Civil Engineering Association eBooks Structural Books Steel Design of SHS welded joints
 gulilero
Italy
User ID: 14057
Threads: 113
Likes: 4,989 in 647 posts
Given Likes: 6732
04-02-2016, 05:33 AM
[Image: 36278928380343199458.png]
  • Author(s): Corus - Structural & Conveyance Business
  • Published By: Corus Group
  • Published Year: 2005
  • DOI: N.A.
  • Size: 0.29 MB
  • Quality: Original preprint
  • Abstract: In construction with structural hollow sections the members are generally welded directly to each other and, as a result, member sizing has a direct effect on both the joint capacity and the cost of fabrication. In order to obtain a technically secure, economic and architecturally pleasing structure, both the architect and design engineer must, from the very beginning, be aware of the effects that their design decisions will have on the joint capacity, the fabrication, assembly and the erection of the structure.
    Structural hollow sections have a higher strength to weight ratio than open section profiles such as I-, H- and L- sections. They also require a much smaller weight of protection material, whether this is a fire protection or corrosion coating, because of their lower external area.
    A properly designed steel construction using structural hollow sections will nearly always be lighter in terms of material weight than a similar construction made with open section profiles and, although structural hollow sections are more expensive than open section profiles on a per tonne basis, the overall weight saving of steel and protective coatings will very often result in a much more cost effective construction.
    This publication has been produced to show how the joint capacity of staticaly loaded joints can be calculated and how it can be affected by both the geometric layout and the sizing of the members.
[Image: comments.png]
See Related Thread:
[-] The following 36 users Like gulilero's post:36 users Like gulilero's post
  • jcbv, agelos100, Andrew seah, subin91, blaze, milova, tomtumx, Dell_Brett, PinkPant, zrilek, oanm2000, red_pool61, melekeen, mgdario, ykhackhack, er.shyams, dizz, K.Lee, psk62, Trishu999, dquan373, knrsa, Jackass, Wijono, ingchio, malc, f_slikken, cace-01, sodapas, stigtg, anfaga, yanburak, caifan, araza023, slowet, febo927
  ECCS - European Recommendations for the Design of Simple Joints in Steel Structures agelos100 0 1,889 05-14-2020, 09:19 AM
Last Post: agelos100
  Design of Joints in Steel and Composite Structures amindoxiti 3 3,824 12-17-2019, 06:53 AM
  design and analysis of fatigue resistant welded structures david-smith 2 2,621 07-20-2018, 04:15 AM
Last Post: axcel
  Design of Welded Steel Structures: Principles and Practice RyanRS 2 3,030 07-26-2017, 08:20 AM
  Fracture and fatigue of welded joints and structures gulilero 2 2,796 07-09-2017, 10:09 PM
  Guide to Design Criteria for Bolted and Riveted Joints (2ed) Ultra Zone 4 4,387 12-16-2015, 05:42 PM
Last Post: cargadory2k
  Lifetime Estimation of Welded Joints Dell_Brett 3 3,244 08-27-2014, 06:51 PM
Last Post: r3be1
