Civil Engineering Association eBooks Codes, Manual & Handbook AWWA AWWA B300: Hypochlorites
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
01-16-2024, 07:28 AM
AWWA B300-18 Hypochlorites
| Size: 6.56 MB| Format: PDF| Quality: Scanner| Year: 2018 | ISBN: 9781625763051
[Image: 95780423677898675854.jpg]
This standard describes chlorinated lime, calcium hypochlorite, and sodium hypochlorite for use in water, wastewater, and reclaimed water treatment.
The purpose of this standard is to provide the minimum requirements for hypochlorites, including physical, chemical, sampling, testing, packaging, and shipping requirements.
This standard can be referenced in documents for purchasing and receiving hypochlorites and can be used as a guide for testing the physical and chemical properties of hypochlorite samples. The stipulations of this standard apply when this document has been referenced and then only to hypochlorites used in water supply service, wastewater treatment, and reclaimed water treatment applications.
  â€¢ babakfeyzi, PinkPant
