01-16-2024, 08:02 AM
AWWA B301-18 Liquid Chlorine
| Size: 4.9 MB| Format: PDF| Quality: Scanner| Year: 2018 | ISBN: 9781625762825
![[Image: 22918064285460209231.jpg]](https://pic.civilea.com/images/22918064285460209231.jpg)
This standard describes liquid chlorine for use in potable water, wastewater, and reclaimed water treatment.
The purpose of this standard is to provide the minimum requirements for liquid chlorine, including physical, chemical, sampling, testing, packaging, and shipping requirements.
This standard can be referenced in documents for purchasing and receiving liquid chlorine and can be used as a guide for testing the physical and chemical properties of liquid chlorine samples. The stipulations of this standard apply when this document has been referenced and then only to liquid chlorine used in the treatment of potable water, wastewater, or reclaimed water.
