Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] paper from ACI Journal
[Request] paper from ACI Journal
 eyad
User ID: 29815
Threads: 8
Likes: 3 in 2 posts
Given Likes: 9
02-13-2017, 11:50 AM
Dear All,
Can i get this paper from ACI journal
Title: Softening Response of Plain Concrete in Direct Tension
Author(s): V. S. Gopalaratnam and Surendra P. Shah
Publication: Journal Proceedings
Volume: 82
Issue: 3
Appears on pages(s): 310-323
Keywords: cracking (fracturing); crack width and spacing; cyclic loads; defor-mation; finite element method; mechanical properties; microcracking; plain concrete; serviceability; stiffness; stress-strain relationships; tensile strength;tension.
Date: 5/1/1985
Abstract:
For rational and accurate analysis of concrete structures, it is often desirable to include the post-cracking resistance of concrete. Due to the difficulties of testing concrete in direct uniaxial tension, only limited and often conflicting data are available. In the present investigation a method was developed to obtain reliable load-deformation behavior in tension, including the post-peak softening response. To characterize the softening response, strains at various locations on the specimens, elongations for various gage lengths, and optical measurements of crack widths were made. Seven different mix proportions were used to obtain information on the influence of aggregate size, water-cement ratio, and volume content of aggregates. An analytical expression has been developed to describe the entire tensile response of concrete.
Thanks All
  β€’
 amindoxiti
User ID: 86739
Threads: 192
Likes: 8,341 in 584 posts
Given Likes: 2618
02-13-2017, 03:11 PM
Do not worry about your difficulties in Mathematics, I can assure you mine are still greater. Β -Albert EinsteinΒ  Β  Β  Β  Β  Β
[-] The following 6 users Like amindoxiti's post:6 users Like amindoxiti's post
  β€’ K.Lee, malc, oanm2000, Dell_Brett, eyad, febo927
  [REQUEST] Journal Paper Required ska51 1 1,688 08-12-2021, 08:02 AM
Last Post: xnr09
  [REQUEST] paper from ACI journal eyad 7 4,030 11-13-2019, 09:08 PM
Last Post: nandicivil
  [REQUEST] Need a Paper from IWA "Hydrology Reseach" Journal ska51 1 1,720 12-06-2017, 02:06 PM
  [REQUEST] paper from ACI Structural Journal Badis 1 1,942 07-23-2016, 10:19 AM
Last Post: xnr09
  [REQUEST] Hydrology Research Journal Paper, IWA ska51 1 1,966 12-12-2015, 11:11 AM
Last Post: hich
  [REQUEST] paper - IWA published Journal ska51 1 1,936 09-27-2015, 07:29 AM
Last Post: Mohammad6299
  [REQUEST] Paper - ACI Structural Journal Sumatra 2 2,311 09-19-2015, 07:55 AM
Last Post: ssobhan
