Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 13636:2004 Cathodic protection of buried metallic tanks and related piping
Threads: 1,298
12-04-2010, 07:37 AM
Author: CEN/TC 219 | Size: 0.5 MB | Format: PDF | Publisher: CEN | Year: 2004
[Image: 77550704848035156021.jpg]
This document specifies the principles for the implementation of a system of cathodic protection
against corrosive attacks on buried metal tanks and associated piping.
This document specifies conditions and parameters to be met in order to achieve cathodic protection,
as well as rules and procedures for the design, installation, commissioning and maintenance for the
protection of buried metal tanks and associated piping.
This document is applicable to the external surfaces of buried metallic tanks and associated buried
piping.
NOTE The protection of internal surfaces is covered by EN 12499.
This document is applicable to buried tanks and associated piping, even if they are earthed by their
own local earthing device, which are electrically separated from any general earthing systems and
other buried structures.
Therefore tanks which are covered by the present document include:
 industrial storage tanks, irrespective of their dimensions and the nature of the stored medium
(liquid or gas, flammable or not, toxic or non-toxic, polluting or not);
 tanks used at petrol stations and on domestic or commercial premises, which contain flammable
liquids or gases or polluting substances.
This document is not applicable to:
 above-ground storage tank floors in contact with the ground;
 reinforced concrete containers;
 buried storage tanks that are electrically connected to the whole or a part of an industrial
complex;
 buried storage tanks electrically connected to any general earthing systems.
NOTE Cathodic protection of the last two types of tanks is covered by prEN 14505.
Measurement techniques are described in detail in EN 13509.
  • kowheng, zrilek, toa011, usman, Quantumm, faros3000, Grunf, roaming79
  EN 10204:2004 Metallic products - Types of inspection documents ir_71 1 2,695 04-11-2014, 04:33 AM
  EN 12502 parts 1 to 5 Protection of metallic materials against corrosion ir_71 0 2,164 12-19-2010, 10:50 AM
