] The following 7 users Like kvtasp's post:7 users Like kvtasp's post
  • kowheng, seriousboy, simanta, Jackass, baikur, duazo2009, bigone
 bigone
User ID: 4505
Threads: 92
Likes: 5,722 in 517 posts
Given Likes: 7145
04-21-2012, 08:47 AM (This post was last modified: 04-21-2012, 09:39 AM by kowheng.)
HANDBOOK OF CIVIL ENGINEERING CALCULATIONS
Author: Tyler G. Hicks, P.E. | Size: 13.7 MB | Format: PDF | Quality: Original preprint | Publisher: McGraw-Hill | Year: 2007 | pages: 883 | ISBN: 0071472932
Structural Steel Engineering and Design by MAX KURTZ, P.E. is the first chapter of :
CALCULATIONS
Tyler G. Hicks, P.E., Editor
International Engineering Associates
Member: American Society of Mechanical Engineers
United States Naval Institute
S. David Hicks, Coordinating Editor
Second Edition 2007
CONTENTS
Preface ix
How to Use This Handbook xiii
Section 1. Structural Steel Engineering and Design 1.1 (MAX KURTZ, P.E.)
Section 2. Reinforced and Prestressed Concrete Engineering and Design 2.1
Section 3. Timber Engineering 3.1
Section 4. Soil Mechanics 4.1
Section 5. Surveying, Route Design, and Highway Bridges 5.1
Section 6. Fluid Mechanics, Pumps, Piping, and Hydro Power 6.1
Section 7. Water-Supply and Storm-Water System Design 7.1
Section 8. Sanitary Wastewater Treatment and Control 8.1
Section 9. Engineering Economics 9.1
Bibliography B.1
Index I
[-] The following 18 users Like bigone's post:18 users Like bigone's post
  • blaze, kowheng, jcbv, stosto6666, Dell_Brett, 88FeNIX, ranger, maad59, shanta, nassara, ruaumoko, Jackass, terrorruban, malc, seriousboy, mowafi3m, simanta, ting tsai huang
  Benchmark cases for advanced design of structural steel connection melekeen 1 3,979 06-22-2024, 04:05 AM
  Australia Steel Institute - Design capacity tables for structural steel leong8929 5 6,746 12-26-2022, 10:41 AM
  Structural Steel Design: A Practice Oriented Approach -- Aghayere, Vigil psa_1987 10 10,230 02-11-2021, 02:20 AM
Last Post: eng donny
  Structural Steel Design: Jack C. McCormac saqib 20 21,816 11-16-2020, 02:28 PM
Last Post: KMABD
  Structural Steel Drafting and Design adshrt 3 3,804 07-20-2018, 12:58 PM
Last Post: febo927
  Applied Structural Steel Design - by Leonard Spiegel usman 3 5,217 06-14-2018, 12:26 PM
Last Post: febo927
  Limit States Design in Structural Steel - 7th Edition by G.L. Kulak usman 5 8,602 04-11-2017, 09:25 AM
Last Post: monter
