Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Shear Behavior of Reinforced Concrete T-Beams with Externally Bonded Fiber...
[Request] Shear Behavior of Reinforced Concrete T-Beams with Externally Bonded Fiber...
 hamzeaziz
Iraq
User ID: 11936
Threads: 17
Likes: 27 in 16 posts
Given Likes: 174
11-20-2010, 08:22 PM (This post was last modified: 11-20-2010, 09:25 PM by Dell_Brett.)
Deniaud, C., and Cheng, J.J.R., “Shear Behavior of Reinforced Concrete T-Beams with Externally Bonded Fiber Reinforced Polymer Sheets”, ACI Structures Engineering Vol.98, pp: 386-494, (2001).
Moderator note:
Please, avoid to use titles like: "...i need this journal PLEASE..."
In the future, it's difficult to be found via Search Engine!
Dell Brett
 miquan
Vietnam
User ID: 631
Threads: 204
Likes: 3,748 in 387 posts
Given Likes: 1331
11-20-2010, 09:47 PM
Size: 0.5 MB | Format: PDF
[-] The following 7 users Like miquan's post:7 users Like miquan's post
  • Dell_Brett, jcoronellr, Grunf, kowheng, usman, hamzeaziz, pousin
  "Deflections in Concrete Slabs and Beams - TR58 - The Concrete Society Publisher" eng-hiep 6 5,430 07-16-2018, 10:28 AM
Last Post: malee
  [REQUEST] Shear in reinforced concrete piles and circular columns avscorreia 1 2,024 08-07-2017, 09:47 AM
  [REQUEST] Strengthening of concrete beams by external prestressing kuri 0 1,468 11-09-2014, 08:19 AM
Last Post: kuri
  [REQUEST] Reinforced Concrete Shear Walls With Openings; Test and Analysis cosminupt 1 1,958 04-23-2014, 04:29 PM
Last Post: Mohammad6299
  [REQUEST] Diagonally reinforced coupling beams of shear walls andre85 0 1,527 03-25-2014, 03:15 PM
Last Post: andre85
  [REQUEST] Experimental and Analytical Investigation of Partially Prestressed Concrete Beams Str AlmostThere 0 1,344 02-17-2014, 04:35 PM
Last Post: AlmostThere
  [REQUEST] Empirical model of the nonlinear vibration of cracked reinforced concrete beams netsonicyxf 0 1,481 12-05-2012, 09:18 AM
Last Post: netsonicyxf
