Civil Engineering Association eBooks Structural Books Steel Semi-Rigid Joints in Structural Steelwork
 amindoxiti
User ID: 86739
Threads: 203
Likes: 8,341 in 584 posts
Given Likes: 2618
09-11-2014, 02:27 AM (This post was last modified: 09-11-2014, 03:16 AM by Dell_Brett.)
Author: Miklos Ivanyi,Charalambos C. Baniotopoulos | Size: 29 MB | Format: PDF | Quality: Unspecified | Publisher: Springer | Year: 2000 | pages: 347 | ISBN: 3211833315 ISBN13: 9783211833315
[Image: 29739211417626567603.jpg]
Definition of semi-rigid steel structural connections, classification and influence to the structural response of sway and non-sway steel frames. Sources of connection compliance, ductility and the application of the component method for characterization of the joint properties. Verification procedures for the available and the required capacity of joints and the design of semi-rigid steel structural connections. Application of the Finite Element Method for the simulation of the structural response of semi-rigid connections taking into account all prominent nonlinear phenomena (cf. e.g. contact, friction and plasticity).
Do not worry about your difficulties in Mathematics, I can assure you mine are still greater.  -Albert Einstein
[-] The following 26 users Like amindoxiti's post:26 users Like amindoxiti's post
  • subin91, ykhackhack, bridgeengineer, PinkPant, blaze, malc, slowet, warlord1, oanm2000, cace-01, Quantumm, ssobhan, Jackass, apocalipse, jfjdm, zrilek, cristi, jcbv, gulilero, Mohammad6299, araza023, yanburak, harsono, monter, Grunf, Trishu999
 Saze808
User ID: 32657
Threads: 46
Likes: 423 in 62 posts
Given Likes: 91
09-12-2014, 07:35 PM
[-] The following 21 users Like Saze808's post:21 users Like Saze808's post
  • vardan, Apache, Quantumm, dinu69in, gulilero, vishal, blaze, PinkPant, jcbv, zrilek, Kurucz, Mohammad6299, eliseo.as, engrirfan, milova, toa011, araza023, agarciam2, lasalleguy, yanburak, febo927
  Introduction to the Economics of Structural Steelwork mastermind 4 4,085 02-15-2017, 12:28 AM
Last Post: RyanRS
  Semi-rigid Connections Handbook ir_71 3 4,297 05-31-2016, 04:11 PM
Last Post: ssobhan
  Structural steelwork: analysis and design abudabeeja 9 7,787 12-04-2015, 08:09 PM
Last Post: cargadory2k
  Structural Steelwork: Design to Limit State Theory: T.J. MacGinley, T.C. Ang babak 9 8,078 11-10-2015, 02:37 AM
Last Post: ibg0203
  Structural steelwork connections abudabeeja 4 6,368 09-13-2014, 07:49 PM
  Limit States Design of Structural Steelwork - by David Nethercot abudabeeja 7 7,827 07-13-2014, 03:39 PM
Last Post: i_kabir
  Handbook of Structural Steelwork-4th Ed.(printable) ahphuah 4 5,757 02-18-2014, 09:15 AM
Last Post: vinnunsam
