02-02-2022, 09:48 AM
Local Compression Property of Rammed Earth Wall with Bamboo Cane Based on ANSYS
Abstract: Local compression damage is a common form of damage in the rammed earth wall bearing buildings.Local compression property of rammed earth wall with bamboo cane under roof load was analyzed using the finite element software ANSYS. Through comparison with rammed earth wall without bamboo cane,the role of bamboo cane in rammed earth wall was analyzed. The role of the method adding wooden blocks in improving local compression property was analyzed. The results indicate that there is obvious stress concentration at the contact area of wall and purlins. The bamboo cane can reduce the displacement of rammed earth wall,and increase the integrity of wall,but there's no use for improving local compression property. The method of adding wooden blocks can improve local compression property effectively.
