Civil Engineering Association eBooks Codes, Manual & Handbook ACI [CivilEA Exclusive] ACI 355.5: Post-Installed Reinforcing Bar Systems in Concrete—Qualification Requireme
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
12-06-2025, 11:37 AM (This post was last modified: 12-06-2025, 11:38 AM by poolmand.)
ACI CODE-355.5-24: Post-Installed Reinforcing Bar Systems in Concrete—Qualification Requirements and Commentary
Author(s)/Editor(s): ACI Committee 355 | Size: 8.83 MB| Format: PDF| Quality: Scanner| Year: 2024| pages: 89
[Image: do.php?img=20]
This Code prescribes testing programs and evaluation requirements for post-installed reinforcing bars intended for use in concrete under the straight-bar development and splice length design provisions of ACI CODE-318. Testing and assessment criteria are provided for various conditions of use, including seismic loading, sustained loading, aggressive environments, and reduced and elevated temperatures. Criteria are provided for establishing the required characteristic bond strength, reductions for adverse conditions, and associated job-site quality control requirements.
post-installed reinforcing bars; qualification procedures.
  • rami1976, Dell_Brett, babakfeyzi, subin91, lisine
  [CivilEA Exclusive] ACI 355.2: Post-Installed Mechanical Anchors in Concrete—Qualification Requir poolmand 1 2,466 12-15-2024, 06:03 AM
  ACI 355.4: Qualification of Post-Installed Adhesive Anchors in Concrete and Comment Mohammad6299 3 3,895 12-14-2024, 12:54 PM
  ACI SP-314: Eco-Efficient and Sustainable Concrete Incorporating Recycled Post-Consum poolmand 0 1,681 03-04-2024, 07:34 AM
  ACI 222: Guide to Protection of Reinforcing Steel in Concrete against Corrosion poolmand 1 2,125 05-09-2023, 01:15 PM
  ACI 364.8: Hydrodemolition for Concrete Removal in Unbonded Post-Tensioned Systems poolmand 0 1,443 05-02-2023, 11:55 AM
  ACI 364.6: Concrete Removal in Repairs Involving Corroded Reinforcing Steel poolmand 0 1,536 05-02-2023, 11:43 AM
  ACI 423.8: Corrosion and Repair of Grouted Post-Tensioning Tendon Systems - Re poolmand 0 1,350 12-04-2021, 10:00 AM
