Civil Engineering Association eBooks Codes, Manual & Handbook AS 1597.2: recast reinforced concrete box culverts Large culverts (exceeding 1200 mm
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
12-02-2024, 11:51 AM
AS 1597.2-2013: recast reinforced concrete box culverts Large culverts (exceeding 1200 mm span or 1200 mm height and up to and including 4200 mm span and 4200 mm height)
| Size: 16.66 MB| Format: PDF| Quality: Scanner| Year: 12-08-2013
Sets out minimum requirements for the design, manufacture and installation of precast reinforced concrete rectangular box culverts for conveying water not under pressure, and for carrying roadway and railway loadings specified by the AS5100 series.
  â€¢ babakfeyzi, rami1976, subin91, Dell_Brett
  AS 1597.1: Precast reinforced concrete box culverts Small culverts (not exceeding 120 poolmand 0 2,969 12-02-2024, 11:47 AM
