Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM D2573/D2573M: Standard Test Method for Field Vane Shear Test in Saturated Fine-G
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
10-28-2023, 06:32 AM
ASTM D2573/D2573M-18: Standard Test Method for Field Vane Shear Test in Saturated Fine-Grained Soils
| Size: 7.6 MB| Format: PDF| Quality: Scanner| Publisher: ASTM International| Year: 2018| pages: 9
  â€¢ zrilek, kowheng, utan, Dell_Brett, subin91, PinkPant
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 3,102 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,431 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 3,215 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 3,273 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,490 11-12-2023, 08:07 AM
  STM D6927: Standard Test Method for Marshall Stability and Flow of Asphalt Mixtures poolmand 0 3,076 11-04-2023, 10:57 AM
