Civil Engineering Association Software Software Product Csi Products PERFORM 3D Perform3D v4
Perform3D v4
 timosi™
User ID: 3890
Threads: 138
Likes: 5,532 in 394 posts
Given Likes: 1812
10-11-2009, 04:56 PM (This post was last modified: 05-15-2024, 06:50 AM by Administrator.)
CSi Perform3D
V4.0.3
Demo Version
[Image: adbjgfhjzpys9m2ve4p8.png]
PERFORM 3D is a highly focused nonlinear software tool for earthquake resistant design. Complex structures, including those with intricate shear wall layouts, can be analyzed nonlinearly using a wide variety of deformation-based and strength-based limit states.
Model data can be imported directly from ETABS and SAP2000. A wide variety of element types are supported, including beams (with panel zones), columns, braces, shear walls (with openings), floor slabs, dampers, and isolators.
Nonlinear analyses can be static and/or dynamic, and can be run on the same model. Loads can be applied in any sequence, such as a dynamic earthquake load followed by a static pushover.
PERFORM 3D provides powerful performance based design capabilities, and can calculate demand/capacity (usage) ratios for all components and all limit states. Performance assessment based on ATC-40, FEMA-356 or ATC-440 is fully automated.
PERFORM 3D output includes usage ratio plots, pushover diagrams, energy balance displays, as well as mode shapes, deflected shapes, and time history records of displacements and forces.
MODELING
• Import Model Geometry from ETABS and SAP2000
• Easy-to-Use Graphical Interface
• Beam, Column and Brace Members
• Solid, Hollow and Flanged Parametric Shapes
• Shear Links and Panel Zones
• Complex Shear Walls and Floor Slabs
• Dampers and Isolators
• Plastic Hinges with PMM Interaction
• P-Delta Effects
NONLINEAR ANALYSIS
• 3D Nonlinear Static Pushover
• 3D Nonlinear Time-History Earthquake
• Sequential Loading, e.g., Cyclic Pushover
• Automated Analysis Strategies
• Trilinear Force-Deformation Relationship
• Optional Brittle Strength Loss and Stiffness Degradation
• Combine Results for Multiple Earthquakes
• Vary Member Strengths without Changing the Model
• Efficient Solver for Large Structures
DISPLAY
• Demand/Capacity (Usage) Plots
• Pushover Diagrams
• Time-History Records of Displacements, Drifts and Forces
• Moment and Shear Diagrams
• Force Displays for Member Groups
• Animated Deflected Shapes
• Animated Mode Shapes
• Hysteresis Loop Plots
• Mean Demand/Capacity Plots
• Energy Balance Displays
Download Links:
CRACK IS ONLY AVAILABLE FOR VIP ONLY
[Image: mgwe2wo8jqjm1a9z4wy.png]
Password (If need):
1.Follows the rules
2.Use "Search" before posting
4.Do not spam
5.Respect the other members
[-] The following 51 users Like timosi™'s post:51 users Like timosi™'s post
  • Administrator , Administrator , kamran, kamran, milvio, milvio, Dell_Brett, Dell_Brett, alexcv, alexcv, rohailiyaz, rohailiyaz, simanta, simanta, jaks, jaks, Ultra Zone, Ultra Zone, medhat, medhat, falconado, falconado, Luisim, Luisim, zrilek, zrilek, u4406014, u4406014, engr1900, rendel_©, yutt, Adam Smith, KAMM, mohcivil, sourovone, baker0, kurashige, bynkook, rezart, cmimiw, sudika, blaze, erthqkengnr™, jcbv, abouferass88, Shahin, optima, ersin, wripes, pram, Grunf
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 258
Likes: 21,197 in 2,356 posts
Given Likes: 4260
10-11-2009, 05:41 PM
CRACK IS AVAILABLE FOR VIP ONLY
[-] The following 22 users Like Administrator 's post:22 users Like Administrator 's post
  • eng.husham, eng.husham, alkskg, alkskg, milvio, milvio, timosi™, timosi™, aslam, aslam, robertsas, robertsas, alexcv, alexcv, kamran, kamran, simanta, simanta, Ultra Zone, Ultra Zone, trantoanxd, rezart
 mowafi3m
Egypt
User ID: 1236
Threads: 385
Likes: 9,322 in 678 posts
Given Likes: 1667
11-20-2010, 11:23 PM (This post was last modified: 11-03-2021, 05:43 AM by Administrator.)
Perform3D Version 4.0.4
Perform3D_Version_4.0.4
Demo version
[Image: 80774712798909143433.jpg]
DIRECT LINKS thumbup
[-] The following 15 users Like mowafi3m's post:15 users Like mowafi3m's post
  • ilgar, ha893459, relu59, robox514, blaze, kaungthant, rickpma, Ansus, Galileo, ocjocj, zrilek, erthqkengnr™, wa_sin_29, Yerbamate, Rami11
 ingcivilpe
User ID: 25029
Likes: 509 in 19 posts
Given Likes: 13
03-04-2011, 07:57 PM
Perform3D v4.0.4
[Image: Perform3D-v4.0.4-image.jpg]
Download Rapidshare: Perform3D v4.0.4 + Medicine | 110MB
[-] The following 25 users Like ingcivilpe's post:25 users Like ingcivilpe's post
  • zrilek, MOSS2000, haojg, mowafi3m, cristi, Hengki, civilphongvan, ibg0203, Galileo, ha893459, spiderthan, erthqkengnr™, optima, mavilladar, paulocs, prasat, thansau, ersin, Adam Smith, handresy, davegabj, Jackass, joseivancenteno, mohcivil, Rami11
 r3be1
San Marino
User ID: 424
Threads: 49
Likes: 2,809 in 355 posts
Given Likes: 101
03-05-2011, 06:47 AM (This post was last modified: 07-07-2011, 06:05 AM by Grunf.)
this is part 4 from mediafire as per request
[-] The following 4 users Like r3be1's post:4 users Like r3be1's post
  • mary, abouferass88, engiman27, mohcivil
 rezart
User ID: 25808
Threads: 66
Likes: 2,748 in 178 posts
Given Likes: 5842
05-13-2016, 10:22 AM
All links seems to be dead.
Can someone upload Perform 3D 4.0.4 ?
  Perform3D v11 poolmand 0 492 06-21-2026, 06:40 AM
  Perform3D v10 babakfeyzi 2 2,842 12-14-2024, 09:22 PM
Last Post: babakfeyzi
  Perform3D v9 Arigato 1 3,155 05-07-2023, 08:10 AM
Last Post: zrilek
  Perform3D v8 temp1366 5 8,507 11-09-2022, 12:08 PM
Last Post: jumbo13
  Perform3D v7 joker™ 6 12,752 06-11-2020, 05:36 AM
  Perform3D v6 temp1366 3 10,274 12-22-2017, 06:47 PM
Last Post: zipatton
  Perform3D v5 joker™ 22 49,609 09-17-2016, 09:01 PM
Last Post: arslanucar
