Civil Engineering Association eBooks Journals, Papers and Presentations Seismic evaluation of a 56-storey residential reinforced concrete high-rise building
 anfaga
structural engineer
User ID: 12412
Threads: 40
Likes: 606 in 50 posts
Given Likes: 279
02-09-2016, 05:25 PM
based on nonlinear dynamic time-history analyses.
[Image: 77940366879343418701.jpg]
  • Author(s): Siamak Epackachi, Rasoul Mirghaderi1, Omid Esmaili, Ali Asghar Taheri Behbahani and Shahram Vahdani.
  • Published By: Wiley Online Library (wileyonlinelibrary.com).
  • Published Year: 8 March 2010
  • Size: 1,30 MB
  • Quality: Original preprint
  • Abstract: In recent decades, shear walls and tube structures have been the most appropriate structural forms for the construction of high-rise concrete buildings. Thus, recent Reinforced Concrete (RC) tall buildings have more complicated structural behaviour than before. Therefore, studying the structural systems and associated behaviour of these types of structures is very important. The main objective of this paper is to study the linear and nonlinear behaviour of one of the tallest RC buildings, a 56-storey structure, located in a high seismic zone in Iran. In this tower, shear wall systems with irregular openings are utilized under both gravity and lateral loads and may result in some especial issues in the behaviour of structural elements such as shear walls and coupling beams. The analytical methodologies and the results obtained in the evaluation of life-safety and collapse prevention of the building are also discussed. The weak zones of the structure based on the results are introduced, and a detailed discussion of some important structural aspects of the high-rise shear wall system with consideration of the concrete time dependency and constructional sequence effects is also included.
[-] The following 20 users Like anfaga's post:20 users Like anfaga's post
  â€¢ zrilek, TAFATNEB, tomtumx, ting tsai huang, simanta, Dell_Brett, psk62, Sumatra, cace-01, PinkPant, ruaumoko, stosto6666, slowet, KhaLed-S.E, milova, gulilero, learner20, oanm2000, carolinandra, isurya
 ESTRUCTO
User ID: 2666
Threads: 1
Likes: 183 in 21 posts
Given Likes: 35
02-10-2016, 01:19 PM
Thanks for the Journal, but, Could you upload it? The link is dead.
Thanks.
  â€¢
 anfaga
structural engineer
User ID: 12412
Threads: 40
Given Likes: 279
02-10-2016, 02:44 PM
The link was checked and works well.
In any case, I have an alternate link:
[-] The following 9 users Like anfaga's post:9 users Like anfaga's post
  â€¢ ting tsai huang, bridgeengineer, learner20, blaze, oanm2000, draluka, sodapas, civilgen, jayborre
Threads: 1,118
02-10-2016, 02:49 PM
ESTRUCTO
The link is alive (posted less the 24 hours ago you can expect you are wrong).
Are you a spammer ? If yes, remeber my shout and next time try harder without filling the forum with useless posts. It's true is your post no. 14 in almost 7 years but if you finally decided to post something share with your friends here something instead of spamming.
ANFAGA this is your sixth transparent link. Is nice you share with others but must be a limit and you don't need to design a 56 storey for putting links in codes.
  â€¢ usman
  Fazlur R. Khan - Current Trends in Concrete High-Rise Buildings RyanRS 0 5,395 09-16-2015, 03:41 AM
Last Post: RyanRS
  Design of High-Rise Buildings RyanRS 0 5,737 06-06-2015, 01:32 PM
Last Post: RyanRS
  POST-TENSIONED CONCRETE FLOORS IN MULTI-STOREY BUILDINGS ir_71 4 10,789 04-23-2015, 09:15 AM
Last Post: titko
  Evaluation of Egyptian code provisions for seismic design of moment-resisting-frame m TAFATNEB 0 5,217 09-05-2014, 02:03 PM
  Seismic performance of concrete frame structures reinforced with superelastic shape TAFATNEB 0 6,243 09-05-2014, 01:59 PM
  Evaluation Of Earthquake Response Analysis Methods For Low - Rise Base Isolated B. TAFATNEB 0 6,091 09-05-2014, 01:46 PM
  SEISMIC ASSESSMENT OF AN IRREGULAR THREE-STOREY FULL SCA LE RC TEST STRUCTURE WITH SU TAFATNEB 0 4,824 06-03-2014, 09:11 PM
