Civil Engineering Association eBooks Codes, Manual & Handbook CSA CSA S826 SERIES: Ferry Boarding Facilities
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
05-07-2024, 05:24 AM
CSA S826 SERIES:01 (R2021) Ferry Boarding Facilities
| Size: 23.9 MB| Format: PDF| Quality: Scanner| Year: 2001 (R2021)| pages: 117
[Image: 96189605472183080767.jpg]
This is the first edition of the CSA S826 Series of Standards, Ferry Boarding Facilities. It consists of the following four documents:
a) CSA S826.1, Ferry Boarding Facilities — Design;
b) CSA S826.2, Ferry Boarding Facilities — Operations (Guideline);
c) CSA S826.3, Ferry Boarding Facilities — Inspection; and
d) CSA S826.4, Ferry Boarding Facilities — Maintenance (Guideline).
These Standards and Guidelines have been developed as a resource for designers and owners of ferry boarding facilities operated in Canadian waters. Their purpose is to provide a consolidated standard of minimum requirements and guidelines for the design, operation, inspection, and maintenance of such facilities. Additionally, they are intended to encompass items not addressed in other standards.
These Standards reflect the diversity of ferry boarding facilities and their operating environments throughout Canada and are therefore based on general principles and objectives. Requirements are expressed in broad terms so that they may have the widest possible national application.
To accommodate the diversity of applications in Canada, the provisions set out by these Standards combine both code requirements and guidelines. In general, the design Standard (CSA S826.1) and the inspection Standard (CSA S826.3) are Standards expressed in mandatory language. The operations (CSA S826.2) and maintenance (CSA S826.4) Guidelines are expressed in recommendatory language.
  • babakfeyzi
