08-27-2010, 08:13 PM
Canadian Span Book 2004
![[Image: 46392424379823949004.jpg]](https://pic.civilea.com/images/46392424379823949004.jpg)
The Span Book
Publisher Canadian Wood Council
Year of release 2004
Format Softcover
Pages 315 pages
ISBN or Catalogue No 0-921628-69-2
The Span Book
The Span Book is a supplement to the wood joist, rafter and beam spans found in the National Building Code of Canada. This booklet contains span tables in metric and imperial units for wood joists, rafters, beams and lintels.
Builders, building officials and specifiers of wood frame construction can use these tables to supplement those published in the National Building Code of Canada in accordance with the authority having jurisdiction. Tables in the Span Book and the National Building Code of Canada were both generated by the Canadian Wood Council.
* Chapter 1: Scope Energy and the Environment - Canadian Wood Frame Construction
* Chapter 2: Energy and the Environment-Canadian Wood Frame Construction
* Chapter 3: Specification
* Chapter 4: Minimum Code Requirements
* Chapter 5: Spans
* Chapter 6: Supported Length
* Chapter 7: Design Considerations
* Chapter 8: Other Loads
* Chapter 9: Grade Stamps
Table metric units joists:
Floor and Ceiling Joists (Tables 1-2)
Rafters : Roof Joists and Rafters (Tables 3-4)
Beams : Beams and Lintels (Tables 5-9)
Table imperial units:
Imperial Units Joists : Floor and Ceiling Joists (Tables 1-2)
Beams : Beans and Lintels (Tables 5-9)
![[Image: password.png]](http://forum.civilea.com/postgen/password.png)
