Civil Engineering Association eBooks Structural Books Steel Lifetime Estimation of Welded Joints
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 264
Likes: 19,035 in 2,188 posts
Given Likes: 42492
11-16-2010, 08:47 AM
[Image: 03463385742026221339.jpg]
Author: Tadeusz Lagoda
True PDF file - 1.153 Kb - 124 pages
2008 Springer-Verlag Berlin Heidelberg
ISBN: 9783540770619
e-ISBN: 9783540770626
In the paper the author attempts to assess the fatigue life of chosen welded joints. It focuses especially on chosen problems that accompany determination of the fatigue life of welded joints, taking into consideration the strain energy density parameter. Chapter 2 describes the welded joint as a stress concentrator. The state of stress and strain in the notch are described and theoretical and fatigue coefficients are indicated. The fatigue coefficient of the notch effect is estimated on the basis of fictitious radius in the notch root. Chapter 3 presents a model of fatigue life assessment under uniaxial stress state with statistical handling of data presented. The new energy model of fatigue life assessment, which rests upon the analysis of stress and strain in the critical plane, is described in detail in chapter 4. The principle of such a description is presented in the uniaxial as well as in biaxial state of loading. Chapter 5 contains the analysis of tests of four materials subjected to different loadings: cyclic, variable-amplitude with Gaussian distribution, and variable amplitude with Gaussian distribution and overloading for symmetric and pulsating loading. The analysis is based on the determined fatigue characteristics for all the considered materials. Chapter 6 shows the application of the model in the fatigue life assessment in the complex state of loading (bending with torsion of flange-tube and tube-tube joints) based on fatigue research of steel and aluminum welded joints carried out in well-known German centres. Proportional and out-of-proportional cyclic research are carried out. Additionally, the influence of various bending and torsion frequencies and proportional and out-of-proportional variable amplitude loadings are analyzed.
[-] The following 16 users Like Dell_Brett's post:16 users Like Dell_Brett's post
  • kowheng, toa011, GioRoc, Grunf, oanm2000, parwez007, jjmtz, faros3000, malc, duazo2009, thebeatles, baikur, Nilupa, jcbv, stosto6666, eliseo.as
 david-smith
United States
User ID: 43924
Threads: 247
Likes: 4,023 in 582 posts
Given Likes: 1085
05-02-2012, 02:16 AM
[-] The following 8 users Like david-smith's post:8 users Like david-smith's post
  • stosto6666, Jackass, slowet, zrilek, seriousboy, cristi, lisine, Dell_Brett
Threads: 54
11-14-2012, 11:47 AM
links dead; mirror here
  • Jackass, eliseo.as, Dell_Brett
 r3be1
San Marino
User ID: 424
Threads: 47
Likes: 2,809 in 355 posts
Given Likes: 101
08-27-2014, 06:51 PM
new links
[-] The following 10 users Like r3be1's post:10 users Like r3be1's post
  • jcbv, malc, gulilero, Mohammad6299, PinkPant, foxxx2010, bridgeengineer, Dell_Brett, sodapas, dinu69in
  Fracture and fatigue of welded joints and structures gulilero 2 2,794 07-09-2017, 10:09 PM
  Design of SHS welded joints gulilero 0 1,922 04-02-2016, 05:33 AM
Last Post: gulilero
