Civil Engineering Association eBooks Structural Books Steel Commentary and worked examples to EN 1993-1-10
 datagap
User ID: 24267
Threads: 48
Likes: 695 in 68 posts
Given Likes: 176
12-19-2010, 02:47 AM
Commentary and worked examples to EN 1993-1-10 “Material toughness and through thickness properties“ and other toughness oriented rules in EN 1993
Author: G. Sedlacek, M. Feldmann, B. Kühn, D. Tschickardt, S. Höhler, C. Müller, W. Hensen, N. Stranghöner, W. Dahl, P. Langenberg, S. Münstermann, J. Brozetti, J. Raoul, R. Pope, F. Bijlaard | Size: 25.9 MB | Format: PDF | Publisher: European Communities | Year: 2008 | pages: 262
[Image: 65144368280949464720.png]
This joint ECCS-JRC report is part of a series of background-documents in support to the implementation of Eurocode 3. It provides background information on the specific issue of design rules affected by the toughness of steel.
In its various parts, EN 1993 – Eurocode 3 currently addresses steel properties essentially with regard to strength. The toughness properties are also dealt with in Part 1-10 and Part 1-12.
The interrelation between toughness properties and the safety of steel structures is not commonly known, and therefore EN 1993-1-10 does not explicitly address this issue. The background material to EN 1993-1-10 presented in this report provides the necessary explanations on the underlying principles and their application rules. It also opens the door to the application of these principles to situations not yet fully covered by EN 1993.
Due to its rather innovative character, some of the contents of this joint ECCS-JRC still needs to be complemented through additional research likely to be carried out in the context of the further development of Eurocode 3.
The European Convention for Constructional Steelwork (ECCS) has initiated the development of this commentary in the frame of the cooperation between the Commission (JRC) and the ECCS for works on the further evolution of the Eurocodes. It is therefore published as a Joint Commission (JRC)-ECCS-report.
[-] The following 19 users Like datagap's post:19 users Like datagap's post
  • kowheng, knrsa, usman, ibg0203, zrilek, sodapas, baikur, cristi, zinousoft, foxxx2010, Dell_Brett, mowafi3m, blaze, gatob, Quantumm, Nilupa, jcbv, kmmh76, andersen3
 avge
Greenland
User ID: 27510
Threads: 10
Likes: 580 in 54 posts
Given Likes: 600
02-03-2011, 12:28 PM
New link to this report from th JRC webpage:
[-] The following 10 users Like avge's post:10 users Like avge's post
  • Dell_Brett, zrilek, vardan, kostis, usman, jferrer, robertsas, cristi, chenamoy, Nilupa
  Steel Building Design: Worked examples for students rami1976 0 1,965 11-12-2015, 10:39 PM
  Steel Building Design: Worked Examples – Open Sections (SCI P364) jamildear4u 5 4,738 12-17-2013, 02:04 PM
  SCI P376 - Steel Building Design: Worked Examples for Students jamildear4u 3 2,689 10-13-2013, 08:38 AM
Last Post: vinnunsam
  Worked examples in EC3 and EC4 baikur 3 5,581 09-18-2012, 01:46 PM
  COMMENTARY AND WORKED EXAMPLES TO EN 1993-1-5 “PLATED STRUCTURAL ELEMENTS” ir_71 2 3,156 07-31-2012, 06:21 AM
Last Post: shadabg
  Steel Building Design: Worked Examples - Hollow Sections 3fan 1 2,558 02-05-2012, 12:37 AM
Last Post: joker™
