Civil Engineering Association eBooks Structural Books Concrete The Ultimate Load Design of Continuous Concrete Beams
 febo927
User ID: 23688
Threads: 105
Likes: 4,179 in 339 posts
Given Likes: 1279
07-17-2018, 01:23 PM
Author(s)/Editor(s): Derrick Beckett | Size: 3 MB | Format: PDF | Quality: Scanner | Publisher: Springer US | Year: 1967 | pages: 116 | ISBN: 1489962980 / 978-1489962980
[Image: 95450776695063555809.jpg]
This book is intended for the use of final year undergraduates and in the design office. It is an attempt to bridge the gap between conventional design procedures for continuous concrete beams, based on an elastic distribution of moments at working Ioad, and the ultimate Ioad approach, which is based on the plastic behaviour of concrete beams. The text assumes that the reader has an elementary knowledge of the elastic sizing of reinforced concrete sections and is reasonably familiar with the section of CP 114 : 1957 relating to design considerations.
Chapter 1 discusses the limitations of elastic design and the basis of ultimate Ioad design together with British, American and Russian design rules. Chapters 2 and 3 dea1 with the behavior of reinforced and prestressed concrete sections under Ioad. In Chapter 4 the formation of plastic hinges is discussed together with a summary of the work of Professor A.L.L. Baker. The final two chapters consider Serviceability requirements, crack width limitations etc., and the problems of shear and torsion. Several worked examples are included in the text together with a comprehensive reference Iist and metric conversion table.
[-] The following 14 users Like febo927's post:14 users Like febo927's post
  • mgdario, gulilero, zrilek, caifan, tuanpecc1, PinkPant, milova, malc, oanm2000, cace-01, Dell_Brett, Aviator, cristi, kowheng
  Guide Specifications for the Design of Concrete Bridge Beams Prestressed with Carbon poolmand 2 3,806 08-30-2023, 08:59 AM
  Compressive Force-Path Method: Unified Ultimate Limit-State Design of Concrete Struct cace-01 3 3,526 07-17-2017, 04:31 AM
Last Post: tomtumx
  Reinforced Concrete Deep Beams - by F K Kong Flexi 6 5,194 11-06-2016, 09:00 AM
  Ultimate limit-state design of concrete structures - a new approach - M.Kotsovos ynopum 4 4,097 04-14-2015, 02:59 PM
Last Post: f_slikken
  Reinforced Concrete Beams, Columns and Frames asim99 3 2,803 08-04-2013, 02:39 PM
Last Post: ssobhan
  Continuous Prestressed Concrete Girder Bridges. Volume 1 mahyarov 0 1,677 10-30-2012, 07:57 AM
Last Post: mahyarov
  Lateral Load Distribution for Steel Beams Supporting an FRP Panel mahyarov 0 1,475 10-29-2012, 06:25 AM
Last Post: mahyarov
