Civil Engineering Association eBooks General Books Using the Building Regulations: Part C: Site Preparation resistance to contaminants m
12-17-2010, 04:50 PM
Using the Building Regulations: Part C: Site Preparation resistance to contaminants moisture
Author: MJ Billington | Size: 4.2 MB | Format: PDF | Publisher: Butterworth-Heinemann | Year: 2007 | pages: 232 | ISBN: 0750662581
[Image: 56553819473839137076.jpg]
Abstract
Discusses the key stages of preparation, compliance, inspection and enforcement. Advises on alternative routes to compliance not explained in the Approved Documents as well as traditional approaches. Analyses advantages and disadvantages of each form of compliance. Explains how to prepare a site's fixtures, including floors, walls, window frames, door thresholds, and roofs, against contamination and moisture.
ISBN
9780750662581
Subject(s)
Building structure
Building foundations/ground floors
Walls/masonry/cavity walls
Coverings and surface finishes
Cladding/covering
Waterproofing/damp proofing
Legal issues and management
Building control
Building control, England and Wales
Supplement
Core. To subscribe to The Construction Information Service please telephone Customer Care on +44 1344 328300
Keyword(s)
building regulations ; approved document ; british standard ; british standards ; risk assessment ; thermal insulation ; external walls ; building materials ; site investigation ; building services ; design and construction ; natural ventilation ; waste disposal ; bre digest ; external wall ; mechanical ventilation ; designed and constructed ; building act ; pitched roofs ; windows and doors ; building control ; surface water ; approved documents ; approved inspectors ; heat loss ; codes of practice ; vapour control layer ; site investigations ; cavity wall ; cavity walls ; thermal bridging ; domestic buildings ; risk assessments ; slating and tiling ; construction materials ; alarm systems ; piled foundations ; concrete slab ; roof covering ; building components ; masonry walls ; timber frame ; damp proof course ; approved inspector ; site preparation ; replacement windows ; cavity wall insulation ; floor slab ; damp proof courses ; cavity tray ; roof construction ; thermal bridges ; door frames ; damp proof membrane ; swimming pools ; timber floors ; window frames ; natural stone ; building project ; floor finish ; surface finish ; vapour control layers ; cavity insulation ; services engineers ; mastic asphalt ; wood preservatives ; floor slabs ; external insulation ; protection of structures ; electrical wiring ; cold stores ; metal cladding ; sanitary fittings ; solid wall ; raft foundation ; wall cladding ; roofs and claddings ; wall coverings ; bre digests ; fire engineers ; external renderings ; weep holes ; level thresholds ; rendered finish ; wall covering ; door thresholds ; building defects ; brick or block ; membrane material ; external claddings ; beam and block floor ; block floor
  â€¢ kowheng, blaze, usman, Dell_Brett, rezart, Nilupa, ykhackhack, Mohammad6299
 Mohammad6299
User ID: 42302
Threads: 251
Likes: 7,913 in 854 posts
Given Likes: 4212
02-26-2014, 06:35 AM
[-] The following 5 users Like Mohammad6299's post:5 users Like Mohammad6299's post
  â€¢ subin91, malc, ykhackhack, Dell_Brett, PinkPant
  Rapid Preparation for the General Fundamentals of Engineering Exam usman 4 4,129 05-30-2013, 09:43 AM
Last Post: bigone
  Frost Resistance of Building Materials ir_71 0 1,735 06-22-2011, 03:26 AM
  Site Management of Building Services Contractors ir_71 0 1,831 06-02-2011, 04:33 PM
