Civil Engineering Association eBooks Codes, Manual & Handbook AASHTO AASHTO Roadside Design Guide
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
10-03-2015, 05:59 PM (This post was last modified: 01-25-2022, 11:22 AM by Administrator.)
AASHTO Roadside Design Guide 4th Ed
Author(s)/Editor(s): AASHTO | Size: 19.2 MB | Format: PDF | Quality: Unspecified | Publisher: AASHTO | Year: 2011 | pages: 316 | ISBN: 9781560515098
[Image: 50671166823625165140.jpg]
This Roadside Design Guide was developed by the American Association of State Highway and Transportation Officials (AASHTO) Subcommittee on Design through the Technical Committee for Roadside Safety (TCRS) under the chairmanship of Keith Cota, P.E. This book presents a synthesis of current information and operating practices related to roadside safety and is written in dual unitsmetric and U.S. Customary. This edition supersedes the 2006 AASHTO publication, which included the update of the Median chapter.
The roadside is defined as that area beyond the traveled way (i.e., driving lanes) and the shoulder (if any) of the roadway itself. Consequently, roadside delineation, shoulder surface treatments, and similar on-roadway safety features are not extensively discussed.
Although safety can best be served by keeping motorists on the road, the focus of this guide is on safety treatments that minimize the likelihood of serious injuries when a driver does run off the road.
A second noteworthy point is that this book is a guide. It is not a standard, nor is it a design policy. It is intended to be used as a resource document from which individual highway agencies can develop standards and policies. Although much of the material in the guide can be considered universal in its application, several recommendations are subjective in nature and may need modification to fit local conditions. However, it is important that significant deviations from the guide be based on operational experience and objective analysis. To be consistent with AASHTO's A Policy on Geometric Design of Highways and Streets, design speed has been selected as the basic speed parameter to be used in this guide. However, because the design speed often is selected based on the most restrictive physical features found on a specific project, reasonable and prudent drivers may exceed that speed for a significant percentage of a project length. There will be other instances in which roadway conditions will prevent most motorists from driving as fast as the design speed. Because roadside safety design is intended to minimize the consequences of a motorist leaving the roadway inadvertently, the designer should consider the speed at which encroachments are most likely to occur when selecting an appropriate roadside design standard or feature.
Post edited by moderator:
- Corrected ISBN number
[-] The following 26 users Like bigone's post:26 users Like bigone's post
  â€¢ oanm2000, Jackass, ting tsai huang, malc, GMianG, blaze, er.shyams, Dell_Brett, milova, isurya, dinu69in, jfjdm, utan, araza023, Hengki, bridgeengineer, sodapas, PinkPant, ikoleci, deltalead, shaker, cace-01, DamaD, Gabemzaman, henrybill, kowheng
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
01-25-2022, 07:02 AM (This post was last modified: 01-25-2022, 07:03 AM by poolmand.)
AASHTO Roadside Design Guide 4th Edition
Author(s)/Editor(s): AASHTO | Size: 10.91 MB | Format: PDF | Quality: Unspecified | Publisher: AASHTO | Year: 2011 | pages: 356 | ISBN: 9781560515098 , 1560515090
  â€¢ Dell_Brett, babakfeyzi, Andrew seah, oanm2000, jayborre
  AASHTO LRFD Bridge Design Guide Specifications for GFRP-Reinforced Concrete poolmand 0 3,214 08-30-2023, 08:45 AM
  AASHTO: Guide to Wetland Mitigation Issues for Transportation Designers poolmand 0 2,964 01-26-2022, 06:06 AM
  AASHTO: Practical Guide to Cost Estimating poolmand 0 3,037 01-26-2022, 05:46 AM
  AASHTO - Guide Specifications for Design of Pedestrian Bridges junaid 6 5,151 01-25-2022, 07:13 AM
  AASHTO - Guide Specifications for LRFD Seismic Bridge Design ir_71 6 6,406 01-25-2022, 06:47 AM
  AASHTO - Guide Specifications for Seismic Isolation Design ir_71 3 4,514 01-25-2022, 06:32 AM
  AASHTO Guide Specifications for GFRP-Reinforced Concrete poolmand 0 1,385 08-02-2021, 06:45 AM
